Results 1 to 19 of 19
    Veteran Member Four Rings cu52's Avatar
    Dec 11 2008
    Denver Metro
    Looking at a 04 S4. Lots of codes... Purchase at what price? or Run?
    EDIT! I bought the S4! Now troubleshooting will start.
    I am looking at a 2004 S4. I expected the codes to more clearly show timing issues but I am not sure what specifically they are showing. Was hoping for some help here. Car is fairly cheap and before I make any offers I need to know what kind of cash I might be throwing at this to get it running right. Interior is very nice, exterior is 6-7 of 10. and has low miles.
    Engine runs rough, CEL on, if rev'd at all CEL is flashing.
    Not scared of an engine pull or replacing timing components which is why was looking at this car. Possibly some electrical harness issues?
    Thanks in advance!
    VIN: XXX License Plate: NEW
    Mileage: 144120km-89552mi Repair Order:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: XXXX Mileage: 144120km-89552miles
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 A HW: 8E0 907 560
    Component: 4.2L V8/5V G 0020
    Coding: 0007711
    Shop #: WSC 22163 444 54161
    VCID: 235B3EA8E1ABF359D4-50E6
    16 Faults Found:
    16725 - Camshaft Position Sensor (G40)
    P0341 - 004 - Implausible Signal - MIL ON
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - - MIL ON
    16685 - Cylinder 1
    P0301 - 001 - Misfire Detected - MIL ON
    16692 - Cylinder 8
    P0308 - 008 - Misfire Detected - Intermittent
    16687 - Cylinder 3
    P0303 - 001 - Misfire Detected - MIL ON
    16592 - Injector: Cylinder 8 (N86)
    P0208 - 004 - Circuit Malfunction - Intermittent
    16585 - Injector: Cylinder 1 (N30)
    P0201 - 004 - Circuit Malfunction - Intermittent
    16588 - Injector: Cylinder 4 (N33)
    P0204 - 004 - Circuit Malfunction - Intermittent
    16589 - Injector: Cylinder 5 (N83)
    P0205 - 004 - Circuit Malfunction - Intermittent
    16587 - Injector: Cylinder 3 (N32)
    P0203 - 004 - Circuit Malfunction - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    16688 - Cylinder 4
    P0304 - 001 - Misfire Detected - MIL ON
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
    P0106 - 008 - Implausible Signal - Intermittent - MIL ON
    17538 - Fuel Trim; Bank 2 (Mult)
    P1130 - 001 - System too Lean - MIL ON
    17535 - Fuel Trim; Bank 1 (Mult)
    P1127 - 002 - System too Rich - MIL ON
    17546 - Fuel Trim: Bank 2 (Add)
    P1138 - 001 - System too Lean
    Readiness: 0000 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 Q
    Component: ABS/ESP allrad 3033
    Coding: 04595
    Shop #: WSC 06435
    VCID: 367DF7FC123976F103-515A
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-10 - - - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 00000
    VCID: 63DB7EA8F12BB35994-515A
    2 Faults Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    41-10 - Blocked or No Voltage - Intermittent
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 01013
    Shop #: WSC 63351
    VCID: 357FF0F00F3F7DE90A-4B00
    3 Faults Found:
    02104 - Light Detection Sensor (G399)
    29-10 - Short to Ground - Intermittent
    01753 - Windshield Wiper Motor (V) Stage 1
    31-10 - Open or Short to Ground - Intermittent
    01754 - Windshield Wiper Motor (V) Stage 2
    Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
    Part No: 8E0 035 593 A
    Component: SDAR XM 0010
    VCID: 27432AB8C5931F7988-50E6
    2 Faults Found:
    00003 - Control Module
    37-10 - Faulty - Intermittent
    02635 - Tuner Not Enabled/Activated
    35-00 - -
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    Shop #: WSC 63351 000 00000
    VCID: 3F9392D86D03B7B9D0-51D0
    1 Fault Found:
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 01041
    Shop #: WSC 63351
    VCID: 3E6DEFDC3A09BEB1DB-4B00
    1 Fault Found:
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 980 M
    Component: KOMBI+WEGFAHRS. RB4 D37
    Coding: 03200
    Shop #: WSC 22163
    VCID: 367DF7FC123976F103-50E6
    WAUPL68E54A140275 AUZ6Z0C0280891
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760
    Component: Sitzmemory R2 F 0305
    Coding: 00002
    Shop #: WSC 63351
    VCID: 71F704E03BD711C916-4B64
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    79-00 - Please Check Fault Codes
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.clb
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72F50BEC3ED12AD1EF-4B00
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0004
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0004
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0004
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0004
