Results 1 to 13 of 13
    Established Member Two Rings Nczcar01's Avatar
    Jul 30 2017
    Conyers, GA
    Just finished new tensioners, chains, guides A4 B8
    Top two pictures are before, last two after all assembled. Comparing full view pictures on the left, you can definitely note timing chain stretch when you look at distance between chains inside the two main guides. After initial and properly timed installation (all marks and colored links aligned) I turned the engine over CW numerous times thinking I would eventually get all timing marks and colored chain links to align once more (as a double check before I buttoned it all up). After about 50 revolutions by hand (with plugs out of course) I gave up. Later read Audi reference that stated it would take about 160 revolutions of the engine to return to the initial position with all timing marks and colored chain links lining up. Mmmmm....only 110 to go. Don't think so.
    Replaced serpentine belt tensioner and idler pulley, belt too.
    Not too bad, just took my time. Car runs like a top now, much smoother. New plugs and R8 coils too.
    117k miles
    Sorry for the horizontal picture orientation...they were correct in my files
    Jul 30 2017
    Conyers, GA
    Couple more before close ups...especially of the old tensioner. If you compare the right picture of old balance shaft chain tensioner (smaller one below cam chain tensioner) to the full "after" picture in the first posting, you can see how much more the old tensioner was extended.
    Removing the bottom timing cover was a tedious process to avoid bending the cover. Used a couple of beveled stainless steel putty knives to break the sealant bond around the perimeter of the cover (pushed in between mating parts). Probably broke the bond ~75% the way around and was easy to remove without damage. Installed latest revision of front oil seal, cleaned and degreased both surfaces. Sealed tight, no leaks.
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    excellent work....good on you!
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Jul 30 2017
    Conyers, GA
    Thanks, this old fart of 65 had some fun doing it. 6 sp manual is a ball of fun with that little 2.0L turbo.
    2010 Audi A4 Quattro 2.0L 6 sp mt
    2022 Ford F-150 Platinum 3.5L
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
    May 12 2017
    Quote Originally Posted by Nczcar01 View Post
    us old guys still have fun!
    like your scooter collection, too, btw!
    Billy
    Avatar Chart
    Jul 30 2017
    Conyers, GA
    Hey, just saw yours..wow! Makes my two look like Ned and the First Reader...
    I looked for years for a K100 when I ran across and settled for the GL500.
    Wife says I have too many toys. Nahhh
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
    May 12 2017
    never!
    Billy
    Avatar Chart
    Jul 30 2017
    Conyers, GA
    Sweeeeeet!
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
    May 12 2017
    thank you....
    70k miles, upgraded suspension, brakes, intake, fuel injectors, exhaust, etc.....
    Billy
    Avatar Chart
    Jul 30 2017
    Conyers, GA
    Bill, Should be very proud of that one...don't see too many around, regardless of condition. I looked on and off for several years and never pulled the trigger. Found a few K75 and K100 bikes overpriced and maintenance not kept up to date. A few nice ones were snapped up before I found them. Unfortunately, do not ride as much as I did but still have fun from time to time with the toys. Those two grandkids keep Pappa pretty busy these days.
    Btw, ever check to see if you have latest version timing chain tensioner in those 2.0L's?
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
    May 12 2017
    yep, same here......not nearly enough time to enjoy the scooters these days....
    on top of that, i prefer the guzzi these days......it has floor boards....lol....
    wife's car is good, just got my A5 a little while ago....still in the process of wringing every thing out.....but stethoscope inspection was positive....
    i will dig deeper to confirm.....& thank you for mentioning it!!!!
    Billy
    Avatar Chart
    Jul 30 2017
    Conyers, GA
    Audi A4 pic
    After all work done and cleaned up a bit
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
    Jul 30 2017
    Conyers, GA
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
