Originally Posted by
Davdraco1
I was reading your post and about halfway thru I thought to myself, clearly he's never tried greasing the 034 set up. It took me hours to install mine. It's NEVER coming out. But good info!
Seriously, the setup is so needlessly complicated. Had to loosen the gas-tank AND the subframe to get those last bolts aligned. Then spent an hour or so just tightening down that ONE bolt on the passenger side (you know the one I'm talking about) with an open-ended wrench 1/4 turn at a time, because you can't fit a socket or a box-end wrench on it. What a PITA.
I actually bought a new set of the metal c-shaped brackets (the ones that hold the bushings) from 034, and I'm going to try drilling holes into them so I can install grease fittings. You'll notice that the bushings themselves already have those holes cut into them...most of 034s setups for new platforms come with holes in the metal brackets for grease fittings. But they opted NOT to do that for the B5 setup because....reasons.
Frankly, I'm not even sure if grease fitting is possible because of how close the damn thing is to the gas tank! Getting annoyed just thinking about it...
