Results 1 to 12 of 12
    Established Member Two Rings ehofmann's Avatar
    Dec 22 2014
    Colorado
    Detailed DIY $200 amp and subwoofer for Bose A6 S6
    Hey guys,
    I ran this setup in my S4 and was very happy with it. It is not like some shitty system you would hear in a high schoolers car btw. Only difference vs my S6 was that in my S4 I had the sub put in the stock location in the rear deck with dynamat. Although this is not a true open air sub, it works VERY well in this capacity. So anyone who does not want a sub box in the truck could still run it in the stock sub location. I am just lazy and opted to use a box since I don't use my trunk much.
    Parts :
    1. Boss r1100m monoamp: https://www.amazon.com/dp/B004S4XNEO..._URkKzbNHGMBAS
    2. Amp Wiring kit - I used Best Buy's kit from prior project but you can find these online. Just don't buy the super cheap stuff. Plan on $50-70.
    3. TruConnex 2 channel line output converter: https://www.amazon.com/dp/B00FN1TXHM..._aVkKzbDYVWDK9
    4. Polk Audio db1040DVC 10-Inch Dual Voice Coil Subwoofer https://www.amazon.com/dp/B0016GT6OI..._GTkKzbGCKZQJ0
    5. Scosche Se10*10-Inch Sealed Subwoofer Enclosure https://www.amazon.com/dp/B0007TJDG6..._TSkKzbA0MXPJ3
    6. Assorted electrical connectors (quick connects, butt connectors), zip ties, electrical tape, velcro tape
    7. About 7ft total of 12-14g speaker wire if not included in amp kit
    Tools:
    1. 10mm + 12mm sockets and wrenches
    2. Drill
    3. Assorted torx bits
    4. Wire cutters
    5. Dremel tool with cutter. Recommend 90 degree adapter
    6. Something to pull wires through - I used coathanger wire and tape
    7. Small pry bar or similar
    Installation for sub:
    I opted to wire the sub for 8ohm. Basically you connect the positive and neg from the sub box to the corresponding terminals but on opposite sides of the sub. Then you take a 3rd strand of speaker wire (about 8in), tear it in half so you only have a single wire and connect the other pos and neg on opposite sides of the sub. Also, the male connectors on the polk sub required cutting off the connectors from the the sub box wire because they were slightly too small. Just put on larger connectors or solder. Once the wiring is done, drill the sub into the box with the supplied hardware. Set it aside. Grab a beer.
    Installation of amp.
    Of course this requires some customization but there will be enough space.
    1. Disconnect neg of battery
    2. The amp is in the left side of the trunk. Disconnect the 3 electrical connectors on the Bose amp.
    3. Take off the front screws (2) and back nuts (2) holding the amp assembly to the car. You can now remove the amp. You do not need to take the amp off the assembly.
    4. Dremel off the back plastic piece that is still in the car (under the piece you just removed). I used a dremel oscillating tool but you can use a normal dremel with 90 degree adapter.
    5. Dremel out the front plastic piece that sits between the 2 front screw holes. This will allow you to easily make adjustments to the amp later.
    6. I have set the amp to: bass boost 0, crossover about 60hz, mode of low pass, level about 40%, sensitivity 100mv-2v.
    7. Connect all wires to the amp and test fit the new amp in this space. When happy with it, you should put the velcro tape on the bottom to hold it in place and zip ties if needed. Keep the wires connected to the amp but don't reinstall the stock amp yet.
    Wiring:
    1. Remove the white nut on the right side of the space for the amp. Use this to connect the chassis ground wire from the amp. Make sure to retighten the nut well.
    2. Remove the 2 chrome hooks on the left side of the trunk and also remove the spare tire
    3. Use a pry bar gently to pry up the carpeting beside the wiring loom at the front left spare compartment. The carpet will not fully come up, you just want to give yourself enough room to run the wires. As you pry up, put the coathanger piece through. Tape the wire to the coathanger and pull it through. I did it for each wire individually as there is not much space. You will want to do this for the positive battery wire, the "auto on" trigger wire, the sub control phone cord wire and the speaker wire (about 5ft if you are using a sub box.) Reinstall the chrome hooks.
    4. For the positive wire (make sure this has a fuse), connect it directly to the + of the battery
    5. Locate the cigarette outlet on the right side of the trunk and take the surrounding trim piece off by turning the 2 holders on the bottom. This will give you access to some fuses and the outlet. Take the auto-on amp wire and pull it through with the coathanger. I had to go near the back to get through. You can probably easily do an add-a-fuse, but I did not have one. I cut the + from the cig outlet and spliced in the trigger wire. Reinstall the trim piece.
