I replaced the car battery and coded it in VCDS in hopes that this would solve the issue. With a 5 year old battery that wasn't looking so good when I checked it in VCDS, it seemed like a sure-fire fix. Nooope, same problem.
Anyone got any ideas on this at all? I removed parts of the log that have no faults listed since the text amount is limited.
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56
5F 6C A9
VIN: Redacted Mileage: 67000km-41631miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 1A250034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 382A20B342D3A9D7A3A-806C
1 Fault Found:
6492 - Sensor for Ambient Air Temperature (G17)
P0073 00 [045] - Signal too High
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 66981 km
Date: 2017.08.10
Time: 14:05:05
Engine speed: 1521.00 /min
Normed load value: 18.8 %
Vehicle speed: 0 km/h
Coolant temperature: 36 °C
Intake air temperature: 36 °C
Ambient air pressure: 790 mbar
Voltage terminal 30: 10.765 V
Unlearning counter according OBD: 40
Engine speed: actual: 0 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 93.75 °C
Engine: operating status: ES
Engine load: 0.000000 %
Vehicle speed: actual: 0 km/h
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 291D1A
Shop #: WSC 06325 000 00000
VCID: 045284434E1B3D377F2-8050
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:06
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0022
Hex Value: 0x338D
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H11 0621
Revision: 00002001
Coding: 0D804000000000000000
VCID: 015C8D575109281F544-8054
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2312000178985012
2 Faults Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 138
Mileage: 66652 km
Time Indication: 0
Date: 2017.07.24
Time: 06:41:59
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:22
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Component: KLIMA 3 ZONEN H04 0121
Revision: C1000000 Serial number: 01090820122062
Coding: 6602228000
VCID: 392C25B77959B0DF5C4-806C
2 Faults Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:04
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 6
Fault Frequency: 3
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:17
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000462928301
Coding: 26008011813CAFE0210040C300003D0D4F9CD388A209022100 0008004000030100000030000000
Shop #: WSC 09532 003 104857
VCID: 78AAE0B302D369D763A-802C
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 070812 H15 0080
Serial number: SWF12080075028
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20496662
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000108121378
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R2HFB02
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: A1B84E36000000000001
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:04:56
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 138
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 14:38:12
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 983 P HW: 8T0 920 983 P
Component: KOMBIINSTR. H35 0556
Revision: 00100000 Serial number: V2C25772E
Coding: 83BF01008301D705020000
VCID: 4BC06F7F23C5324FFE8-801E
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:04:58
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0181855134
Coding: 0106069A00FA400582B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000552261
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:22
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000081754
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
1 Fault Found:
461568 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 98
Mileage: 66981 km
Date: 2017.08.10
Time: 14:05:16
Voltage terminal 30: 13.2 V
Internal Fault ID: 147
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
5F 6C A9
Revision: --H07---
1 Fault Found:
P0073 00 [168] - Signal too High
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 67000 km
Date: 2017.08.10
Time: 19:56:24
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 57 °C
Intake air temperature: 50 °C
Ambient air pressure: 800 mbar
Voltage terminal 30: 11.984 V
Engine speed: actual: 1248 /min
MAF_ENVD: 98.04706 mg/stroke
Coolant temperature (unfiltered): 90.75 °C
Engine: operating status: IS
Engine load: 3.906250 %
Readiness: 1010 1101
Coding: 291D1A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 20:13:22
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0022
Hex Value: 0x3392
Hex Value: 0x0000
Revision: 00002001
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:32
Coding: 6602228000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:27
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:27
Coding: 00FD11
Coding: 02005D
2 Faults Found:
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:27
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 138
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 20:14:47
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:28
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:32
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Date: 2017.08.10
Time: 19:55:30
Voltage terminal 30: 12.1 V
RWU: not active
DSD: not active
HTR: not active
ECD: not active
5F 6C A9
Revision: --H07---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 66981 km
Date: 2017.08.10
Time: 14:05:05
Coding: 291D1A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:06
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0022
Hex Value: 0x338D
Hex Value: 0x0000
Revision: 00002001
2 Faults Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 138
Mileage: 66652 km
Time Indication: 0
Date: 2017.07.24
Time: 06:41:59
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:22
Coding: 6602228000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:17
Coding: 00FD11
Coding: 02005D
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:04:56
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 138
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 14:38:12
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:04:58
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 98
Mileage: 66981 km
Time Indication: 0
Date: 2017.08.10
Time: 14:05:22
1 Fault Found:
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 98
Mileage: 66981 km
Date: 2017.08.10
Time: 14:05:16
RWU: not active
DSD: not active
HTR: not active
ECD: not active
5F 6C A9
Revision: --H07---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 67000 km
Date: 2017.08.10
Time: 19:56:24
Coding: 291D1A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 20:13:22
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0022
Hex Value: 0x3392
Hex Value: 0x0000
Revision: 00002001
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:32
Coding: 6602228000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:27
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:27
Coding: 00FD11
Coding: 02005D
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:27
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 138
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 20:14:47
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:28
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Time Indication: 0
Date: 2017.08.10
Time: 19:55:32
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 139
Mileage: 67000 km
Date: 2017.08.10
Time: 19:55:30
RWU: not active
DSD: not active
HTR: not active
ECD: not active
