Alright well I'm having my first issue on my audi a4 b7 2.0 6 speed.. I was driving a little fast and I went to shift quick into 3rd and seemed hard to shift and so I put it back into neutral and was hard to shift it into neutral and then immediately felt tjr clutch pedal was looser and stopped and then couldn't move the car or start it in neutral so I thought the clutch was bad.. started it in 1st and it will stumble to start but super hard to change gears like clutch dlave isnt fully pressurized and engaging but wasn't super hard when filly pressed down to shift like it is now to the point the pedal won't even go down..... replaced the clutch slave assuming that was the issue and now after I bled it.. the pedal is so hard it won't even go down and don't want to force it and snap or break something. Done a bunch of research and everybody says it's something with my clutch fork or pressure plate but the pedal wasn't hard when it originally broke down. Any answers or opinions would be appreciated as I'm baffled now that the clutch pedal can't even be pressed down now..