    6. Put down the left rear seats. Run the speaker wire and the remote cord under the trunk carpeting
    7. Hook up the subwoofer and put the box where you want it.
    8. Leave the remote cord alone for now but you can connect the controller. I put up the seat and ran the cord to the front console without hiding it. (I chose to complete this later after testing the sound. See the next section for subwoofer knob installation if you want to complete this now.)
    9. Unplug the bitch of a connector at the stock sub. You will notice that there are 3 wires white/red (+), white/gold (-) and brown (grd). The problem is that if you try to find these wires in the large wiring loom that connects to the stock amp, there are no correlating wires. This had me scratching my head for a bit but I found that if you look under the rear deck, there is another connector to the sub where brown/grey wire connects to white/red and brown/blue connects to white/gold.
    10. Go to the large wiring loom with the pinkish lever by the amp and find the brown/grey (not white) wire and the brown/blue wire that runs with it. ( Brown/grey is + to the sub and brown/blue is -). Cut both wires.
    11. Get out the line output controller. Take the solid grey and solid white wires and twist the copper ends together. Then couple this together (via butt or twist connector) to the brown/grey wire that is still attached to the large connector with the pink lever. Do the same for the grey/black, white/black and brown/blue.
    12. Plug in the RCA cord to both the line outlet converter and the front of the amp.
    13. My wiring kit had rubbery blue and black wires that were supposed to run from the amp to the sub. However it was too short. I thus connected these via butt connectors to the speaker wire from the sub. Note: if you are putting the sub in the deck, you will connect these wires from the amp to the bare ends of the brown/grey and brown/blue wires that you cut earlier.
    14. Reinstall the stock amp assembly and reconnect the 3 electrical connectors.
    15. The line out converter fits very well on the right side of the assembly. I just used velcro tape on the inside to keep it from moving.
    16. Reconnect the neg of the battery.
    17. Turn on the ignition. Put on some music and make adjustments to both the mmi, bass controller and amp as needed. Keep in mind the sub will need a few weeks to fully break in.
    Subwoofer control knob installation
    - to be added in future
    Senior Member Two Rings 13_C7_SC's Avatar
    May 01 2016
    2011 Range Rover Sport
    Glenside, PA
    Awesome write-up.. now if I only had the Bose system lol
    Sent from my Nexus 6 using Tapatalk
    Dec 22 2014
    Colorado
    Quote Originally Posted by 13_C7_SC View Post
    This could work with any system. Only difference is probably the color of the wires going to the stock sub
    May 01 2016
    Glenside, PA
    Oh really, cuz I have the no name system, and I've been dying to change my sub, and run an amp on it.
    Weren't the power wires you were splicing into, the wires on the factory Bose amp?
    Dec 22 2014
    Colorado
    You don't power the new amp from the stock amp. You power it directly from the car battery. The new amp is just taking the sub signal off of the stock amp and well, amplifing it.
    May 01 2016
    Glenside, PA
    Ohh ok, that makes sense
    Established Member Two Rings Slickn's Avatar
    Apr 08 2012
    Massachusetts
    I'm about to undertake a subwoofer project to upgrade the Bose subwoofer in my a6. Going a slightly different route with replacing the 10 inch rear deck speaker with an Acoustic Elements IB10au subwoofer specifically geared towards infinite baffle applications. I then went with a Kicker 40kx800.1 amp that allows for speaker level inputs(so no need for a line out converter) and has technology to turn on based on sensing a DC offset on the speaker level inputs(so no need for a turn on wire). I chose this amp because I really wanted an amp that had a built in eq that allowed for frequency and q adjustments for the bass boost. I'm excited to get it all together and see how it sounds.
    Sent from my XT1635-02 using Tapatalk
    2014 Audi A6 3.0t Prestige - 20" sport. EPL stage 2. Eurocode sway bars.
    2001.5 Audi A6 2.7t - K04/997 hybrids tuned by EPL.
    Dec 22 2014
    Colorado
    Quote Originally Posted by Slickn View Post
    Let us know how it goes. Can you post up links to the amp and sub?
    Apr 08 2012
    Massachusetts
    Quote Originally Posted by ehofmann View Post
    Sure. The sub is from Acoustic Elements(AE). Its a 4 ohm IB10au sub without their Apollo upgrade. Can be found here: http://aespeakers.com/shop/ibau-woofers/ib10au/
    The amp is a recently discontinued Kicker KX series mono class d amp. Class d amps are more efficient and produce much less heat and consume much less current than class a/b. The model is Kicker 40KX800.1. Can be found for relatively cheap money here(probably for a limited time only): https://www.amazon.com/Kicker-40KX80...icker+40kx8001
    I also bought the speaker to RCA cable connection: https://www.amazon.com/Kicker-KISL-2...speaker+to+rca
    Finally, I purchased some FatMat sound deadener for the rear deck and trunk: https://www.amazon.com/dp/B00DYAF9FY...ing=UTF8&psc=1
    I had some 4 gauge power and ground cable left over from a previous install. I am planning on putting the amp in the spare tire well. Im going to attempt to epoxy some wood to the side of the spare tire well, and then mount the amp to the wood. Not sure if this is a good plan or not, but it will keep most everything contained to that small area, and allow me to easily adjust the bass eq on the amp's hidden panel.
