Results 1 to 22 of 22
Thread: C5 Color MFA
    Jan 23 2008
    02 B5.5 4mo/ 05 b5.5 4mo
    washington
    C5 Color MFA
    Just got the Autopilot Color MFA installed and couldn't be happier. Purchased and installed through/by Clusters By Litke
    Lots of great features, like the modern Audi and VW MFA with VAGCOM functionality built in to cluster
    Veteran Member Three Rings Nogaro Nitwit's Avatar
    Sep 13 2010
    2000 S4, 2005 allroad 2.7t, 2004 allroad 4.2
    Sterling, VA
    Very cool!
    2000 S4 - ASP Stage 3, ER ICs, ASP DPs, ASP True Dual Exhaust, 710Ns, Neuspeed 19mm swaybar, ASP phenolic spacers and many more goodies
    2005 allroad 2.7t - 6mt conversion, Daz Stage 2 tune, S6 seats/headliner, Podi boost gauge w/ custom pod, Arnott Gen IIs, H-sport swaybars, Magnaflow exhaust, 19"x9.5" Miro 111's, Euro roof rails, OEM spoiler, LED Tails
    2004 allroad 4.2 - APR tune, OEM spoiler, H-sport swaybars, OEM hitch, BFG K02 all-terrain tires, Yakima roof basket
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Aahhh fantastic, another person to bounce ideas off of. I installed mine into my cluster last week too!
    I set my temps up to be:
    AMBIENT OIL
    INTAKE COOLANT
    Few questions:
    So are you able to see [R] when you put it in reverse?
    Are you able to see boost pressure without manually tapping the MAP sensor?
    Did you have brake light before the cluster swap?
    Does your oil level work? Doesnt show your level or anything in your vid
    Ive been informed that these can not accept 3rd party sensor inputs either such as an afr or boost gauge...
    Mine works 100% accept boost pressure and [R] for reverse...
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Jan 23 2008
    washington
    No [R] in reverse, i also had to adjust the gearing in the cluster but it always shows the right gear now
    No boost pressure
    Brake light was on before swap, pad wear sensor wire got cut when the rf airbag blew out
    Oil level does work
    i was a little disappointed about the boost. Was hoping not to have to get a gauge.
    Also thinking about having the white LED's in the speedometer replaced to match the MFA's brighter white color
    Jan 04 2013
    Zephyr Cove NV
    Yea I received conformation that R only works for the auto cars. Not manual.
    In order to see boost you need to tap the boost line from the sensor. It is T121/101.
    I have learned that depending on what map sensor you have installed 2Bar (stock), 3Bar (TDi), or 4 bar, the mfa automatically scales for the different sensor. Found this to be cool...
    Oil level works on my car. Are you able to see oil level in vcds 17-instruments? Maybe you have a bad sensor?
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Something I have been waiting for!
    Looks awesome
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Bringing this back.
    I want to do this mod. Did anyone look into the Diaz module? Search it on YouTube.
    I'm talking with both of them right now but there may be some questions about reliability with Diaz software. Does anyone have any insight?
    Sent from my ONE A2005 using Audizine mobile app
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Jan 04 2013
    Zephyr Cove NV
    It is differently different software. Maybe an update
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    May 09 2012
    Virginia
    I can't seem to track down an ECU wiring diagram to tap the boost gauge into the T101 ECU wire. For those that did it, where did you actually tap the wire? Prior to going into the ECU from the MAP sensor? What did you use to tap it? Thinking about using posi-taps. Thanks.
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by jbain2 View Post
    Back from my trip, text me tomorrow and remind me I'll forward you the wiring diag, should have it in pdf.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Feb 01 2017
    NoVA
    Very cool upgrade, my LCD fades to nothing when it warms up. I'd just have to try and justify the $$.
    Is the eastern european group the only ones that do this, or is there a state-side group that does it as well?
    Nathan
    ____________________________
    '19 SQ5
    '64 356 SC 1720
    '73 914 2.8 6-cyl conversion in progress
    ‘02 S6 Avant - gone to a new owner to live up to it’s potential as a 6-speed
    RIP (tree) ‘99.5 A4 2.8 Quattro Tip - GIAC engine and tip chip, Stage 3 MAF mod, A8 front rotors
    May 09 2012
    Virginia
    Quote Originally Posted by JMURiz View Post
    The units are ordered from overseas. I worked with Matt Litke. Google clusters by Litke. He is U.S. based. All in with him doing the install I was right around $500. If you are going to pay to have a fading cluster replaced it makes it slightly more worth it. I find the amount of data and the features invaluable.
    Jun 07 2005
    Shepherdstown, WV
    Jbain2's was awesome when I saw it, haven't been able to justify 500 myself but it seems reasonable for how good it looked and the functionality.
    I've done my TT and allroad with the normal replacements if you are doing it yourself then the cost difference is pretty high if you are paying the color gets a little more reasonable..... one day.
    May 09 2012
    Virginia
    You can read all measuring blocks. Read and clear fault codes. I needed to replace the LCD anyway and since I suck at soldering and small electrical jobs I was going to send the cluster out to get it repaired anyway so I figured it was as good a time as any to go with the color MFA.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    wish they have some special or group buy. Looks cool, but cannot justify the price, after spending 300+ on P3 gage.
    May 09 2012
    Virginia
    Quote Originally Posted by V1nny View Post
    I hear you. I wouldn’t do it either if I’d gone the P3 route. You can do the install yourself and save the $250 but frankly I found the install on YouTube and it’s no joke. Way beyond what I can take on.
    Nov 22 2015
    Norway
    Just random browsing and found this thread.
    Just feel i have to reply.
    The jobb looks way scaryer than it is!
    If you have changed the normal lcd or even just thought about it i would say this is a way easyer jobb, although more time consuming.
    If you have a desent solder station, a magnifier a multimeter and some patience this is for you.
    Atleast on the b5/c5/8l platforms.
    Now ive herd mk4 can be abit more trouble.
    Jun 07 2005
    Shepherdstown, WV
    Bump reminded me. Anyone have contact info for someone in the US selling them for self install?
    May 09 2012
    Virginia
    Quote Originally Posted by chris86vw View Post
    Sent you a text.
    Established Member Two Rings simple2me's Avatar
    Apr 22 2015
    Lousiana
    I want one. where can I buy one at?
    Dec 13 2017
    Silver '03 Allroad, '17 Mk7 Golf Wolfsburg
    Laguna Hills, CA
    Talked with Matt Litke this morning. The next round of ColorMFA's opens this weekend. 5-6 month lead time (perhaps sooner but erring on the side of caution).
    240$ for DIY kit
    [email protected]
    My stock MFA hadn't turned on for a few years. I was able to get it to work again by simply cutting a small stripe of rubber with some double sided tape that would pinch the ribbon connection in place. It worked great but it slowly started to fade when its warm over the last 6 months, and now only works when its really cold, or for the first 15-20 minutes before the cars gets warm. I am going to try and resolder the ribbon this week while I have the car apart for valve covers, a power steering leak, and an AC compressor replacement.
    Pigging off what Mrimstad said above - I Have some experience building control boxes for the testing machines at my work. Similar small PCB's and wires everywhere, it was really daunting the first time i worked on one but picked it up really fast. After looking at the directions it doesn't seem that crazy in my opinion.
    I'm going to order one if I cant get my stock one working again, I'm going to pull the cluster tonight and work on it tomorrow. Will keep you guys updated.
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by Gogeees View Post
    240$ for DIY kit
    Sweet, 3 family birthdays this weekend so wallet is sore but I"ll go sell some parts I guess :)
