Results 1 to 30 of 30
    Junior Member One Ring
    Feb 04 2015
    Berwyn PA
    Allroad 4.2 won't restart when hot
    I have a 2004 Allroad 4.2L Problem I’m having is that after running it at highway speed for a period of time, say an hour or more, if I shut the engine off for s short period of time (say at a rest stop) and then try to restart it, it won’t start until I wait for an unspecified period of time, anywhere from a couple of minutes to 20+ minutes. All the dash lights come on, there’s a slight click but it doesn't crank. I keep trying every minute or so until suddenly, voila, it suddenly starts right up.
    I don't have this problem if just driving and stopping around town.
    Saw some blogs that pointed to a bad coolant temperature sensor but dealer said not that as even if it was bad the engine might not start but it would at least crank. Is that correct and if so does anyone have any other ideas? This used to happen just periodically but now it happens almost every time.
    Thanks
    Sep 16 2010
    Central Wash
    Nope. That's not it. There are very few sensors that affect the mechanical/electrical ability to start the car, or crank the engine.One of them is the Crank position sensor. When they start to fail they tend to fail more when they're hot. Once it cools off it'll work again. USUALLY you'll get a CEL and error for 'intermittent' failure of that sensor.
    If you have a way to check for errors do that first.
    Otherwise some other things, like the starter, can fail more when hot. But that's going to take some diagnosis..
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by rollerton View Post
    ...other things, like the starter, can fail more when hot...
    ^^ My bet is on the starter, based on the symptoms quoted. Should be easier on the V8 vs a 2.7T ...
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Senior Member Two Rings mr_dave's Avatar
    Apr 20 2013
    C5 RS6
    MN
    Starter.
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    I would clean battery contacts and follow main grounds/power wire. Then pull the starter and open that bad boy up and check it out. Throw it in a growler if you can and test the solenoid. Check the commutator and brushes. Or just get a new one and call it good. After cleaning contacts :)
    Check your coolant temperature sensor. Replace with a new green plug type and try it.
    Quote Originally Posted by kRussia View Post
    Sorry didn't read enough about not cranking. Disregard
    Feb 04 2015
    Berwyn PA
    Thanks for the reply but curious why the starter would act funky only in those specific situations when the car has been running at speed but never at any other time ?
    Nov 14 2011
    NW
    Can't say for sure, but perhaps solenoid contacts can't close due to heat.
    The brushes, commutator, core/windings and all that seems less likely to be causing the issue. Mayyybe the brushes have had a bad time with the commutator but that makes little sense in this situation. Pretty easy to find out..
    Maybe lacquer has degraded and causes a short if expanded.
    It's a hard question to guess but if it's a certain speed it may be the frequency of vibrations causing it to heat up^.
    Kinda impossible to guess
    Feb 01 2017
    NoVA
    For some reason on my S6 4.2 (timing belt engine) I have found that a hot or warm start has less issues when I turn the ignition key to the 'on' position for a couple of seconds before turning it to start the engine. I'm wondering if it's kind of like an old hot/warm start issue on Porsche 914s where there is kind of a vapor lock due to the engine heat...
    Give this a try and it may help.
    Nathan
    ____________________________
    '19 SQ5
    '64 356 SC 1720
    '73 914 2.8 6-cyl conversion in progress
    ‘02 S6 Avant - gone to a new owner to live up to it’s potential as a 6-speed
    RIP (tree) ‘99.5 A4 2.8 Quattro Tip - GIAC engine and tip chip, Stage 3 MAF mod, A8 front rotors
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    My bet is that it’s the Crank Reference Sensor.
    Mine exhibited the same symptoms before it flat out died. Not an overly costly part but kind of a pain to get to, so I had my indy do it.
    Current: 16 VW Tiguan R-Line 4MO, 15 VW GTI PP, 14 Audi S4
    Retired: 12 VW GTI, 10 Audi S4, 08 VWJetta Wolfsburg, 04 Audi allroad 4.2, 04 VW Jetta, 03 Audi A4 3.0
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    ^ this, and/or the fuel pump is starting to give up the ghosty
    either one can leave you stranded
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Jun 10 2013
    United States
    Original Poster says the starter is not starting. You need to diagnose the circuit. The starter needs power and the starter solenoid needs power. Sounds like a starter or wiring issue.
    Jun 07 2005
    Shepherdstown, WV
    fuel pump or CPS would be a crank but doesn't actually catch situation, this seems to be related to the starter or ignition switch like glennda5id is suggesting since OP is saying it doesn't actually crank.
    IF it's cranking, for some reason people seem to always say it doesn't crank but it actually is, then CPS would probably be first place to check since that is a common part to work cold but not hot.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    May 20 2010
    Sounds like the same exact issue going on over here: https://www.audizine.com/forum/showt...6#post13073006
    Could be the starter in that case. Might not be making contact anymore when it gets warm.
