I was thinking about one of my gripes that has been coming back after doing a mech unit repair a few years ago. With the warmer weather I was noticing that if stuck in bumper to bumper traffic, my transmission starts shifting terribly. After parking it especially over night, it seems to go back to normal, but whenever I have a bad shifting day, the car seems to not quite drive like it did before. Just so happened an ad from APR popped up in the forum and this exert got me thinking :
Temperature management is an important part of the DL501 transmission. While some may simply remove temperature protection routines all together, or mistakenly raise temperature protection torque limiters sky high and claim increased cooling performance due to zero transmission intervention, APR’s TCU upgrade only allows the maximum safe temperature levels before intervention. Under high stress scenarios, such as launch control, the transmission’s cooling pump runs at maximum speed until the desired transmission temperature is achieved.
Unlike the factory intervention routine, which allows for nearly no torque to be transmitted through the transmission at all after limits are crossed, APR’s over temp intervention allows for a limited amount of torque, enough so the vehicle can be safely driven off the track or pulled to the side of the road during intervention. In keeping the vehicle moving, airflow continues across the radiators, which in turn keeps coolant temps low and aids in removing heat from the factory DL501 oil coolers to restore full operation.
Do you think a lot of the gear box malfunctions are a result of overheating? Well based on the information posted below, I think that is a resounding yes. I have the v1 of the DL501.
Does anyone have any information on how the cooling system works on the DL501?
http://www.audizine.com/forum/showth...tronic-(DL501)
I'm curious if there is some type of test I can do to make sure my cooling system is functioning ok, or as most enthusiasts are rightfully thinking - modify it for cooler temperatures. To date we seem to just say 'replace the mech unit' without giving much thought to root cause. I feel if that is found, the S4 could live a long life with the DCT transmission.
