Originally Posted by
Mobileguy
I realize that removing cats is their recommendation but I disagree that it is not "their problem" if this turns out to be a broader issue. As per my earlier post, I have not been pushing the car at all and if that is all it takes to blow your cats, they should not call it a "recommendation" but a clear "requirement". In any event, at this point all of this is speculation because if my cats are in fact failing - it could just be because I am that unlucky guy whose cats would have failed anyway... I guess we will see over the next year how many others have problems with their cats on an ultracharged car.
It's likely not a requirement because the car will function with stock cats. But when pushed hard, they have the potential to fail.
A requirement would entail something that is, well, required. For example, the APR Ultracharger tune is required in order for your car to start after installing the throttle body. If you don't flash that UC map, the car will fail to start, therefore it's required. An inverse example might be: you can run the stock ECU map with an aftermarket supercharger pulley installed. The aftermarket map is not required in order for the car to run, but why wouldn't you flash it?
I'm pretty sure you signed something when you had this setup installed as well, acknowledging the risks and confirming you were aware of the requirements and recommendations. I know I had to sign something when I was flashed with APR software.
From APR's view, they released all these updates and said "Hey this stuff works, but we strongly recommend that you don't run it with factory cats". Everyone then said "Ok, got it, but I'll try it anyways.". Fast forward a few months, and people are magically dumbfounded that their cats are suddenly failing, blaming APR. We can argue about the semantics of "required" vs "recommended" all day, but the fact is they told everyone up front.
I know there have been a few cases of cats failing recently, some on Ultracharged cars and some not. As Thurston pointed out above, even stock cars have had cats fail. It is an unfortunate position to be in, but it comes with the territory, and a quick call to Evan Doel for some test pipes should fix things up rather quickly for you.
When you're pushing 500hp on a tuned car, you gotta pay to play.
