Until I got acquainted with it and pulled it outside.
I had worked at an Audi dealership a few years ago and got to experience all types of Audis, but something about seeing this car roll out of a cramped garage into the sunlight and hearing the blower motor running even with a dead battery, I fell in love. This car needs a LOT of work to be road worthy, so the first order of business is to assess specifically what needs to be addressed to drive this thing. After making sure I can fix it for less than it would cost to just buy a nicer S8, I'll move forward.
My lease ends at the end of August so this is going to be a 30 day build thread and I will do my best to post each day with what I did. Get ready for some seriously regular content! I've never done any sort of serious project like this and I'm super excited to share it with the community.
DAY 1:
Today I started by running extension cords to the garage and hanging up lights so I can work late into the evening, run a fan and just generally have power in the garage. I had a buddy come over to check out the car and we jacked up the front end and pulled the wheels off. I knew the front rotors were shot from when I'd purchased the car but seeing them up close without wheels on... Wow
And a closer view:
Other things I found, it needs every CV boot in the front replaced, might need a trans output shaft seal on the Driver's side, needs an oil pan gasket, valve cover gaskets, rotors, pads and a battery. I noticed that there was oily wetness around the electrical connector for the trans towards the front of the car.
Good news though, it appears that all of the control arms have been replaced at some point as the ball joints look to be in good shape and most of the bushings on the frame side are very driveable! Also there appears to be no structural damage to the front end of the car at all. The damaged fender that is now missing likely was just damaged on the surface.
It seems that this car had been driven in winter and covered in salt then stored before getting a car wash, because virtually every piece of steel I've run into has been rusty. The block and heads are showing a good bit of surface corrosion, and there is white powder (assuming that's salt) all over the engine bay.
My goal is to get the front clip back on and start the car up to verify that the engine runs and the trans shifts okay. If everything checks out, I'll proceed with purchasing the "road-worthy" parts and doing those jobs. I've got a spreadsheet going to keep track of costs and have three categories of parts. Tomorrow's plan is to jack up the rear and see what needs fixing back there.
Should I throw new oil in it just for an initial test startup? It's been sitting for over a year, but I don't want to spend all that money on a full oil fill only to have to drain it to handle the oil pan gasket.
Needed to run:
Trans fluid
Trans filter
Trans pan gasket, drainplug and seal
Electrical Connector O-Rings for Trans
Replace front clip
Battery
Front Brake Rotors (To test transmission ability)
Needed to be roadworthy:
G12 Coolant Fill
CV Boots (All fronts)
Trans output seal
Brake pads (front)
Battery
Fender
Needed to be a daily:
Oil pump coolant tube things and reseal
Front Bumper
Timing belt and water pump kit (Blauparts Enhanced would be great)
Oil Pan
A/C Line Compressor to Condenser
Valve Covers
See you all tomorrow!