    However, I'd start with the grounding. There's a grounding bar at the battery, and sometimes those bolts corrode, giving you a bad connection. Getting hot and expanding the metal could do that if the bolts are corroded there.
    I had a similar one-click and thought it might be the starter motor, and it turned out to be one of the engine grounds by the passenger engine mount had gotten corroded.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Veteran Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    Stage 2 C7 A6, Tahoe for the kiddos
    SLC, UT
    Sounds like a crank position sensor to me.
    Jul 25 2016
    1995 Land Rover Discovery
    Missouri
    +1 for crank position sensor.
    Sep 28 2009
    suburb
    ever find out what the prob was?
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Established Member Two Rings Watcher0691's Avatar
    Jul 20 2017
    2013 Audi A4 2.0T Quattro, (2) 2001 A6 2.7T Quattro, Dodge Stratus R/T full sub 510 cu.
    Ozark Missouri
    Quote Originally Posted by audicary View Post
    Starter Windings have a short to ground. When you start the car in the morning (or for several hours) everything appears normal. After running for a period of time, you shut off, try and restart, and hear a click!
    That is caused by the break in the winding expanding as the engine and engine compartment temperature (heat soak) reaches a point where the current from the battery will take the path of least resistance. Instead of jumping the gap on the broken winding, the current finds a better path with little resistance, starter motor housing!. Don't confuse this with a no-crank condition in which you don't hear a click, with a fully charged battery. That is primarily caused by a bad ground condition. For those old enough to remember, the 1968, 69, 70 Corvette big block motors experienced this same issue until GM engineers figured out that it was a heat issue and put a heat shield over the starter. problem solved!
    Watcher
    Sep 28 2009
    suburb
    My 2.7 just had this. It was a 10 dollar fix with new battery ground strap.
    Audi SQ7
    Audi B8 S5 (gone)
    Established Member Two Rings kwaceyoopony's Avatar
    Jan 03 2017
    Bothell, WA
    I had this problem on my 4.2L it ended up being the engine speed sensor
    Feb 04 2015
    Berwyn PA
    As an update to my earlier post, I have replaced the starter, the coolant sensor, the battery and fuel pump. The other day doing errands around town on a hot (90+ degrees) and humid day, and after my third stop, each stop consisting of no more than 5-10 minutes driving in between stops of equal length, the problem arose again. it wouldn't start right away, but after trying once every minute or so, it started after 5 or so minutes. Then again after my fourth stop. So it seems like I'm back at square one except it doesn't just take driving at highway speeds for an extended time, it can happen after a limited time of driving in hot and humid weather. Still looking for clues so if anyone has any other ideas on where to look please feel free to suggest
    Sep 28 2009
    suburb
    check your engine and battery ground strap
    Audi SQ7
    Audi B8 S5 (gone)
    Dec 10 2013
    Borden, Ontario, Canada
    At that point, crank sensor. It's right there on the driver side above the axle approx. The plug is behind coolant expansion tank and the sensor is held in with a 10mm bolt. Takes all of 15mins to change and you wont have hot start issues anymore
    Sent from my SM-G935W8 using Tapatalk
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Feb 04 2015
    Berwyn PA
    Do you have to remove the coolant expansion tank to get at it ? And is it connected into the firewall? Thanks
    Active Member One Ring kicker's Avatar
    Feb 05 2019
    NZ
    So is it the starter that still isnt cranking on occasion when hot?
    I had a faulty crank position sensor, it gave a G28 implausible signal DTC and it wouldn't start when hot BUT it would crank non stop without firing if you wanted to. If it is your CPS, with the problem present the rpms will show as zero when cranking, you can watch the tacho but an OBD2 device will be easier as cranking speed is a lot lower than idle.
    It sounds like yours is still a heat soak problem but if the starter isn't cranking then you should check that first. Earth strap, wiring, solenoid, starter motor etc
    Feb 04 2015
    Berwyn PA
    Have replaced the starter, fuel pump, the coolant sensor, and the battery. Supposedly the tech checked the battery straps. Problem only happens when the car has been running awhile at highway speed and then I stop, e.g. at a rest area. All lights in dash come on but car does not crank. After trying occasionally for awhile it starts right up. Never a problem otherwise. My simple mind thinks something either expands when hot to create a break in current to starter, or engine thinks it is over heated and prevents connection as a safety
    Dec 10 2013
    3 bolts and it swings out of the way
    IG: 24_et
    Sold:
    RIP:
    Feb 04 2015
    Berwyn PA
    ok thanks
    Oct 30 2009
    Miami, FL
    What kind of starter did you put in? It really sounds like a bad starter and you should never assume the new part you just put in is good. Anecdotal evidence, but I've seen a few brand new supposedly quality brand parts fail soon after installing, a starter being one of them. The starter circuit is really simple, it would still turn over with no ecu whatsoever. If you want to be sure you can check for 12v at the starter solenoid connection when it's refusing to start, but that's easier said than done.
    2018 S5 Coupe - stock for now