    15 Faults Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Rear Right
    35-00 - -
    01366 - Opened Due to Crash Signal
    36-10 - Open Circuit - Intermittent
    00955 - Key 1
    00956 - Key 2
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01333 - Door Control Module; Rear Left (J388)
    01561 - Rear left door
    59-10 - Can't Unlock - Intermittent
    01334 - Door Control Module; Rear Right (J389)
    Address 55: Headlight Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    VCID: 04195D3414651461CD-4B64
    1 Fault Found:
    07-10 - Signal too Low - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 H
    Component: symphony II NP2 0400
    Coding: 01220
    Shop #: WSC 87552
    VCID: 2C49D594DC753C2165-5072
    1 Fault Found:
    Address 75: Telematics Labels: 8E0-035-616.lbl
    Part No SW: 8E0 035 616 A HW: 8E0 035 616 A
    Component: Telematik USA1
    Coding: 0005003
    Shop #: WSC 00000 785 00200
    VCID: 235B3EA8E1ABF359D4-515A
    3 Faults Found:
    01656 - Crash Signal
    004 - No Signal/Communication - Intermittent
    01531 - Emergency Battery
    002 - Lower Limit Exceeded - MIL ON
    13 Tundra SUPERCHARGED
    01 B5 S4 Avant, C5 RS6, 18 SQ5
    Gone:
    03 RS6, 01 605 Tial Avant, 00 S4, 01 S4 Avant, 01 Imola, 00 Hibiscus, 04 4.2L Allroad 6 speed swap, 03 allroad, 04 Audi Allroad 6MT 2.7T ST3!, 04 Allroad TIP, 02 Allroad MT6 2.7, 08 Toyota Sequoia, 04 Audi S4 MT6, 01 S4 Casablanca White 6MT , 04 VW GTI 5MT, 03 A4 Avant 3.0 6MT, 09 Tundra CM, 11 Tacoma DC, 02 A4 Avant 3.0 Tip, 01.5 S4 Avant tip GIAC stage 3-, 00 S4 6mt
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    I'll let some of the S4 guys chime in, but cam position sensor and multiple cylinders misfiring could be timing. Although I'm guessing the motor and exhaust would sound a little off if the timing was off
    Dec 11 2008
    Denver Metro
    Quote Originally Posted by b7_Andy View Post
    Forgot to mention engine is running rough, CEL on, if rev'd was flashing. Will put that above! Thanks.
    Sent from my VS988 using Audizine mobile app
    Gone:
    Jul 18 2015
    Sounds like it could be timing. I've seen in some cases where there's codes for cam position sensors on chain driven motors and the car acts like the timing is bad, but it's just electrical or a bad sensor and that fixes it. For me the biggest sign is if the exhausts sounds different from what it should. I know that sounds weird but if the timing is off it will cause the car to make a different noise as opposed to just a bad sensor that's causing a few misfires.
    Veteran Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    I'm with these guys...sounds like timing. Cost could be $3k - $10k depending on what TC service kit you buy and who does the labor (you or shop). Got any pics of the car?
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Quote Originally Posted by cu52 View Post
    the flashing CEL is misfires.... It seems like there's quite a few gremlins in this guy... doing the timing service and replacing the mechanical adjusters would definitely solve some of the issues. There are some of the other codes that I'm not too familiar with... if you're going to buy this car I would not run it until you complete the timing service... you will also likely have to replace the valves because they're probably bent... I would do a compression test and see what type of compression you get... although with bent valves it won't tell you what kind of shape the cylinder walls are in.
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    if you can get it for a song then i would fix the obvious electrical issue before diving into the timing. new battery, check grounds, check relay harnesses, replace engine-related relays, check ECU harness, and check the coil pack harness.
    - emilio
    Vorsprung durch Service Position
    Buy shirts & help me buy tires!
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    did you try clearing them all and resetting everything. then start it up again for a bit and see what pops up. half of those could be as simple as the battery got low and bad coil packs, or indicative of much larger problem(s)
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Dec 11 2008
    Denver Metro
    I did not reset the codes. Going to take a chance on working a deal, hope to finalize in the next 2-3 hours and will go from there and see what happens! Will keep everyone posted.
    Gone:
    Jul 18 2015
    Quote Originally Posted by badger. View Post
    I agree with this, a lot of those codes look like they came up due to low voltage at some point. I'd try clearing them and seeing if it runs any different.
