Results 1 to 40 of 52
    Mar 18 2013
    States
    what kind fuel you would use in 2.0T
    I use Chevron 87/89 most of time, 80% is city driving
    Jan 02 2011
    2018 4M Q7, 996 Turbo, 2014 Q5 3.0T
    MN
    91+
    Like the cap & manual indicate
    2018 Audi Q7 3.0T: Glacier White Metallic/Black, Prem +, Driver Asst. Pkg, Vision Pkg, 20" 10-spokes - Dadwagon 3.0
    2014 Audi Q5 3.0T: Moonlight Blue/Black, S-Line, Sport Interior, Nav, Adv Key, VAG-com's, 034 Intake tube Wife's Daily Driver - Momwagon 3.0
    2001 996 Turbo: Black/Black, Tip, Diamond Black BBS RS-GT's - Summer Car
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Shell 93 V-Power NiTRO+ only for me :)
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    May 12 2011
    Norway
    gasoline, i would never use diesel.
    Audi Q5 2011 3.2 fsi S-line
    Mods: SQ5 rear valance and mufflers, AWE switchpath controller, X-pipe, custom high end audio system
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by lucio_liu View Post
    Why wouldn't you use the manufacturer-recommended 91 octane?
    Please don't say that you're trying to save money, because if that were the case, you wouldn't have bought an Audi in the first place...
    Jul 18 2016
    2015 Jaguar XF 3.0 Portfolio
    Florida
    Quote Originally Posted by zcd2.7t View Post
    My wife has a 2014 Q5 2.0 that we regularly put BP 93 in. On a recent trip we were only able to get BP 91 and we saw a big drop in performance. So much so that we couldn't wait to burn off that tank full and put 93 back in. Based on our experience I couldn't imagine what a pig a 2.0T would be not to mention the potential harm 87 might do. False economy in my book!
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Quote Originally Posted by Irish1004 View Post
    I've recently discovered that BP fuel (by me at least) is crap. I was doing some logging and noticed that with BP 93 I was getting knock detection/timing pull of at least a few degrees whereas a full tank of Sunoco 93 showed almost no timing pull. I guess that's why the BP by me is $0.30+ cheaper per gallon!
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Feb 15 2007
    Costco/ Turkey Hill/ Sinclair 91. It's all the same crap. Just use a Top Tier fuel and min 91 octane.
    *Highest we have in CO is 91 due to altitude.
    lower octane is actually more volatile than higher octane. You get less combustion with higher octane. It allows the piston to travel the maximum distance in the cylinder before the fuel ignites, offering more power (longer stroke). Other than that, all octanes are the same pretty much.
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Olive oil for me.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Dec 10 2011
    CLT | MKE
    In all seriousness, running 87/89 is a poor decision and will result in significant timing pull due to knock, reduced fuel efficiency, and a slower car, all of which are not good things. There's a reason Audi requires a minimum of 91 octane for your Q5.
    -Hayden
    Junior Member Two Rings emceus's Avatar
    Aug 22 2017
    Naples
    So true you can really tell a difference between 93 and 87
    I use shell V-power 93 all the time even when the gas prices suck
    Established Member Two Rings goblues38's Avatar
    Aug 14 2016
    STL
    boosted (turbo or supercharged) motors require premium.
    Normally aspirated do not.
    yes, you can use cheap gas in a boosted car, but it will be down on power 10% at least. In the long run, this will cost you any fuel economy you hope to gain.
    me = 2018 Ford Raptor, 1990 944 Cabriolet
    wife = 2022 A6 3.0
    daughter #1 = 2015 GTI
    daughter #2 = 2020 GTI
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Someone should take your keys away if you're running 87/89 in a FI engine. That's ridiculous.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Quote Originally Posted by BG SQ5 View Post
    THIS
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Mar 18 2013
    States
    Quote Originally Posted by goblues38 View Post
    will switch to 91+ in the future.
    - - - Updated - - -
    yeah trying to save money. i am cheap.
    Mar 18 2013
    States
    wife's daily commuter. she cant drive fast less than 10 miles roundtrip many traffic lights
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    the ping factor is the killer. low octane burns hotter and faster so using 91+ will save your engine.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Mar 18 2013
    States
    Quote Originally Posted by TexasDfwS4 View Post
    70c more than regular here in Houston. but wife only drive less than 3000 miles per year so I can afford.
