Originally Posted by
ShadowSmitley
That's definitely your issue. The left pin is corroded so it is not letting the bulb holder contact the metal to send the current to the bulb. The whole black piece comes off and you should be able to clean it. pretty easily. Just be careful as things tend to break easier when they are already corroded.
Not sure what that's called. Oxidation? Corrosion?
I never really learned how to care for electronics yet.
Not just the subject of how to remove any corrosion (such as what tools, chemicals, etc. are required)
but also the final step of protecting it after.
Because for example, if you are mechanically abrading the surface, maybe you strip it down to bare fresh metal. Which is then exposed to the outside environment.
I hear one product is called Stabilant 22A. It's probably expensive. I heard it might be favored over dielectric grease, for use in connector housings, because they have metal pins inside.
IDK if this gets applied at the factory.
Oh look, Audi and VW logo branding.
But at this point if OP is already taking apart, maybe it doesn't matter and isn't that big of a deal.
I mean, let's say he puts it back together and it works for another 5 years until having to do it again.
Would a chemical make it last 6 years?
Who cares.
Maybe this is more of a concern for a factory assembly line, to extend the life of the car as much as they can, so it doesn't corrode early in vehicle ownership, and everybody starts complaining about how their low-mi fancy Audi is having issues.
Ordering something like that, you're waiting for it to ship.
Versus fixing something by hand right now.
Maybe you'll need to get creative with a fix. A cut piece of emory cloth or sandpaper wrapped around a Q-tip?
Not sure.
Maybe whoever buys the car next down the road, will have to do it again.
