Results 1 to 20 of 20
    Established Member Two Rings marto7's Avatar
    May 06 2017
    Sofia
    What speakers for A4 B7
    Hello guys.Now i am with Concert2 and oem speakers.Not bose system.The cheapest want and its very low quality and power.Now i am going to buy RNS-E navigation and i want to upgrade speakers.I have two questions:
    - What is the output power of the RNS-E navigation ?
    - What is the size of the speakers in the doors ? I want to replace it with same size but better aftermarket speakers.I think i cant fit a larger speakers than oem's one
    Thank you for the help and sorry for my bad english
    Oct 24 2015
    Perth, WA
    The speakers in my signature fit.
    The RNS-E unit only powers the front speakers, the rear speakers are powered by an amp in the trunk area. I would suggest running all to an aftermarket amp, however that much more work.
    In terms of power, its rated at 15A total. That means it cannot possibly provide more than 180W peak.
    As you can see, any speakers will work, as long as they're the correct size, and IIRC 4Ohm.
    You can replace them with 6.5" speakers, the best way to do that is slice out the inside or the original cone, and install your new speakers into the OEM door speaker housing.
    My respray thread
    May 06 2017
    Sofia
    180w peak power for all the speakers or only front ? Can i put 4x60W rms speakers ?
    Oct 24 2015
    Perth, WA
    Yes, for the whole amp. Thats current draw at 12V, = 15A. Thats when the fuse blows, so its actually less. Then you take what, 30% off for electrical losses and you have your power at rms essentially. The amp and RNSE probably each output at the speakers a max across all four at 100W, or 50W per speaker. I would get bigger. What is your budget.
    My respray thread
    May 06 2017
    Sofia
    I want to get in 150 euro for speakers.Not more.Im not a big fan of loud music but i want something that have good qualitty and power.yesterday i was at local shop here and liked Hertz models.50 euro for two hertz speakers is a good price.But this is only the front.For the back do i need aftermarket amp ? Or i can use oem one ?
    Oct 24 2015
    Perth, WA
    Just replace all 4 with new speakers. Dont change the wiring or amp in your case.
    My respray thread
    May 06 2017
    Sofia
    Today i saw that my car is missing the Subwoofer on the back and back speakers too.Now its have only Hole in the top of the trunk.Tommorow i will remove some stuffs around the hole to try find the wires.What is the best for me now ? To put the original subwoofer for 60euro or to buy something aftermarket ? I dont know if the back speakers missing or just not play sound because of the missing subw
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    Quote Originally Posted by marto7 View Post
    I'd just connect an aftermarket amp and sub. You can build a basic unit for 130usd and it will sound far better. The cheap hifonics sub sound good and are cheap. Not dummy boomy but good quality sound in a sealed boxed.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    May 06 2017
    Sofia
    Reccomend me a cheap amp. i will find sub and speakers.Every amp that can output 2x60w are okay ? Or i need more ?
    Jun 15 2016
    Northern California
    For the amp, you want a monoblock amp. Do you have sonicelectronix out there in Europe? You can sort by price and look at the reviews there. I bought an amp that was on sale for 60 bucks and pushed 350watts on my voltmeter.
    Jun 15 2016
    Northern California
    Boss is cheap and they over rate their output, but they do work well. Look at planet audio too.
    https://www.sonicelectronix.com/item...s-AR1500M.html
    At the end of the day, you want to measure watts doing into the sub using a voltmeter, not the specs on the spec sheets.
    May 06 2017
    Sofia
    dont i need more channels ? why only 1? Dont rear speakers have power from the amp? In this case i need 2 chanels for 2 rear speakers and 1 for Sub
    Veteran Member Three Rings A4B7Avant's Avatar
    Jun 07 2017
    PA
    How do you measure watts from an amplifier using a voltmeter?
    Quote Originally Posted by StatusQuo View Post
    2019 A4 P+ Brilliant Black, Black Optic, Sports Pkg
    2008 A4 Avant SE Ibis White SOLD
    May 06 2017
    Sofia
    I disasebled some stuffs in the trunk and my amp missing and installation too.I dont know whats happening with this.Now i need new instalattion and amp and woofer
    Jun 15 2016
    Northern California
    Quote Originally Posted by A4B7Avant View Post
    https://youtu.be/gg2gl-fz2Qc
    Jun 15 2016
    Northern California
    Okay if you removed your stock amp, you need a two channel amp. I would have left the stock amp in and have tapped into the signal to the amp and ran a separate amp for the sub.
    Jun 07 2017
    PA
    Ah! You are actually measuring volts. That makes more sense.
    May 06 2017
    Sofia
    Im not sure i understand you.Now I dont have the original amp and subwoofer.The cables that connect radio with the amp is not there too.I need new cables from the RNS-e to the trunk.What is the best option for me :
    - Original Amp and woofer
    - Aftermarket amp with original woofer and aftermarket speakers for the doors
    - Aftermarket everything
    Active Member One Ring Sonic.'s Avatar
    Aug 11 2013
    If you want to do it correctly, here is how you should do it:
    - A proper head unit with front/rear and sub output, I would not use the RNS-e but it's your choice.
    - 6 1/2 component speaker for front door only, no need for rear speakers if running a subwoofer.
    - 2 channel amp for the component speakers
    - mono block amplifier for the subwoofer.
    You dont need new wiring for the front doors, you just need to run rca, sub control wired from front to back , and power wire for the amp.
    Go here caraudio.com and ask for some help about putting together a system in your car and do a bit of reading as well.
    May 06 2017
    Sofia
    Today i bought RNS-E Navigation for only 125 euro.Very good deal for me.Now i want to know how to connect the aftermarket amp to the navigation ? For the Front speakers is easy.But for rear its not mentioned.For front is like Front Right-, Front left + and etc.For rear i think is something like Line line line ... If somebody know please help.
    And can i power 2x60w front speakers with RNS-e ?
