Over the past year or so the car has been becoming annoying to drive. Noticibley at the track I started to have a sticky clutch pedal while shifting fast and missing gears became quite common. In some cases the clutch pedal would only return halfway from the floor. Letting the car sit a few days would result in the clutch engagement point being immediately off the floor instead of being at the top of pedal travel. The car has a newer clutch and master cylinder so I decided to replace the slave since it was original and cheap.
The beck/arnley slave is $38 from rockauto. Although it does require a minor amount of grinding to make it work. I think they made the metal housing to exact specs of the factory slave, but then they coated the whole thing in a thick protective coating and that was enough thickness to make the install very difficult/tight.
I used a dremel with a metal bit to grind the ring on the end that goes into the transmission. I also removed material on the edge near the mounting hole. I litterally just took the coating off (3 or 4 passes) and exposed the metal in those two areas and the slave fit in on the first try with no resistance.
I should also mention that you want to reuse the rod that comes with the factory slave. The beck/arnley rod was about 1cm shorter... now I know what they say its not the size its how you use it but I didn't want any push to start issues down the road so I swapped it. I also noticed the clip that holds the clutch line in the slave is not shaped correctly so i used my factory clip for a better fit.
After bleeding the clutch, I am incredibley impressed with the results. I think the factory slave must have been failing even since I bought the car in 2015 or the beck is just that much better. Shifts are much crisper, no more sticky clutch pedal and the pedal is a little easier to depress. I can actually launch the car now which will be great for the dragstrip this fall. I can also chirp the tires now when i hit second, so thats fun much better clutch engagment. Hopefully this helps someone out. I'm trying a new photosharing service with this post as photo bucket took a crap. Thanks!
-Alex
