Results 1 to 10 of 10
    Jul 05 2011
    Smith
    B8.5 allroad transmission won't shift out of 1st
    I'm going to scan the car when I get home. Any ideas?
    Jul 05 2011
    Smith
    Friday,18,August,2017,18:38:18:26996
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    Address 02: Auto Trans Labels: 0BK-927-156.clb
    Control Module Part Number: 8K1 927 158 HW: 0BK 927 156 AL
    Component and/or Version: 0BK 20TFSIUSA H16 1003
    Software Coding: 000002
    Work Shop Code: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL551211 002020 (AU48)
    ROD: EV_TCMAL551211_002_AU48.rod
    VCID: 74EC0C9ADFD25BE1FD-8020
    1 Fault Found:
    8708 - Shift Monitoring
    P0780 00 [237] - Shift Error
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11113 km
    Date: 2017.08.18
    Time: 16:26:13
    Unlearning counter according OBD: 40
    Voltage terminal 30: 13.483 V
    Engine speed: 2703 /min
    Transmission input speed: 2700.00 /min
    Transmission output speed: 410.00 /min
    Transmission fluid temperature: 45 ∞C
    Driving position: d
    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
    Current N215 Pressure control valve 1: 850.0 mA
    Current N218 pressure reg.valve 4: 50.0 mA
    Current N216 pressure reg.valve 2: 850.0 mA
    Current N233 pressure reg.valve 5: 390.8 mA
    Current N217 pressure reg.valve 3: 50.0 mA
    Engine torque: 47 Nm
    Current N443 pressure reg.valve 7 main pressure: 638.7 mA
    M015_Time Normal Mode: 57 s
    M019_Time Since Reset: 7650 ms
    M014_Time Since Shift: 2010 ms
    Address 01: Engine Labels: 06H-907-115-CDN.clb
    Control Module Part Number: 8K5 907 115 F HW: 8K2 907 115 L
    Component and/or Version: 2.0l R4/4V TF H09 0008
    Software Coding: 722A0013242600062000
    Work Shop Code: WSC 39403 001 1048576
    ASAM Dataset: EV_ECM20TFS0118K5907115F 001009 (AU48)
    ROD: EV_ECM20TFS0118K5907115F.rod
    VCID: 356AF19E942802E90A-8060
    1 Fault Found:
    10577 - MIL Request Signal Active (Check TCM for errors too!)
    P1624 00 [039] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 11113 km
    Date: 2017.08.18
    Time: 16:30:00
    Engine speed: 3920.00 /min
    Normed load value: 12.9 %
    Vehicle speed: 30 km/h
    Coolant temperature: 96 ∞C
    Intake air temperature: 44 ∞C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.169 V
    Median injection timing: 1.068 ms
    Engine operating condition-Channel 87: Part. load
    Relative load value: 23.98 %
    Engine torque: 60.3 Nm
    Readiness: 0000 0000
    Chassis Type: FL (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
    62 6C 6D 72
    VIN: WA1VFAFL1DA144503 Mileage: 11110km-6903miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (DET-CPMA) Labels: 06H-907-115-CDN.clb
    Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H09 0008
    Revision: ECH09---
    Shop #: WSC 39403 001 1048576
    1 Fault Found:
    P1624 00 [039] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 11113 km
    Date: 2017.08.18
    Time: 16:30:00
    Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
    Part No SW: 8K1 927 158 HW: 0BK 927 156 AL
    Component: 0BK 20TFSIUSA H16 1003
    Revision: --H16---
    Coding: 000002
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11113 km
    Date: 2017.08.18
    Time: 16:26:13
    Driving position: d
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
    Component: BCM1 1.0 H16 0103
    Revision: 09016001 Serial number: 00000485375501
    Coding: 26008091C03CAFC00000480300003D0D0F1C4708A209032100 0008004000010200020030000000
    Shop #: WSC 06335 123 12345
    VCID: 7AF022A2F5B62D91A7-802E
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 250912 H07 0080
    Serial number: SWF12090256538
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 20613664
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000002409124574
    Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0030
    Serial number: 0000002274555R364A02
    Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
    H01 0031
    Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
    H01 0031
    Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: D8084D46000000000001
    1 Fault Found:
    01771 - Control Module for Headlight Range (J431)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 176
    Mileage: 10384 km
    Time Indication: 0
    Date: 2017.07.16
    Time: 22:37:37
    Senior Member Three Rings alhutch's Avatar
    Jun 03 2017
    Portland, OR
    Did you save and then clear the faults? Solution?
    2013 Allroad - Volcano Red
    Jul 05 2011
    Smith
    Quote Originally Posted by alhutch View Post
    Yeah, saved the log dump and cleared the faults. Car drives fine now. I have an appointment scheduled....in a month Hopefully they don't balk at me and tell me the car doesn't have any codes, so they can't help me. Honestly, this is pretty silly...a possible TCM fault at 6k miles!
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    Quote Originally Posted by norcalb5 View Post
    Be prepared for it...unless you've got codes the dealer really can't do anything for troubleshooting, even if you do show them the VCDS scan. Hopefully it was just a hiccup. If not you've got a month to replicate it.
    Jul 05 2011
    Smith
    I lucked out...the day before I took the allroad in trans locked up on the way home. I didn't clear the codes this time. Dropped the car off and the dealer was unable to reproduce the problem, but based on the codes recommended the mechatronics unit to be replaced.
    Jun 03 2017
    Portland, OR
    I thought that was a DSG only issue.
    Jun 29 2007
    Texas
    How did this turnout?
    What exactly failed?
    Jul 05 2011
    Smith
    that's what i thought, but this is what the tech said:
    "good afternoon, XX here with Audi.. the vehicle is going to need whats called a mechatronics unit basically the computer inside the transmission. it is covered however is going to take about 7-10 days to get here"
    I asked if was basically the TCU and they said, "kind of yeah they term it differently and looks like a valve body inside the transmission"
    - - - Updated - - -
    Quote Originally Posted by f_399 View Post
    car is in the shop, they are doing audi things and fixing broken stuff. ill post once i get it back
    Jul 05 2011
    Smith
    got the car back. out of warranty you'd be shelling out 2900 for parts. labor brought everything to 4-5k
