Results 1 to 15 of 15
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Musty smell from A/C..
    Anyone have any experience with this? So far I have changed out the cabin air filter and checked the air intake under the hood under the plastic cover where it resides- totally clean.
    I get a wet/musty smell from the AC when I first turn it on. It is mostly only when the car has sitting in the sun and getting heat soaked, them when I fire it up and turn on the AC I get blasted in the face with that smell. It lasts for a minute and then goes away. To me it smells as if stagnant water is sitting somewhere in the duct system. I just sprayed pure rubbing alcohol into the intake while running the fan to see if that kills it but I'm doubting it.
    Where are the drain lines for the evaporator and where is the condenser itself?
    Sent from my Nexus 6P using Audizine mobile app
    Established Member Two Rings ehofmann's Avatar
    Dec 22 2014
    Colorado
    Spray lysol in the intake and run it on low for a few min. Then let it sit overnight with the windows down to help the lysol smell dissipate. I had to do it in my a4 and s4. Works great.
    Feb 21 2012
    Aurora, CO
    I think my drains are plugged.. no water on garage floor after running AC.
    Feb 21 2012
    Aurora, CO
    Answered my own question: one drain line is located on passenger side footwell, against the trans tube. Remove small rectangular panel as pictured by popping off bolt cover and using 8mm hex drive.
    There is the drain line attached to drain pan.
    Turns out mine isn't clogged so ordered some 1Z to clean the evaporator.
    Established Member Two Rings DaveG ASP3's Avatar
    Jun 23 2011
    2001.5 Audi S4 6MT Sedan ASPSTG3, 2006 Acura MDX
    New Jersey
    I was going to recommend the 1Z Klima Kleaner. I've used it on many cars - works great.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    2014 A6 Prestige, Sport, Cold - Daytona Gray on Black
    2001.5 S4 Bose, Cold - Brilliant Black on Black
    Apr 14 2010
    Southern California
    I have just started to get the odor problem in my 16 S7; one year old, 7k miles. I have had this on previous cars, once so bad I had the evaporator replaced. The smell is from mold that grows in the intersticial spaces of the evaporator. Some moisture remains there when you park the car, even if the drains are clear, and mold grows. While there are ways of combatting the mold, prevention is the best. That means, switching off the A/C a few minutes before you park the car and running the fans at high speed to expel the moisture. i.e. Don't put the car away wet. That mold CAN have an adverse effect on those with respiratory sensitivity.
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    Quote Originally Posted by EriCal View Post
    You beat me to it! This is exactly how to combat this issue!!! Always turn off AC and let car run a good couple mins before shutting off to let system cycle through and expel moisture.
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    Feb 21 2012
    Aurora, CO
    I'm learning all this now. This wasn't an issue on my C6 that I had for over 4 years. I don't get it.
    Feb 21 2012
    Aurora, CO
    I believe that this could be the reason that when I arrive at work after 30 mins in the car that my nose itches and is runny. Seriously.
    Mar 26 2010
    US
    Every night I park in the garage, with the front windows rolled down - no issue with mold.
    BMW M3 Competition X-drive
    Feb 21 2012
    Aurora, CO
    For anyone searching this issue like I was for the C7 platform, here's the solution:
    KlimaClean is definitely the way to go because the smell from the cleaner fades almost immediately.
    You need 2 cans (at least I did) to get it done right and completely kill the odor.
    You need to empty one full can in the passenger side evaporator drain tube located on right side of center console (passengers left leg). See picture earlier in this thread. remove plastic cover to access bolt, pull small panel off to expose where evaporator tray connects to drain tube. This process is identical on the driver's side. Remove rubber drain tube connection from evap tray nipple. Grab some paper towels and place around the nipple to catch the cleaner because it will spill out. Insert tube from 1z KlimaClean into nipple, run in as far as makes sense, then attach to can and empty the can. When can is empty, quickly reconnect the drain tube so the product can drain out of the car. Repeat with second can on driver's side. Then follow directions on product and run fan for a few minutes to dry out system.
    I originally only treated the passenger side and within a day the odor returned. I then ordered another can and hit the driver's side and that killed the odor completely. This way you are getting both sides of the evaporator with the KlimaClean. Happy to report that the smell is gone.
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by SlickMachine View Post
    Sorry to bump and old thread but I'm about to do this. The directions from KlimaClean say to remove the blower motor... will using this product as you described work since the blower motor is still in there?
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Sep 07 2019
    Run the heat on full blast before shutting off the car
    Established Member Two Rings SHR's Avatar
    Apr 01 2012
    2013 C7 A6, 1998 B5 A4, 2011 Honda Odyssey, 2002 B6 A4
    Pittsford, NY 14534
    I chased this same problem in my sons B6 A4 for a couple of years, until I discovered that I had issues with the 4 servo motors that regulate the airflow being out of synch, and I believe one of them was bad, I destroyed it trying to clean the pot, so I just replaced it. I throw this out there for you in case the issue continues to return. On the B6, I found a reset procedure that you perform by holding the HVAC control buttons in a certain sequence, and I also found the procedure to initiate it with VCDS, both worked fine. You can hear and watch the servo's actuate to each extreame and then find where they should all be in unison with the others. I assume they're designed to dry the moisture out in a particular sequence based on what the system is delivering. Once I got everything in synch the issue never came back and I haven't had to spray another can into the evap. I don't have time to research if this is similar on our C7 and hope this info is helpful.
    Gone - C7 A6
    Gone - 2012 S4 | Phantom Black | Prestige | Titanium | Black Silk Nappa | 6MT | Sport Diff | Carbon Inlay | Full Front 3M Paint Protection | 3M Crystaline Tint 50% | Passport SRX | Bilstein Eibach B12 Prokit GTF 25.7 | Wilson Electronics Signal Booster | DIY and OEM IC Protection Screen | Piano Black Painted Dash Surround | BFI Spacers 10mm x 4 | Michelin Pilot Super Sport 245/35 19 |
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I got one of these long ago and don't seem to have any problems.
    https://www.frecious-plus.com/en
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