    Dec 11 2008
    Denver Metro
    Alright I bought it. I could part it out if the costs get too crazy based on what I paid and come out ahead.
    Before I can go crazy and try to figure thus one out I need to finish my stage 3 allroad. Hope to be done next week with that!
    This S4 has 89K miles
    6 speed manual
    Clean title
    2 keys
    Aftermarket exhaust
    Bilstein coilovers.
    Dent in driver fender and a couple in the driver door.
    And lots of CEL codes!!
    Gone:
    Veteran Member Three Rings jhoward's Avatar
    Dec 13 2012
    central NY
    I was going to say offer them $5k or so. Did you get a steal?
    Dec 11 2008
    Denver Metro
    Quote Originally Posted by jhoward View Post
    I think so, what would you call a steal?
    That said what is the best way to remove Tar that that has baked in the sun? Without ruining the paint?
    Sent from my VS988 using Tapatalk
    Gone:
    Dec 11 2008
    Denver Metro
    Cleared all codes. Started up and ler if run for a minute or so. Here are the new codes. Removed all sections with no codes to shorten the post. Ran ok at first, the. Rough, guessing due to miss fires. Car has 3 more coils (used ) and 1 (new) camshaft sensor in the trunk.
    Also gas cap issue? Gas light is blunking on the screen where it normally tells me a door is open.
    Address 01: Engine * * * *Labels: 079-910-560-BBK.lbl
    * *Part No SW: 8E0 910 560 A * *HW: 8E0 907 560*
    * *Component: 4.2L V8/5V * * *G * 0020 *
    * *Coding: 0007711
    * *Shop #: WSC 22163 444 54161
    * *VCID: 235B3EA8E1ABF359D4-515A
    4 Faults Found:
    16725 - Camshaft Position Sensor (G40)*
    * * * * * * P0341 - 004 - Implausible Signal - MIL ON
    16684 - Random/Multiple Cylinder Misfire Detected*
    * * * * * * P0300 - 001 -*
    16685 - Cylinder 1*
    * * * * * * P0301 - 001 - Misfire Detected
    16687 - Cylinder 3*
    * * * * * * P0303 - 001 - Misfire Detected
    Readiness: 0110 1101
    Address 0F: Digital Radio * * * *Labels: 8E0-035-593-XM.lbl
    * *Part No: 8E0 035 593 A
    * *Component: SDAR XM * * * * * *0010 **
    * *VCID: 27432AB8C5931F7988-50E6
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated*
    * * * * * * 35-00 - *-*
    Address 75: Telematics * * * *Labels: 8E0-035-616.lbl
    * *Part No SW: 8E0 035 616 A * *HW: 8E0 035 616 A
    * *Component: Telematik USA1 * * *
    * *Coding: 0005003
    * *Shop #: WSC 00000 785 00200
    1 Fault Found:
    01531 - Emergency Battery*
    * * * * * * 002 - Lower Limit Exceeded - MIL ON
    End-------------------------(Elapsed Time: 05:22)--------------------------
    Gone:
    Jul 18 2015
    I use a 3" buffing pad on a drill with some compound to remove tree sap and tar from paint. It's pretty forgiving and hard to screw up. And then just use an orbital buffer to polish out any swirls left behind. Have you cold-started the car yet? A chain rattle on cold start would definitely indicate the timing is bad. Otherwise I hope it's just a sensor and coils, that would be nice! Also it seems you've picked up some pretty sweet Audi's recently including this one... I'd like to come check them out one day! Will the Allroad be running soon?
    Jul 05 2016
    Ontario, Canada
    Look up the guy from AMMO. NYC on YouTube. He might have a good method.
    Other than that maybe try WD40. I used to sell it to a company that made ashphalt shingles it would emulsify the ashphalt. Might work with the tar.
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Dec 11 2008
    Denver Metro
    Will be re-assembling engine and transmission tonight, working on piggie pipes and then hopefully going to get the engine back in the car over the long weekend depending on plans with the kids. I work in Denver so we will have to connect one day once I have it up and running!
    Really hoping the sensor and coil swapping solves the issue on the S4. If so then I def. Stole it.
    Gone:
    Feb 18 2014
    Arizona
    I've used a product specifically sold for removing tar, found near the car washes and waxes in the store, that worked great to remove it. I'm sure you could use some other solvent like wd40 or anything that's not too harsh for paint
    Dec 11 2008
    Denver Metro
    Thanks all, I am actually thinking it is sap that has hardened and turned dark brown. That might be a but harder to get off. Will try some water destroyer in a couple spots tonight.
    Gone:
