Originally Posted by
5ktq
A couple times now, my ESP (?) light (triangle with '!' in it and circle arrow around it) has come on steady. goes away when the car is restarted.
Only code I'm getting that would correlate is brake switch - intermittent.
Seems pretty slam dunk but just checking if that is likely the case, or if its the ABS unit itself?
When watching ABS measuring blocks and pressing / releasing brakes, the switch and the... redundant test switch? one of them seems to lag or stick on entirely, so that seems like it's probably the problem...
I've had a similar issue, and think I recently fixed it: when sitting at a light, sometimes I'll have light brake pressure applied just to keep the car from rolling (manual trans). If I were to pay enough attention, I might notice that the brake lights aren't on, but the brake is definitely on slightly. Then the ABS/traction control lights would come on.
I believe my issue was an incorrectly set brake light switch. The ABS module's pressure sensor would sense brake pressure, but the brake switch wasn't telling it that the brakes were applied... so it would freak out and disable the system.
Simple fix: re-zero the brake switch, and reinstall paying careful attention to the plunger's engagement point. It took a few tries, including placing a temporary shim between plunger and pedal, before I got it perfect. Now the brake light comes on when there is brake pressure, and after 3 separate drives the issue hasn't come back. Mostly I was just really hoping to avoid spending $150+ on the ABS module brake pressure sensor
