Results 1 to 20 of 20
    Veteran Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    Any aftermarket hoods for this model?
    I'm looking for something to help vent hot air and perhaps reduce weight a bit? I've searched all over and not found any for a 2005 cabrio.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    You haven’t searched and found B6 carbon hoods? Are you sure you searched at all? There are literally dozens of aftermarket hoods for this car. Hell, there is one posted for sale in the classifieds section of this forum.
    http://www.eurogearusa.com/hoods/pro...iber_hood.html
    I typed “B6 vented hood” into google, and that’s the second link I found. The first one was a link to Audizine for the same good.
    Hope that helps.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Oct 11 2015
    Atlanta, Georgia
    Quote Originally Posted by james12lucy View Post
    Hope that helps.
    I knew I'd get a response like this. Look at my picture closely and then look at the hoods in the link you sent. The cabrio hood is different from the sedan hood (insert eye roll)
    May 18 2012
    2005 S4
    Portland, OR
    Yep, grille isn't part of the hood on a cabrio.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by Fourpoint282 View Post
    You’re right, I’ll own that mistake. Sorry.
    Ever though about buying a carbon hood and having a good body shop/ carbonsmith cut the grill portion of a B6 hood? It’d be beast to attempt with an old OEM hood first to ensure it’ll line up. Then use the template to do the carbon hood. All that would be needed is more epoxy, sanding, and clear coat to finish.
    Oct 11 2015
    Atlanta, Georgia
    Eh, it's a nice to have but not a have to have. I'm not interested in custom fab. If I could find a VERY good body shop who could add vents I might consider it, but my experience is the people who say they're good at this actually suck and those that possess the quality skills to do this wouldn't bother with it. I'll just move on from this unicorn hunt.
    Jul 04 2015
    Toronto Ontario
    Good points.
    Having said that, I’ll be adding vents to my B7 race car over the winter. If it turns out well, I’ll share the process.
    Veteran Member Four Rings VinnysS4's Avatar
    Nov 12 2015
    2004 s4 Avant, 2005.5 S4 Manual swapped, 2002 A4 3.0 6 speed, 2004 A4 1.8 5 speed
    Oregon
    Hope that helps.
    Lol saw this one coming. I haven't seen any mass produced carbon hoods for the cabrio. Or any decent ones for that fact
    Sent from my SM-G550T1 using Audizine mobile app
    1997 VW GTI VR6 (sold), 2003 Audi RS6 (sold), 2010 Audi A4 2.0T (RIP Totaled on 11/2/2015 ) 2005.5 Audi S42011 Dieselgate Q7 TDI..... patiently waiting for my warranty to expire!!
    My build log
    "Everyone is An expert when they make their own category."
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    I'd give it a whirl with some tin snips and a pipe wrench.... on a scrap hood for practice.... I imagine I could get some decent air flow/speed holes
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Nov 12 2015
    Oregon
    I'm a sheet metal worker and custom fabricator. We could make it happin cappin!
    My build log
    Oct 11 2015
    Atlanta, Georgia
    Good points.
    Yeah please do
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I need one as well... Wonder how much it would be to have one from a scrap yard used, I can either A repaint, or b wrap it.
    Veteran Member Three Rings Midnightblkb5's Avatar
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    none what so ever. just forget about it and leave it the way it is.
    His 03 a4 cabby 3.0! quattro swapped 0A3 6 spd 2.7t single turbo holset hx40
    Hers 06 a4 b7 3.2 tip
    build thread@ http://www.audizine.com/forum/showth...2#post12428942
    Oct 11 2015
    Atlanta, Georgia
    Maybe a dumb question but doesn't the b7 hood fit here? They look awfully similar
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    fit maybe. line up because of the shape of lights, never ever
    Oct 11 2015
    Atlanta, Georgia
    I'm grasping at straws here
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    ok! cabrios are unique to any other model in the b6/b7 lineup because of there fenders and hoods. they where not mass produced like the sedans or avants. on the b6 cab model it was ahead of its time. the one piece bumper was unique. it was s4 quality at that time. the only other b6 model with a one piece bumper was the s4, the cabrio was more so set up like a b7 as far as front end goes. with the b7 cab you have options as far as bumper goes. the bumpers for all b7 models are interchangeable. for the b6 this is not so. now with cabrios they have slightly longer hoods, and fenders. and if you look closely the b6/b7 fenders on the cab have the same body lines. the cutout for the headlamps are different on the fenders and hood. so you are basically stuck with what you have or your going to custom fab something. i hope the gives you some clarity
    Jun 14 2005
    Anaheim, CA
    I've got another straw for ya!
    If you were in Southern California I'd say try giving http://trackspecmotorsports.com/ a call to see if you can bring your car by for them to work something up bespoke for this application. A more feasible option is taking some measurements from the underside of your hood and going with one of their universal kits. Maybe shoot them an email and ask for advice on placement as well.
    Their vents are a neat product. Keeping the OEM hood and adding vents is beneficial because you have the OEM hood strength and fitment, which can both be concerns with aftermarket fiberglass/carbon hoods. Only downside is having to cut up your OEM hood but if you were considering going with a vented hood to begin with, this may not feel like such a big deal.
    Keep this thread alive if you go that route, would love to see the results!
    Brandon @ VMR Wheels
    Brandon@Velocitymotoring.com | 714.442.7916 Ext 108 | www.velocitymotoring.com| Instagram | | | Blog
    Oct 11 2015
    Atlanta, Georgia
    Quote Originally Posted by Midnightblkb5 View Post
    Great explanation...thx
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    no prob
