Results 1 to 10 of 10
    Jan 07 2011
    2013 C300 4Matic
    DIY: Easily removable license plate bracket for those who need the front plate
    I have been asked by many people about my license plate bracket that I fabricated recently, so I thought I post up a quick and overall DIY guide. unfortunately I did not take many pic's as I just did this cause I was bored, and had no idea how it would turn out. but it turned out great imo! so I will try to be as detailed as possible, and will answer any questions you may have
    so for those who are living in states with the required use of front license plates, this can be a great way to have the plate on when parked, and easily removed when driving/photoshoots/etc. I cant take the credit though, as someone on the s3 section did this first, and I just pretty much mimic'ed his setup, so credits to him!
    this setup is mostly useful for honey comb grilles, and since a lot of members here have replica RS grilles, or FL s5's with the bottom honey comb grille, this will work very well
    ok so here are some materials that you should have:
    - license plate frame of your choice ( optional )
    - soft felt
    - thick, 3m double face tape ( thicker the better, it will be used as cushion)
    - 2 toggle bolts ( depending on your application, choose the correct length. RS grilles only need short ones, fog grilles will require longer )
    - 2 washers to go with the toggle bolts
    - black tape ( can use black gorilla tape, electrical tape, etc )
    - black spray paint ( optional, if you want to spray the toggle bolts )
    ok so lets start!
    prep:
    -clean the license plate
    -if you wish, spray the toggle bolts black as it looks the best and remains stealth
    license:
    1) cut the felt so its the size of the license plate. try to make it as exact as possible
    2) with the double face 3m tape, tape all over the back of the license plate. be careful not to cover up the screw holes on top and bottom.
    3) attach the felt on to the back of the plate pressing the felt against the 3m tape so it sticks together. you can also use glue, but the point of the thick 3m tape is so it adds cushion behind the felt. use both if necessary ( I did )
    4) if the felt is covering the holes, just poke the holes through since you will need to push the toggle bolts through it
    assembly:
    prep:
    -if you are using a plate frame, it may be a good idea to use double face tape on the bottom if the frame does not require screws on the bottom
    5) regardless if you have the frame or not, at this point you are going to put the toggle bolt through the plate. first thing is to unscrew the toggle itself so only the screw is on. push the screw through the front
    6) from the underside of the plate, screw on the washer all the way down. this will ensure the bolt will not move.
    7) once the bolt is screwed onto the bump and is not moving, screw the toggle back on. you are going to put it in the direction where it closes away from the bumper ( i.e. when u pinch, it will fold away from the plate, towards the car )
    at this point you are pretty much done. you can add some tape around the back of the plate to provide more cushion in case it touches any part of your car. you can also use the black electrical tape to cover up the silver colored parts of the bolts so its more stealth, unless you already sprayed it. but either way, as of right now, you can modify it however you see fit to make it work perfectly on your car. results should be similar to this:
    now to attach the plate:
    1) line up the toggle with the holes you want to use on your grille
    2) pinch it so u can put it through the hole
    3) listen to the click of satisfaction. VOILA. you're done
    4) to take off the plate, just pull
    note:
    for my specific application, I needed longer bolts since the fog grille is not flush with the bumper. if you are using it on your center grille, short toggle bolts are fine
    from the "creator"
    and heres a video of it in action ( installing and taking off )
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Four Rings gqambitions's Avatar
    May 27 2015
    Atlanta,GA
    Thanks for the break down Steve. Deff going to look into trying this .
    APR Sponsored
    Current- 2021 S6 Premium Plus on Arras red/ My build thread --> https://www.audizine.com/forum/showt...(Build-thread)
    Past-
    2018 B9 A4 (s line) Mythos Black metallic
    2008 VW Passat Wagon- Stage 1 Giac
    2010 B8 s5
    IG/TikTok/Youtube:@ikelifestyles
    Veteran Member Three Rings cchoi83's Avatar
    Nov 10 2014
    Long Island, NY
    TL;DR
    Your anchors are backwards!
    Jk.
    2018 RS 3 | Nardo Gray | Crescendo Red | Dynamic Plus | Black Optic | RS Design Pkg | Tech Pkg | Dynamic Pkg
    P3 | XPEL Ultimate Full Wrap | Nanolex Si3D HD
    I swear I'm keeping this one stock.
    Eventuri CF Intake | JRZ RS PRO3 | BBS CI-R | Michelin PS4S
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    Since you're local, want to make mine LOLL
    Sent from the Amazon.
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by gqambitions View Post
    hope it helps ! stupid NY lol
    Quote Originally Posted by cchoi83 View Post
    TL;DR
    Jk.
    don't jk. it is backwards :D lolol
    Quote Originally Posted by DreDay View Post
    lol. dude builds his air system. needs help screwing on toggle bolts to a plate :-D
    Present:
    IG: bknewtype
    Senior Member Two Rings Dlau's Avatar
    Aug 15 2016
    Was just looking for solutions to mounting the front plate due to the stupid requirement in ny, and came across this. Now i can do this mod and remove my zip ties/not buy a towhook mount. Thanks guys! You da real MVP.
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by Dlau View Post
    Awesome! Post pics!
    I went the zip tie method as well. Honestly most convenient and quickest way. Just didnt look clean/cheap
    Present:
    IG: bknewtype
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    See, I'd be worried about someone pulling the plate with this. A little less convenient but I think I'd flip the toggles around and just pop the hood whenever I wanted to take it back off.
    Cool solution though, may try at some point.
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by MilesM View Post
    If thats the case any one can take off ur plate if they really wanted to simple hand tools. Honestly dont know why anyone would want to steal a damn plate lol
    From the way it looks outside people cant tell its toggle bolts. It sits flush so it may look like its actually secured in place
    Present:
    IG: bknewtype
    Aug 15 2016
    Will do, once i find some time to hit up the local homedepot ;D
