Results 1 to 12 of 12
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Battery Tender Hook up Question
    Looking to hook up a battery tender to my 2014 S4 but have a lame easy question. The positive is easy to find under the cowling cover, but is the negative connection really that silver bolt on the coil over with a - sign on it? Again, stupid question but then this is my first German car and things have to be different...
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    Yes. That is the recommended location per the manual. I've used a Battery Tender at those connection points without incident.
    Current: 16 VW Tiguan R-Line 4MO, 15 VW GTI PP, 14 Audi S4
    Retired: 12 VW GTI, 10 Audi S4, 08 VWJetta Wolfsburg, 04 Audi allroad 4.2, 04 VW Jetta, 03 Audi A4 3.0
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    Mar 06 2015
    Columbus, Ohio
    Thank you!
    Junior Member Two Rings
    Apr 20 2012
    NoVA
    The other option is to use a short extension cable to the battery directly in the trunk. I have the cable wired in and then can leave it plugged in to the charger with the trunk closed (I put a protective cable cover around the section that the trunk lip is pressing on). With the quick disconnect its a breeze and worst case, if I ever forget to unhook it, it comes off with very little effort.
    Apr 04 2012
    MSP
    I ran one out of my trunk. Just a pigtail that I ran up to the trunk floor... when connected the trunk still closed without issue.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Oct 06 2014
    Cleveland, OH
    What battery tender (or similar product) is recommended for our cars in storage over the Winter? The Battery Tender website has several offered, all with different AMPS.
    Also, as listed in this thread, are people attaching the leads to the battery in the trunk or some access point under the cowling?
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by SR7D1 View Post
    I suspect it's probably easier to attach the Battery Tender to the connection points under the hood, but that connecting it in the trunk would also work. That said, I happen to have a 1.25 Amp Battery Tender Plus (Model 021-0128) that I no longer need. I used to use it on my '85.5 944 and my 2004 R32 when I put them in storage for the winter months. They're both gone now and we're down to our S4 as our sole daily driver, and not planning to acquire any toys to occupy the other half of the garage. If you want the Battery Tender I have, it's yours (at no cost). I'm in the Canton area but get up to Cleveland fairly often (mainly for Heinen's trips). Alternatively, you can pick it up down here at your convenience. Send me a PM if that works for you.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Feb 10 2013
    Orlando
    I use the engine bay terminals with a CTEK Multi 3300 charger that was recommended to me.
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Using CTEK as well in engine bay. Only issue is I must leave the hood opened a bit so the cable doesn't get squeezed too much
    Murdered B8.5 S4
    Build Thread
    Active Member One Ring Mongoose's Avatar
    Oct 29 2012
    IA
    Quote Originally Posted by infinkc View Post
    I use this same setup - works great.
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    I did the simple mod to make the 12v socket in the ashtray permanently live, based on this guide.............
    https://www.audizine.com/forum/showt...it-s-always-on
    Then I use a CTEK type smart charger (actually a "maypole" ) plugged in to that.
    Very convenient, works perfectly. Shut the door on the wire, lock the car and no issues.
