Results 1 to 9 of 9
    Mar 23 2008
    Queens Ny
    Front lower control arm torque specs
    Does anyone know the front lower control arms to subframe bolt torque specs all the pictures on the site all dead cant seem to find any showing with pics.
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    It's will mentioned in this video right at the end, I've done recently but can't recall :)
    [url]https://youtu.be/rd31p-BmQGg
    B7 2.0TQ Avant '08
    Oct 24 2015
    Perth, WA
    My respray thread
    Mar 23 2008
    Queens Ny
    diagram pics are dead but got it thanks !
    Mar 12 2016
    The land of Kiwis
    Oh sorry man pasted the wrong link :(
    B7 2.0TQ Avant '08
    Mar 23 2008
    Queens Ny
    Lol no problem found that video thanks!
    Oct 24 2015
    Perth, WA
    75 Nm Engine Bay Bolts (f)
    40 Nm Upper Control Are Bolt
    90 Nm (66 lb ft) Lower Shock Clevis Bolt (f)
    60 Nm Shock Shaft Nut (f)
    35 Nm Upper shock mount to body (r)
    160 Nm + ΒΌ turn Lower shock eye to lower control arm (r)
    http://www.vaglinks.com/Docs/Audi/B7...on_Install.pdf
    My respray thread
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Make sure you torquethem down with load on the suspension
    What ever makes sense go with the opposite and you got it
    Mar 12 2016
    The land of Kiwis
    Yes that ^
    B7 2.0TQ Avant '08
