So following the DIY on here, I slowly heated and twisted the plastic rod 90 degrees to get the slot facing forward. I took an x-y-z measurement before and after, they look pretty close.
Problem is, when I go to install the 8.5 knob, pull out the safety plunger, I push down feel the clicks, then when I remove the zip tie, and the trigger just snaps in and doesn't seem to catch on anything.
Should the trigger stay in the "out" position when I remove the plunger and zip tie?
What am I doing wrong?? Thanks for your help AZ... =/ =/
