Originally Posted by
endy1
No more source then that my engine drinks that much and when i asked Audi about it, they said it was "normal".
Dident bother to dig deeper into this because i get my oil for free at work...
The faulty 2.0 drinks way more then mine does.
Good to know. I just checked my dip stick and the range of oil seems to be normal, but I guess that's something ill check every couple months from now on since it's so easy. MMI oil level is at max as well (but i've never seen that change)
shonseb
I believe oil changing interval depends on the way the car is driven. I usually change mine on both my cars no longer than 5k miles. That being said, if I took my car on a weekend running hard, I would change around 3k miles, even as low as 2k miles. I also believe that people who live in big cities that require a lot of stop and go with RPMs reaching 3-4k or more quite often should have more frequent oil changes. This compared to someone who lives in suburbs or rural areas who usually travel for miles at cruising speed. I don't believe in a universal time or mileage for oil change frequency but I wouldn't go longer than 5k miles and definitely not the manufacture recommended 10k miles.
Good to know. All of my driving is short 2-5km city driving so maybe I should change it at 5k km. I do however drive about 300km every two weeks (in a single day). I also let the car warm up every time from cold start for 30s-1m. I don't know if that's enough to get all the oil moving around.
