The bulbs I will be reviewing are as follows:
OSRAM Xenarc Night Breaker Unlimited
Philips Xenon X-treme Vision gen2
A quick comparison of the bulb differences:
Before ordering, I reached out to Powerbulbs customer’s service team to as a few questions about these bulbs. The advice received was accurate and the customer service advisor kept me updated on the progress of my order. These were purchased using a 20% off discount code (NEWBIES) which should still be active, if not a quick google search to help find a code. Osram and Philips have been tackling counterfeit bulbs so both these have an authenticity sticker to check they are genuine. Not to mention Powerbulbs are the approved distributor for both brands so you are sure to be receiving the genuine products. You also receive a free 12 months warranty with Powerbulbs should any item fail within that period, simply return them back for a replacement, not to mention the free worldwide shipping.
Osram Genuine Check
Philips Genuine Check
They are both very well packaged and arrived very quickly. A quick overview of the packaging:
I went about to get them installed and to compare the difference between all three. Below is a few pictures of the OEM bulbs.
Standard OE Bulbs
As you can see from the above picture, the colour temperature is warmer than the Philips and Osram bulbs.
Philips X-Tremevision gen2
Osram Nightbreaker Unlimited
Summary
As you can see, both bulbs are a very good upgrade from the stock bulb, although the Philips just edges ahead in terms of colour temperature and light output. They both throw out a lot further too. Regardless of which one you go for you will see a noticeable difference at night that will help elevate the eye fatigue occurred on long journeys. Just make sure you do get the genuine bulbs, they are miles apart from the counterfeits and cheap Chinese knockoffs, which provide a false economy.
Any question, let me know.
