So, after a little research here, I assumed I have the old tensioner and I should replace it. Well, let's do the entire timing if I'm in there. So, I ordered all 3 chains, all the rails, the tensioner and all tty bolts. The lower cover, all the gaskets....blah blah blah.
But what if the oil pump is bad? So I got that too.
So, I took it all apart and the screen on the cam bridge was in the oil galey down there, completely broken. But in one piece and not spread throughout the engine. And I ordered a cam bridge.
And this is where the questions start: the old bridge bearing on the intrake side has some scoring on it. The cam is not bad, but it has some scoring on it as well.
If I install the new bridge on the old cam, how long or how little can I expect any one of them to last for?
Here are some pics.
Oh, car has 270000kms on. At 145k previous owner had stage 2 oil consumption (pistons and rings) done. And a new style chain tensioner installed. Not sure about chains, rails, cam bridge etc.
Sent from my SM-G950W using Tapatalk
