My wife has a 2010 Q5 with the 3.2L motor in it. Trying to get it ready for inspection and its throwing the P2432 secondary air injection system code on me. I've searched the depths of the internet and I can hardly find any info on how to fix it. Here's what I pulled up from the vehicle with my Vagcom. Really hoping I can get some help here, I've always been able to find what I need on Audizine for my S4 and A4!
Address 01: Engine (J623-CALB) Labels:| 06E-907-559-CAL.clb
Part No SW: 8R0 907 559 G HW: 8F0 907 559 A
Component: 3.2 SIMOS8.2 H06 0004
Revision: --------
Coding: 0121000A190F0121
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
ROD: EV_ECM32FSI.rod
VCID: 44D245F8AE140A273F2-8010
2 Faults Found:
6524 - Throttle Body (J338)
P1559 00 [032] - Fault in basic settings
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 184982 km
Date: 2017.07.17
Time: 17:25:38
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 96 °C
Intake air temperature: 31 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.288 V
Unlearning counter according OBD: 28
V_TPS_1_ENVD: 0.72266 V
V_TPS_2_ENVD: 4.25781 V
Coolant temperature (unfiltered): 96.8 °C
Intake air temperature: 31.50 °C
Battery voltage: 12.289063 V
Vehicle speed: actual: 0 km/h
8617 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
P2432 00 [175] - Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 168077 km
Date: 2017.04.03
Time: 16:57:56
Coolant temperature: 62 °C
Intake air temperature: 54 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.984 V
Unlearning counter according OBD: 40
Engine speed: actual: 1120 /min
MAF_ENVD: 201.54117 mg/stroke
Coolant temperature (unfiltered): 34.5 °C
Engine: operating status: IS
Engine load: 25.000000 %
