Originally Posted by
gta7
I am a techie for sure but mostly PC, Linux and iOS. In other words no android. I've read about side loading apps on to the Fire. Were you able to install the obdeleven app on to the Fire?
Here is the procedure I used to get the OBDEleven App on my Amazon Tablet. There may be an easier way, but this one worked for me. I copied the language below from this website: blog.the-ebook-reader.com/2016/07/02/how-to-install-google-play-on-fire-tablets-the-super-easy-way-no-pc-or-root/
Step #1: Prepare Your Fire Tablet
Go to Settings > Security > Enable Apps from Unknown Sources.
Step #2: Download Google Apps
You need to download 4 different apk app files. The easiest way is to download them to the Fire tablet directly.
Update: If your Fire tablet has Fire OS 5.3.1.1 or 5.3.2 and up, then use these newer apps from this post at the XDA forums (
http://forum.xda-developers.com/amaz...-fire-t3486603) instead of the older ones shown in the video.
Likewise, if Google Play suddenly stopped working on your Fire tablet after updating then install the top two newer files from the XDA link above, Google Account Manager and Google Services Framework. Then restart the tablet and it should be good to go. That worked for me after the 5.3.2 update.
Older firmware still works when downloading the top 4 apk files from here: Archive.org (old files) (
https://archive.org/download/GoogleP...4.521174655036).
Or you can download all 4 in a zip file from here: Google Drive (old files) (
https://drive.google.com/uc?export=d...E0xeDFqWXlBY0E).
Note that if you use the second option you’ll also need to install a file manager app such as ES File Explorer to extract the zip file.
Step #3: Install Google Apps
Use the Fire tablet’s Docs app to locate the downloaded apk app files to install them. Generally the default location is Docs > Local Storage > Download if you used the web browser to download the files above.
The Google apps need to be installed in the following order to work:
Note that if you are using the newer apps from XDA then follow the order listed over there, but it should work either way.
Google Play Services
Google Play Store
Once that’s finished you can open the Play Store and sign in to your Google account.
Step #4: Update and Restart
After you open the Play Store for the first time you need to install the YouTube app and then open it. This will prompt the Play Store services to update to the latest version, an important last step. Once the update is installed (it takes awhile), power off and restart your Fire tablet.
Now the Google Play Store app should be good to go!
Sent from my iPhone using
Audizine
