Results 1 to 13 of 13
    Active Member One Ring S4NOWHT's Avatar
    Apr 22 2017
    2016 S3 (SOLD), 2013 S4 (SOLD)
    Ashburn, VA
    Best Tune for the S4?
    Hi all. My wife just picked up her Audi B8.5 S4. I know APR is usually the top tuner in the market from what I've heard for Audi/VW. Are there any other tunes the community would recommend or is APR the way to go? Def plan on upgrading her super charger pulley and crank pulley.
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    I would look to see who can provide local support, however there are a couple of flash at home options. You have APR, GIAC, 034, Unitronic, Revo & EPL as your choices. They may feel different, but you will be pleased with either one.
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    Upgrade cooling!
    There are a couple APR Dealers in your area. And there are quite a few threads that will answer your questions. Unitronic, Revo, EPL, APR, United Motorsport, Chipewerke, 034, etc...
    I would do a few other things before I went to DP. Upgrade "her" cooling unit.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Joker S4 View Post
    Upgrade cooling!
    I echo and stress this sentiment as well.. don't go DP unless you plan to upgrade your cooling
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 04 2012
    MSP
    My suggestion
    Enjoy the car stock for a while... there's nothing wrong with that. You determine what a "while" is - I didn't stage 1 my car for a year.
    Stage 1 tune is potent as is and really wakes it up above 5k RPM. This is the least obtrusive upgrade. Software and you're done.
    Stage 2 is more than enough for most but at this stage you will want some supporting hardware. (see below)
    Dual pulley will be probably overkill for her (just an assumption).
    Anything more than stage 1 you'll want to do an upgraded intake and cooling and probably exhaust. Do the math with the tune and install and you're easily in the 7k+ ballpark. Up to you to decide if the wife needs all that. You don't HAVE to do exhaust but it's recommended and you might as well if you're doing the rest.
    I'm assuming it's an Auto that you got. If so then you'll want to also do the TCU tune if you're doing the stage 2 or Dual Pulley... If it's a manual then you'll probably be needing a clutch on the DP set up. Factor those costs in as well.
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    If DSG you will want DP / Upgrade Heat Exchange / TCU tune - keep in mind all the additional boost/heat you will eventually burn out your catalytic converters (factor as future cost + labor 8 to 10 hrs if DSG)
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    if we are telling this man to go straight dual pulley let's also tell him that he is going to have to replace his cats and the car could sound drastically different to the point his wife may not enjoy it. Dual pulley w/o cooling is fine for 2 pulls and then the car limits to ~ stage 2ish levels so yes you want to upgrade the heat exchanger but also go w/ a tune that has safe guards in place which appears to be all of them.
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Quote Originally Posted by Thurston View Post
    Indeed - and good catch! ty
    Apr 27 2015
    canada
    Quote Originally Posted by bayonet14 View Post
    thanks!
    Sep 10 2008
    ashburn, va
    I live in the nova area as well and i recently had NGP install the APR stage 2 along with the TCU tune, next thing i will have them install the APR CPS along with the crank pulley. I am definitely very happy with the tune
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Closest tuner to you
    /thread
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Deactivated Four Rings
    Jun 23 2011
    PM sent
    Right now we are doing package deals with a Roc-Euro intake
    Stage 1, cable and intake for $1249
    Stage 1, TCU, cable and intake for $1699
    Stage 2 with our SC pulley, belt, cable and intake for $1799
    Stage 2 with our SC pulley, belt, TCU tune, cable and intake for $2199
    All prices shipped in the USA except for CT.
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    I just did the Stage 1 EPL tune today and it was a no-brainer to do this at home. Clear instructions, very simple, and after a one hour drive on some river bottom roads, I can definitely say that the engine feels much more alive, especially in the upper RPMs.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
