Results 1 to 12 of 12
    Established Member Two Rings mangol4life's Avatar
    Jul 14 2017
    Infiniti G37 Coupe
    Orlando fl
    Automatic Lights feature
    I have a 2010 Audi A4 premium. My light switch has the auto option but it does nothing. I have read through the forums and I think there is a light sensor in the rear view mirror on some models but my model only has a basic mirror. I have even checked inside the interior roof light counsel to see if there may be connections for a optional rear view mirror with the sensor but no luck.
    All I want is for the auto function to work.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    When in "auto", your lights arent on?
    Auto works in my 2010. It simply turns the headlights on when its dark and turns the LED strip on when it's not dark.
    I'm as cool as a cucumber in a bowl of hot sauce.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    I thought the sensors were located in the headlamps?
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Were you the original owner of your A4? The AUTO position on the light switch uses a light sensor in the rearview mirror. If you are not the original owner, the rearview mirror may have been replaced with a regular RVM to save money.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Yeah you're definitely lacking the hardware piece (at least) to get that functionality working. Need to install the appropriate mirror, then probably refresh the coding... assuming this car was originally equipped for it to begin with.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by A4 Centaur View Post
    Thought it was part of the automatic wipers package which is why you cant have it unless you have the rain sensor.
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    You'd need a rain sensor with appropriate wiring loom to auto switch then you'd need a new trim piece to cover the wiring aswell as a new windshield to have the right lines to go around the sensor
    Jul 14 2017
    Infiniti G37 Coupe
    Orlando fl
    Quote Originally Posted by BeerBrent View Post
    When in auto the lights do not come on when it gets dark.
    Jul 14 2017
    Infiniti G37 Coupe
    Orlando fl
    Quote Originally Posted by plat View Post
    I am not the original owner. You may be right but I would assume that there would be extra wires in the ceiling panel but there is none.
    Jul 14 2017
    Infiniti G37 Coupe
    Orlando fl
    Quote Originally Posted by B8_Dude97 View Post
    Seems like it may not be worth it.
    Sep 05 2016
    Antioch, California
    Quote Originally Posted by mangol4life View Post
    Depends. How's your insurance deductible on broken windshield? Mines 100 so if yours is the same or better it might be time to move your car near the baseball field. I'm kidding of course
    You would need a harness to go from headlight switch to route all the way up to upper dome console then the trim to attach to winshield and then have a window installed install new winshield and from what I heard you just give him the mirror and trim pieces and he makes it all stick right. After that you would need minor coding done with vagcom to get the car to acknowledge the rain sensor. On a plus note you get auto wipers aswell but not sure on coding for that. This is in the books for me when I do a headliner conversion
    Jul 14 2017
    Infiniti G37 Coupe
    Orlando fl
    Thank you for the advice
