Hi Guys,
This may be a simple question and just want your guidance. I have this b6 1.8t quattro in my possession that suffered a head gasket issue. Problem happened on cylinder 2 wall and it's evident due to the big water stain, all the other cylinder walls look perfect. the surface does not feel rough, feels the same as the other cylinder walls, there's no score or scratch. here are my questions:
- Can I do a replacement head gasket and leave cylinder as it is?
- clean the area but not rough it up? like using a super high grit sandpaper with oil and just move the piston all the way down
- if above is not possible, do i need to hone every cylinder or could I hone just the affected one without causing a catastrophic problem?
I'm already replacing the cylinder head since it was cracked on cylinder 2 and I'm not going to be adding more power or anything of the like. Car is staying stock with k03s and no chip, it's an economy daily driver.
Thanks for the help :)
