I believe that everything is wired properly; I tried both the solid white and the white/red stripped wire off of the brake switch, same results with both. Verified that the other side of the switch is connected to pin 39 on the ECU).
This is what VCDS shows when the clutch switch is installed and the pedal is up. Cruise control does not engage.
This is what VCDS shows when the clutch switch is installed and the pedal is down. It's also what VCDS shows when I let the clutch switch hang. Cruise control engages.
At this point the only two options I can see is that my cruise switch has failed, or that I've spliced into the wrong wire on my brake pedal. Having already spliced into two different wires, I'm hesitant to try the other two unless someone is confident I've wired it up wrong.