    Veteran Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    Pay the extra $5 in gas and get 93o anytime you can. You'll have better performance and your motor will last longer;)
    Mar 28 2013
    Chicago
    That's kind of reverse though of how I think about this whole topic -- If you will be doing nothing but straight-up cruising on the highway, even at 80mph+, you could probably get away with lower octane without much trouble because A) you're never in boost, or very slightly, B) you aren't asking for much in the way of power. Detonation will just be less of an issue. Look at MPG of a 2.0T on straight-away, flat highway cruising. Pretty good, right? It's because you don't need to make any power... ie you aren't demanding boost...ie who cares about octane (within reason)
    Acceleration and transient conditions are where you demand much more from the engine, and you'll be dipping into boost to get going at every light. Face it, these things weigh 44-4500lbs with a little 4 cyl. You need that turbo to make them driveable in that kind of stop light to stop light commute. You see it in the garbage MPG you get on the 2.0T in that kind of driving. More power demand means you need the octane to avoid timing pull. With too low octane, you naturally step on it even harder to get going because it's not making the power you want at that moment. It's essentially false economy to run cheaper gas when more is being used for the same drivability. Just my rambling $0.02
    2013 Q5 3.0T Phantom/Black
    APR Stage2 | APR CPS | 034 Inlet Hose | ECS 12.5/20mm | 255/50-19 DWS06 | 034 Inserts | P3 | ...
    2020 MB GLC63, Black,
    2019 BMW M2 Competition, Black, 6MT (sold)
    Jan 02 2011
    MN
    Oct 15 2013
    Tampa, Florida
    Oct 11 2015
    Atlanta, Georgia
    Quote Originally Posted by AudiDTMA4 View Post
    Hilarious....and exactly my reaction. Nice!
    May 21 2010
    ECU compensates for lower Octane. Probably wont cause any harm unless constantly accelerating hard . My Brother has about 160,000 kms (100,000 miles) on his A5 with 2.0 and has never run a drop of anything more than regular and has never had a problem of any sort. Could be down a few HP but nobody is going to miss/notice 5-10 on the street. These monthly fuel threads are funny. That being said , I always run what manufacturer reccomends. They have no reason to suggest premium fuel id its not necessary.
    Jan 02 2011
    MN
    Quote Originally Posted by Wilbur View Post
    Here's the thing though......you're saving like $300 to $400 a year (so less than a monthly payment, 1-1.5 tires, 2-3 oil changes etc....). Just get a Corolla or Civic at that point.
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    If you paid for 220 HP why not get your money's worth and use premium gas?
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Feb 05 2014
    No one is mentioning that lower tier/octane fuels do not burn as clean and you will actually have more buildup than if you ran higher tier/octane fuel. In the long run you are going to spend more on repairs/maintenance than the savings at the pump...
    Established Member Two Rings m47thew's Avatar
    Feb 03 2016
    2001 Sierra 1500 HD
    Quattroland, Canada
    Go with leaded gasoline
    2001.5 S4 - Milltek SuperDual Exhaust, GIAC Xplus tune, 034 adjustable upper control arms (front and rear), density line lower control arms, front sway bar end links, rear sway bar + reinforcements, KW V3 suspension...
    Senior Member Three Rings sean_entrust's Avatar
    Feb 11 2017
    Portland OR
    92 only
    2017 S3 P+ (Mine) Daytona Gray Pearl / Black Optic / Carbon Fiber Package / 034 springs / Stoptech BBK / 12.94 @105.3mph stock
    2012 Q5 P+ (Wife) Ibis White
    Established Member Two Rings ryanherr's Avatar
    Oct 17 2015
    A4 B6 1.8t TIP, My sister's Camry "Drift Lord"
    Minnesota
    can you even get that anywhere?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Feb 23 2014
    Zielonka/Poland
    Interesting explanation of your dilemma: https://www.youtube.com/watch?v=WYlk9C1o0nk
    May 11 2017
    Bedford, NS
    Nice explanation! I use 91.
    Sent from my STV100-1 using Audizine mobile app
    May 21 2010
    I agree 100%. Just telling you that it doesnt cause any damage . I use 91-93 in my SQ.
    Quote Originally Posted by Perry01 View Post
    Agreed. Brother isnt a car guy and clearly hasn't done the math.
    Quote Originally Posted by PreciseD View Post
    Because thats not true. Detergents determine how "clean" a fuel is. Octane is basically about how much fuel can be compressed before it ignites....higher the octane the less likely it is to ignite early ("ping"). Higher octane fuel burns in a more controlled fashion than lower.
    Feb 05 2014
    That is why I said Tier/Octane...
    Lower tier fuels do not have the same detergents that higher tiers do.. and higher octane fuels are refined more than lower ones... That makes it a cleaner product...
    May 21 2010
    higher Octane level does not make it a cleaner product.
    Feb 05 2014
    Its not a cleaner product
    My experience with petrochemical plants and their processes would disagree...
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Jan 02 2011
    MN
    Correct, shouldn't assuming Audi's calibration team did extended 87/89 testing and the knock sensor is working correctly.
    I'd just feel like a dope putting 87 in a car designed for 91+.....
    May 21 2010
    I agree. If I wasnt prepared to run what owners manual said I wouldnt buy the car. Doesn't make sense to me.
    Jan 02 2011
    MN
    Same thing as people who get $99 tires for their $60K car.
    Mar 18 2013
    States
    owner's manual was kinda vague, says don't put below 87. I would prefer they put 91 required not recommand.
