Results 1 to 21 of 21
Thread: Magnetic ride
    Apr 16 2017
    vancouver
    Magnetic ride
    I would like to know if magnetic ride was a must in your wish list when you purchased the S3. What is the difference between the one without? I have read and watched videos about it and still not sure what it does.
    Most importantly, any issues so far?
    Thanks for feedback
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    Quote Originally Posted by donot521 View Post
    Thanks for feedback
    Read here and here
    In a nutshell, you control the firmness of the dampers via Drive Select or the vehicle setup in the MMI.
    I have the MAG ride, and for those daily commutes I have the dampers set to comfort however once on the freeway, I prefer a firmer damper ride.
    If you plan on upgrading your suspension I'd opt out of the MAG ride - save the $$$.
    Hope this helps.
    Senior Member Three Rings sean_entrust's Avatar
    Feb 11 2017
    Portland OR
    I have mag ride. For me it was a must. I bought this car to be a fun and also nice daily driver so I had no plans on going coilovers or anything. I put some 034 springs on which are designed to work with mag ride and the car is perfect now!
    2017 S3 P+ (Mine) Daytona Gray Pearl / Black Optic / Carbon Fiber Package / 034 springs / Stoptech BBK / 12.94 @105.3mph stock
    2012 Q5 P+ (Wife) Ibis White
    Feb 27 2012
    2016 Porsche GT3 RS
    Marin, CA
    Mag ride was a must for me. Car is my daily driver and the older I get, the less I want a car that punishes me. Firm and compliant is ideal.
    If you are a serial modder or want to track this car a lot, probably go non-mag and get a good set of coilovers.
    Veteran Member Three Rings mossback's Avatar
    Feb 01 2015
    2017 Subaru Outback
    United States
    if you plan to track the car, coilovers are your best option. this version of mag ride are very much at the low end of the mag ride systems. i might have kept mine in if i could have tuned it more than the 2 settings.
    2016 TTS
    Feb 11 2017
    Portland OR
    Quote Originally Posted by mossback View Post
    Do you think there will be anyway to tune them further in the future? Which part is low end? The software, the hardware or both?
    Feb 01 2015
    2017 Subaru Outback
    United States
    I suspect both, they felt really 'spongy' to me on the track, nothing I could to do to fix that, it was a strange feeling, like the dampers could not keep up. I have read reviews of other cars with mag ride and they were praised at their competence. Pretty sure no one has said that about the TTS version. I installed Bilstien clubsports (double adjustable, linear springs, retail around 4500.00) I was able to get around my local track 2-3 seconds a lap faster, with less drama. The mags would skitter across tarmac braking ripples, the clubsports when set appropriately do not.
    2016 TTS
    Feb 16 2004
    Bay Area
    Thanks for feedback
    If you are set on changing the shocks to coilovers anywhere down the line, it would be cheaper to start with a car that does not have MR suspension to begin with. Otherwise you'll need to purchase cancelers to intercept the signal. Feedback on MR is VERY mixed. I would not suggest you take input based on what forum users say. Many enjoy the functionality of MR, and others find that the MR rides poorly with factory springs. Some even note that it gets worse with lowering springs. Having spent many years tuning performance suspensions, in my opinion, the spring rates are a bit off on this car. It could use a little bit more rate in the back to even things out. 034 Motorsports seems to think the same as they have mainly concentrated on increasing the rear rate by 50lbs.
    There are currently no MR shock controllers on the market. DSC offers MR tuning at a very reasonable cost, however they do not have an Audi offering yet. I have started a thread to encourage people to sign up to show interest. It is located here, http://www.audizine.com/forum/showth...etter-handling. DSC has said that they are currently back logged with cars that they had already planned on developing and will begin Audi development in 2018. I highly suggest you visit the link and also sign up on the DSC interest page. The more people that sign up, the faster development will happen.