    All in im about $550 deep.
    Edit: BTW I have a Polk DB12 subwoofer in their ported box in my 2001 Audi A6... it bumps pretty hard.
    Senior Member Three Rings Prh's Avatar
    Mar 28 2015
    Q5, Land Cruiser 200, John Deere
    Northern VA
    Look forward to seeing some pics of your install. I just ordered the amp and want to do the same. On the fence about which sub. Anxious to get your feedback on the sound. Thanks
    Sent from my iPad using Tapatalk Pro
    2014 S6 Black - APR Stage 2 ECU+TCU, APR DP, AWE Exhaust, HRE-FF01, Black Optics, P3, ALP, Escort Redline 360, Blackvue, 034, carbon diffuser, carbon mirror covers, Roc-Euro intake, ECS Tuning sways, H&R lowering module
    Mar 28 2015
    Northern VA
    I did the Bose subwoofer upgrade and finally getting around to post.
    I ended up buying:
    Kicker 40KX8001 Mono 800 Watt Amplifier from Amazon (someone else on here recommended and it was on sale/closeout. It's got more power than I need for now but would rather have more watts than not enough.
    Kicker 10 Sub: https://www.crutchfield.com/p_206CWC...mnews=12532363
    XCEL Foam Rubber Padding - Acoustic Damper Anti-Vibration Closed-Cell Pads from Amazon.
    AudioControl LC2i 2 Channel Line Out Converter with AccuBASS and Subwoofer Control
    FatMat Self-Adhesive RattleTrap Sound Deadener Pack with Install Kit - 25 Sq Ft x 80 mil Thick
    SoundBox Connected 4 Gauge Red / Black Amplifier Amp Power/Ground Wire
    InstallGear 4/8 AWG Gauge AGU Fuse Holder Distribution Block 4 Gauge
    Removing the Bose sub was straightforward. I added the FatMat Sound Deadener on most of the top rear metal panel and then dropped the new subwoofer in place. Putting in new sub was a bit of a PIA. Had to drill new holes through the panel and drill bit hit my rear window which nicked up my window tint a little.
    I'm a big guy and getting in the trunk on my back was not comfortable, not to mention we were having 95+ degrees with 90% humidity the day I tackled this project in my garage.
    I removed the Bose amp from the side panel. It was going to be way too much effort to get my new amp and LC2i line out converter to fit on the existing amp bracket. If the amp was smaller, it would have been easy. Ended up mounting both near the spare tire (pic below).
    Everything was pretty straight forward except the remote turn on. This amp and the LC2i can be configured to turn on when they detect a signal from the sub line. This isn't reliable as others have pointed out. I noticed the amp would not always turn off (e.g. turning off car, locking, coming back 30 mins later and seeing the amp still powered on). I wasn't going to chance it, coming back to a dead car battery. I ran the remote power-on to a fuse on the fuse bank on the right side. (they are concealed, need to remove the two black plastic connectors that the net attaches and pop out the panel).
    Initially, there was way too much bass. I had to play around with the crossover settings and dial the LC2i and amp down to around a 1/4 of max power. All good except a really annoying rattle/buzzing sound. Finally isolated to the rear third brake let vibrating against the rear window. Got really annoying after a week. I took a thin strip of the XCEL Foam padding and placed between the rear window and the top center brake light. Problem solved and it now sounds incredible.
    Before tuning and fixing that annoying rattle, I came really close to buying a sub/box combo like another member posted. It's smaller yet powerful and doesn't take up much space compared to others. It would have been easier than mounting that sub on the back panel but it's a pricey subwoofer. However - it would take advantage of the 800W amp.
    https://www.crutchfield.com/p_136S11...AE.html?tp=112
    Overall, I'm very satisfied with the sub and amp combo. I don't need any more bass. I use the MMI to turn down the bass (Bose system doesn't give you the sub setting in MMI) when needed. I have another project - mounting a pair of rear laser jammers. When I start that, I'll run the remote sub level switch that came with the amp somewhere up front on drivers console. I listen to a variety of music and going into the MMI to adjust the bass is not always convenient.
    Pic below shows the sub and LC2i. I placed the foam rubber padding on the bottom of the trunk and on the side wall. Also used some 3M double sided tape which keeps everything in place. Spare tire fits fine with room to spare.
    Very happy with the sound now. Wish I had done this when I first bought the car. So much better sound now.
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    I don't have a brown and grey wire 🤔
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
