Page 32 of 81 FirstFirst ... 22303132333442 ... LastLast
Results 1,241 to 1,280 of 3213
  1. #1241
    Mar 18 2019
    2018 Q5
    Hi all, looking at Konig Freeform Radium Bronze 19x9.5 +40 offset.
    Will these fit on B9.5 S4 with 100% no rubbing? Looking for square setup using 255/35. No plans to drop now but maybe in a couple of years.
    Brand might be out off place here but just looking for flow formed rims that's not super expensive.
  2. #1242
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by audizzZZzz View Post
    Zero chance for rub Really good specs for stock height too. Just have Konig confirm front caliper clearance.
    Mops on the Move
  3. #1243
    Mar 18 2019
    2018 Q5
    Mops on the Move
    Thanks Mops! It looks like they won't clear the front calipers as per Konig. The search continues.
    How does the 19x9.5 ET40 look on stock height? Any pictures for reference?
  4. #1244
    Sep 28 2010
    NW NC / DE
    Will look pretty much just like this -
    Make sure to check out the VMR V803, V804 and V810 too. They all come in 19x9.5 ET40-45.
  5. #1245
    Veteran Member Four Rings BrockDM's Avatar
    Jan 21 2018
    Orland Park, IL
    Another pic for reference. I was running 19x9.5 et40 on stock height for quite a while, it looks great!
  6. #1246
    Mar 18 2019
    2018 Q5
    I've been checking out the VMR website. Really liking them. Especially I could get them in gold/bronze color. Wanted to have some contrast on my quantum grey. Where can I find a list of their wheel specs like sizes/weight/bore/offset?
  7. #1247
    Mar 18 2019
    2018 Q5
    Quote Originally Posted by BrockDM View Post
    Those are nice BC Forged rims! Looks good even on stock height.
    Any pictures on et45 if ever? Seems most of what I see online are et45 on 9.5 width.
  8. #1248
    Sep 28 2010
    NW NC / DE
    Applicable offerings -
    V810 - 19x9.5 ET45
    V710FF - 19x9.5 ET45
    V803 - 19x9.5 ET45
    V804 - 19x9.5 ET45
    I can go after weights if needed. We're a direct VMR dealer. 👍🏼
  9. #1249
    May 13 2015
    Georgia
    Quote Originally Posted by ass4 View Post
    I did a search but couldn't find anything. Does anybody run 255/35/19 Firestone indy500 on the stock wheels ?
    I hit a pothole today and it seems like I need to change tires now
    I have those tires on my car. They ride great!
  10. #1250
    Mar 18 2019
    2018 Q5
    V810 - 19x9.5 ET45
    V803 - 19x9.5 ET45
    V804 - 19x9.5 ET45
    You have all the answers Mops! Thanks!
    ET45 will push the rims in closer to the struts. Any issues with rubbing and will it work with 265/35 tires?
    Plan to use my OEM 255/35 summers for now but will replace it with 265/35 when worn out.
  11. #1251
    Sep 28 2010
    NW NC / DE
    I do my best.
    No issues at all with 9.5 et45 and 265/35. We done it before and I ran 9.5 et40 on 265 and had a ton of room to spare on the suspension side.
    Mops on the Move
  12. #1252
    Junior Member Two Rings
    Jun 03 2019
    Bakersfield, ca
    Hello all. I'm seeking for some help on wheel fitments. I'm debating on 19s or 20s, but dont feel like having issues with rubbing or what not. I want to go with stance sf07 19x9.5 but not sure if it will fit. Any help will greatly appreciate
    - - - Updated - - -
  13. #1253
    Sep 18 2019
    Montreal
    Quote Originally Posted by Fabre80 View Post
    Yes, I went with the indy500 in 255/35/19. They are so much more quiet then the OEM tires but the sidewall are softer. I'm guessing that going from a "stretched" tire to a more square one that doesn't require 40+ psi doesn't help either for the softness feeling. The grip seems good once the tire is seated and the noise level is lovely
  14. #1254
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Jlaspire View Post
    @Montoya fan
  15. #1255
    Dec 18 2019
    Old lady's W204 C300 4Matic Sport
    VA, USA
    Your oe tires are 255/35? Thought they were 245/35, mine are at least. 245/35 on 9.5 would be beyond recommended stretch.
  16. #1256
    Nov 22 2018
    Arkansas
    Quote Originally Posted by MbagS4 View Post
    Treated myself to these today, unfortunately the tires i wanted wasn't in stock so will be fitted Monday :)
    Got some pics with these bad boys on? They look great with that finish.
  17. #1257
    Nov 03 2016
    CA
    - - - Updated - - -
    Your bigger issue is wether the wheels will clear the front brakes. I bought the correct offset and size, but they wouldn’t clear even with a 10mm spacer.
    Stick to the wheels in this thread or confirm with the manufacturer before buying.
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
  18. #1258
    Mar 18 2019
    2018 Q5
    I do my best.
    Mops on the Move
    Glad to know it's been done before and no issues.