    Having looked at the reviews many of the other MR cars experience very similar tendencies to what S3 owners say as well. DSC provides upgraded programming and FULL user adjustability to fine tune. Reviews from other makes suggest that the primary issue with MR is poor programming. This is the case with Porsche, Chevy, Nissan, etc. I believe that with better programming we can not only get the cars to handle better, but also ride better. We should also be able to do some fine tuning with increased spring rates as well.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
    Active Member Two Rings McFarland's Avatar
    May 30 2015
    How much did the 034 springs drop it? I've been looking at them.
    Feb 16 2004
    Bay Area
    Quote Originally Posted by McFarland View Post
    Officially .75". Here's the best review with pictures so far, http://www.audizine.com/forum/showth...Springs-Review.
    May 30 2015
    Great review. Thanks. Your car looks great.
    Quote Originally Posted by rex_racer View Post
    Mar 18 2017
    PA
    I wanted it on my car for the adjustable firmness. There is a very noticeable difference between Dynamic and Comfort with the suspension. I use comfort when driving with the family or on the highway. Dynamic for twisties and aggressive driving. One thing I will note and maybe it's just in my mind, but under my "Individual" setting I have everything set to Dynamic except suspension which is set to comfort. When driving in "Manual" mode in this drive mode the exhaust doesn't seem as loud as when I running the car in "dynamic". I know in Dynamic the car has the transmission in "S" mode, but I like to use Manual since "S" mode seems to just want to hold gears longer than needed before upshifting. "D" mode is just a race to 6th gear imo, and then it loves to hold the car there unless you give it more than 25% throttle.
    '17 Daytona Grey S3
    Premium +, Dynamic Package, Tech Package, Sport Seats, B&O
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    The Mag Ride in the S3 is good if you have the right spring mated to it. The OEM spring lacks in many ways and so do a lot of the aftermarket options. MSS has developed a particular solution that not only increases performance considerably over the stock springs whilst retaining a very composed ride, better than stock.
    I know there are many people out there that agree with me that the mag ride settings don't differentiate as much as they should with the OEM springs. With MSS Kits each mode feels noticeably different between the modes and operate as you would expect it to in each respective position.
    I assembled this page to help explain how each kit works. All we know is the Audi MAG Ride is highly capable, just needs the special touch from the Aftermarket to make that happen. :)
    Let us know if you have any questions.
    Thanks
    Greg
    Feb 16 2004
    Bay Area
    Quote Originally Posted by ADM17 View Post
    So you know, the transmission in Manual mode has a D version and an S version, which is why you're getting less audibles with your Individual setting. Manual in S mode will shift quicker and is more audible.
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    As a follow-up to the 034 Motorsports springs, (great guys by the way) I would only expect to see .5" drop. That is what I saw in my mag-ride '16 S3. I am fine with that BTW.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Mar 18 2017
    PA
    Really? I thought the trans had "Manual", "D" and "S" and they were all separate. So, do I need to select "S" mode and then switch the trans over to "Manual"?
    '17 Daytona Grey S3
    Established Member Two Rings S3owner's Avatar
    Jun 16 2016
    Ontario
    Yes, 'S' then manual acts different than 'D' then manual.
    Missano Red II S3 Quattro 2.0T - H&R Sport Springs - Spacers 10mm/17.5mm - Sound Enhancing Resonator Delete - USmillWorks tow hook bracket - Pinalloy carbon key fob cover - Carbon Fiber mirror caps - matte black diffuser
    Instagram
    Feb 11 2017
    Portland OR
    Quote Originally Posted by S3owner View Post
    Why do our cars not show S1,S2, etc? I never knew there was a Manual sport mode because it just shows M1,M2, etc.
    Mar 18 2017
    PA
    welp, I'll have to give this a shot on my drive home. Thanks.
    '17 Daytona Grey S3
    Jun 16 2016
    Ontario
    Quote Originally Posted by sean_entrust View Post
    One obvious indication is manual S keeps the rev higher when idling. I was told that shifts are faster in manual S as well. I'll try to switch between manual D and S and pay more attention to test this today.
    Sent from my STV100-1 using Audizine mobile app
    Instagram
    Jul 27 2015
    Ontario
    You may need to venture into the higher tiered models to look for that option however I may be wrong. A TCU tune may also provide S mode shift points.