    I'm considering VMR V801 & V803 and Forgestar F14 & CF5V deep concave profile. Will these clear the calipers at 19x9.5 ET40? Seems I can get these all in ET40.
  19. #1259
    Mar 18 2019
    2018 Q5
    Quote Originally Posted by CrazyCanuck17 View Post
    Confirmed mine comes with 255/35 summers as OE tires. Don't know the brand yet as I'm taking delivery in a couple of days.
    Maybe they changed it on the 2020 models? Or maybe it's a Canadian OE spec? Even the base Progressive S4 with upgraded 19's come with 255/35. At least that's what the online configuration says.
  20. #1260
    Dec 18 2019
    VA, USA
    Ah yes, you are correct. 255/35 for the 5y torsio wheels (US also). Also 245/40 and 245/35 for the other two wheel options.
    Where ya at in Canada? I’m originally from Quinte Bay Area in ON. Tempted to move back north, but doubt my lady could handle the cold.
  21. #1261
    Dec 18 2019
    VA, USA
    Why do I find myself looking at wheels every time I drink alone. Still haven’t seen a DG S4 with BCF RZ21 in brushed bronze... maybe it’s time.
  22. #1262
    Mar 18 2019
    2018 Q5
    I'm in Mississauga, ON. You should be very familiar with Sandbanks of you're from Quinte Bay area. Nice place to go to.
    Wifey used to the cold now and lots of fun activities in the winter.😄
    Where ya at now?
  23. #1263
    Mar 18 2019
    2018 Q5
    Do it! I like bronze/gold wheels on gray. Not everyone likes it.
    I had red rims on gray before. Our current Q5 has bronze/black dark tint on black.
    Never liked the plain black/silver rims. To each his own I guess.
  24. #1264
    Dec 18 2019
    VA, USA
    Where ya at now?
    Sandbanks is a nice place indeed.
    Lived in the states most my life... PA, now VA. All my extended family lives in Canada still, and my rents moved back up there years back. Miss going up there in the summers for the cottage/lake life - endless dirt biking, water sports, and camp fires.
  25. #1265
    Dec 18 2019
    VA, USA
    B9 S4 Wheel Gallery
    So tempted. Plan was to get some apr wheels in silver (primarily due to a slick deal through a friend, still waiting). Run those with as3+ in winter. Sell stock rotors.
    Then get 19x9 et36 RZ21 in bronze. Maybe even run staggered profiles, get some good concavity in the rear!
    Kinda paranoid about dropping 3k+ on wheels though. One nick and my attitude would quickly become... “throw em in the trash!”
  26. #1266
    Jul 30 2020
    Winnipeg, MB
    Good day gentlemen, anyone here ever heard o Euro Design by YKW Wheels? YKW Wheels seem to be a distributor company sourcing wheels from factories in Thailand and Malaysia. Recently acquired a used 2018 B9 S4 and is looking at options for a winter setup.
  27. #1267
    Mar 18 2019
    2018 Q5
    I say just keep the stock for winter and go get the BCFs!
    I hear ya man, I was thinking of BC Forged as well but even without curbing the rims, I know it'll still get nicked from daily driving. Really hurts to see that, if I dropped that much for rims.
    So I finally took delivery of my S4. Now I'm really on the fence on which wheels to get as I will be using my stock 19's for winter.
    I'm thinking maybe stay with 9 inch rims to get more side wall / rim protection using OE 255/35. But I don't know if 265 will look good on 9 inch rims when it's time to replace. I like more meaty tire look.
    I was considering VMR but they only come in 8.5 and 9.5. decisions decisions....
  28. #1268
    Dec 18 2019
    VA, USA
    B9 S4 Wheel Gallery
    Took me a minute. You are swapping the stock tires to the new rims I take it? Personally I’d buy the rims and tires you plan on running for the nice summer set, don’t let the one set of oe tires adjust that. Sell the oe tires. Probably better off running the oe 255’s on 9.5 rim and going 265 tire later, than the other way around. Your sidewall height would still be equivalent to my stock 245/35 on 8.5 with a slightly stretched 255.
    In regard to 265/35 on 9. Guess it depends on the tire somewhat too. Haven’t seen many 265 on 9 in this thread, but 255 on 8.5 isn’t uncommon. Will stand your sidewall up a bit, which looks fine IMO with 255 on 8.5. Not sure if the larger sidewall from a 265 combined with a step down in rim width will be too much though.
    Pics of the fresh S4?
    Side note, can speed calibration be adjusted with vcds to compensate for these effective circumference changes?
    *edit... cut out my late night rambling.
  29. #1269
    May 02 2019
    SF
    Any pics of 18x9.5 et45's?
  30. #1270
    Mar 18 2019
    2018 Q5
    Yup I'm swapping the stock tires on the new rims. I thought about selling the OE tires but not sure how much I'm going get for it so planning to just keep and use it. Will the ride quality be compromised with a stretched 255 on 9.5?
    Car is still in the shop for ceramic coating. Dropped it off the same day I picked the car. Will share pics when I get it back tomorrow 🙂. I miss the car already... Lol
    As for calibration, my understanding is if you're around 1% difference in circumference changes, then shouldn't matter isn't it?
    Lol! What late night rambling?
  31. #1271
    Dec 18 2019
    VA, USA
    B9 S4 Wheel Gallery
    Car is still in the shop for ceramic coating. Dropped it off the same day I picked the car. Will share pics when I get it back tomorrow . I miss the car already... Lol
    Guessing you’ll get at least half the oe tire price back out of them. Common enough size to reasonably find a buyer.
    Personally, I plan on running 255 anyways, even if I got custom wheels. 265 adds around 3 lbs from 255, not sure if most tires see that increase (I was comparing as3+ weights). Significant considering its full distance from the rotation axis. Get light rims to save about 7lbs, then seems counter productive to add 3lbs back while only gaining 1cm width. Others are likely to disagree. I too like a meatier tire, the stock 245/35 tires on my ‘19 look thin to me.
    For what I plan on doing, change in circumference is minimal. More than 3% I’d be more inclined to figure out how. Just wondering if anyone had found the setting. I have access to latest vcds, might just adjust to have it exact anyways.
    My previous post was a bit longer before cutting... have the tendency to go on too much detail and mildly off topic when I’m bored and on this forum.
  32. #1272
    Dec 18 2019
    VA, USA
    B9 S4 Wheel Gallery
    *deleted* - question already answered prior.
  33. #1273
    Mar 18 2019
    2018 Q5
    Finally here she is. Crappy picture. Wife took the picture as I've been asking her to drive it around first to break-in. I'll have to get better shots when the weather is better. Just tints and ceramic coating so far.
    OEM 10 V-Spoke rims
    19x8.5 ET40
    255/35 ContiSportContact 5P
    So I've scoured through this thread and except for winter set-ups, a track set and a BBS rim in 18's, it seems no one else is running 18"s as summer/all season setup. Is it because of aesthetics or fit? Preference maybe?
    For my Summer/All-season set, here's what I'm thinking:
    1. 18x9.5 rims on 265/40 (or crazy 295/35?)
    2. 18x9 rims on 255/40
    Probably will go with DWS06.
    Would ET40 or 35 work with no rubbing in both configuration?
    For my winter set-up:
    1. 18x8 rims on 225/45 (can't find load rating of 96 and up yet in this size)
    2. 18x8 rims on 235/45
    3. 18x8.5 rims on 245/40
    Will probably go with Conti Viking 7.
    What would be a good offset in these configurations?
    Sent from my Pixel 4 XL using Audizine mobile app
  34. #1274
    Dec 18 2019
    VA, USA
    B9 S4 Wheel Gallery
    OEM 10 V-Spoke rims
    19x8.5 ET40
    Aesthetically 18” is a small rim on this car IMO. What’s the main motivation to run 18” year round?
  35. #1275
    Mar 18 2019
    2018 Q5
    Here's another shot from yesterday.
    Motivation for going 18"s
    - I like the chunky tire look
    - more sidewall means better protection for rims and probably a smoother ride
    - maybe more tire and rim choices that will not rub
    - potentially less unsprung weight depending of rim/tire combination
    I know looks are subjective but with the right offset and rim, I think it will still look good. That's why I wanted to ask if anyone has any pictures for reference as well.
    I think some S4's have OEM 18's.
  36. #1276
    Dec 18 2019
    VA, USA
    I hear ya on the meatier tires, I was never a fan of super thin. Definitely understand wanting to run 18” with a big sidewall up there in Canada during the winter! Was surprised ya wanted 18” for summer tho... to each their own, and roads probably aren’t great in general given the harsh winters.
    I haven’t seen many folks posting 18” in the numerous times I’ve scanned this thread. Hopefully a few folks can chime in with some photos! Wonder if 18” is hard to find wheels that work given the big front calipers - I’m intrigued.
  37. #1277
    Veteran Member Four Rings z_wrecker's Avatar
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    Fresh from a refinish. Some S5 rotors
    2018 Alfa Romeo Giulia Quadrifoglio
    2014 Arctic White B.O. S5 Prestige manual w/ sports diff
    2002 Arctic Silver Metallic Boxster manual
    2018 Daytona Gray Q5
    2018 Daytona Gray B.O. S4 -Sold
    2009 Pearl White Ducati Monster 696 with Termi race kit, and a bunch of CF -Sold
    2008 Ibis White A4 s-line manual -Sold
  38. #1278
    Sep 28 2010
    NW NC / DE
    Damn Z
    Mops on the Move
  39. #1279
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    Damn Z
    Mops on the Move
    Thanks Ben. I was going to do satin black like we talked about, but then I picked up those satin black CH-R’s so I figure I’d go little darker gunmetal. Now I need to get some black center caps and I’ll be set.
  40. #1280
    Jan 21 2018
    Orland Park, IL
    Wow love that color! Great tire choice as well
