Results 1 to 36 of 36
    Veteran Member Three Rings arotished's Avatar
    Jul 04 2010
    Norway
    JE, Mahle, Vossner or wiseco pistons?
    Looking for pistons for my second engine, gonna be 82,5MM and 8,5:1 (or 9:1) CR as I want to have the spool instead of high power on big boost.
    Still trying to get my head around which pistons to buy, I currently have REC pistons (8:1 CRin my engine but cant get a hold of REC anymore.
    Veteran Member Three Rings ElementR's Avatar
    Nov 23 2013
    2016 Stg 2 S6, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    I went with the Mahle Powerpack as they are the OEM supplier and the alloy they use allows for tighter clearances. Price wasn't bad either. I want to say around $650 IIRC
    2001 Silver/Black S4, Built engine, Tial 605's @25psi on 93 oct, ET Spec Tune, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
    2016 Silver/Black S6 Sport Package, IE Stg 2 E85 & DSG tunes, IE intake, ARM DP's & Mid-pipes
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    If you want to have good spool, don't even think about less than 9.0:1. I would use JE's. It can be difficult to find 9.0:1 82.5 mm pistons from the other manufacturers. At least I have find out that difficult.
    Where can you find 82.5 mm Mahles?
    Nov 23 2013
    Grosse Pointe, MI
    Mine were 81.5mm. I didn't catch the 82.5mm. Are you locked in on the 82.5mm bore already? If not, consider the 81.5mm.
    Jul 04 2010
    Norway
    82,5mm gives true 3L so I kinda want it. My current engine has 82mm which gives 2,945cc I think.
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    I have a set of 9:1 JE pistons already balanced if youre interested. They bump you up to 2.8l.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Mahle absolutely. I have no numbers to back my claim up, but I feel the sweet spot is going to be 9.5:1 on E85. I run 8.5:1 on my 1.8t and its a dog under 4k rpm.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jul 04 2010
    Norway
    These are normal stroke? I'm gonna have 3L crank on my new engine
    Jul 04 2010
    Norway
    Quote Originally Posted by JMTx86 View Post
    These are normal stroke? I'm gonna use a 3L crank
    Dec 14 2008
    Finland
    Quote Originally Posted by arotished View Post
    What is the advantage in spool up over 2,7l with GT size turbos?
    World's Fastest B5 Avant biturbo Full Weight
    With Race Seats @3800lbs
    TTE950+ 100-200kmh 3,81s
    Dec 05 2007
    I'm from the 1.8t world, but JE I have noticed always have the most complications and ironically cost the most than the other two listed (don't know about Vossner). Mahle is stock for the AEB block with a Mahle stamp on the pistons, and Wiseco simply has the best track record (haven't seen one documented mishap with these pistons). I have a spare block I plan on stroking out (currently on AEB Mahle pistons with Brute rods on an otherwise stock block, building a head on the side with a 530p turbo) with an FSI forged crank (already picked up) and plan on 83mm Wiseco pistons. But Mahle is also a good option. For the best, many go custom with one or more companies I can not recall the names of (built to order).
    Last edited by Seerlah; 07-27-2017 at 12:55 AM. Reason: neglected Vossner pistons listed
    Dec 07 2004
    Finland
    People say "Mahle Mahle Mahle", but show me where you can buy 82.5 mm pistons for 3.0 crank and CR 9.0 or higher!?
    May 11 2013
    Nnj
    can't you get custom pistons made to order?
    Jul 04 2010
    Norway
    Quote Originally Posted by okkim View Post
    You can get 9:1 at 82,5mm from Mahle but dont think you can get higher?
    Dec 07 2004
    Finland
    For the 3.0 crank?
    I don't know where to get those, I have never seen anywhere.
    Dec 05 2007
    For those who don't know, the 3L crankshaft creates a longer upward and downward stroke. You use the same stock length and journal sized specs for the rods, along with wristpin size. But with the longer upward and downward strokes, the pistons now must be more shallow to compensate. If not, the pistons would basically smash the cylinder heads on each upward stroke and it simply won't work. That is why they refer to them as stroker cranks. The upward and downward strokes will now be more than with the stock crank.
    Oct 03 2005
    Yes stock stroke
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    we know.
    2000 Achat S4
    Dec 05 2007
    I know most do. But people who stumble upon this thread may not, and I would rather educate than belittle (though I do like reading your posts with chuckles behind the keyboard and not placed in font, but you are an old school B5 head. if people don't know, purchased my AEB pistons and Brute rods off Jaychen years back in his Peasant Mobile days and still running them till this day...strong). So now people can learn more about motors, including the one they make combust when they place their foot on the gas pedal.
    Wasn't necessarily informing people in this thread, but those who may stumble upon it and want to be included in the thread. Can also help the OP out if those who are now more educated can possibly assist in sourcing 82.5mm stroker pistons with a 9:1 CR (compression ratio: 9:1 intake vs exhaust once pistons compress the air for combustion on the upward stroke to make it easy to understand but is more entailed, which has to do with what time the ECM grants spark which is ignition timing. things take time to fully combust, so you want to time the spark as much as you can in advance to produce the most powerful downward stroke before the ECM retards ignition timing). I'll look into those companies that make custom ones later. I think CP is one that is favored though, for custom pistons.
    Dec 05 2007
    Shit, reading comprehension 101 fail. OP wants stock stroke. Oops!
    Disregard some of my last two posts. Info still relevant.
    Feb 19 2011
    Earth
    you're a good dude. 10 year veteran stripes. came up from a foot soldier to a general.
    2000 Achat S4
    Dec 05 2007
    You're a good dude too. People just may get the wrong impression of you because of what I consider funny posts. lol
    Don't know how, but your posts end up on my profile page. hahaha
    Dec 05 2007
    Did some quick research and I think CP is the company I was referring to when it comes to custom pistons. Give them a call and see if they do it. Matter of fact, any brand you are interested in give a call and see if they will do a custom set for you. At that point, price point comes into play. But if you read the Wiseco piston descriptions (just learned this now), I see why they have such less (I have came cross none documented) failure rates. This is for the 1.8T 83mm stroker pistons, but wonder if it applies to the 2.7t also. Because if so...my vote still stands with Wiseco.
    Pistons I plan to run with on my 2L build later on, but the description may relate to the 82.5mm stock stroke pistons (research and find out): http://www.ringer-racing.com/product...categoryId=188
    Veteran Member Three Rings Cacti's Avatar
    Nov 10 2011
    MI
    Go with a 4032 alloy for more a of a daily driver.
    Dec 05 2007
    More research. This is the CP custom piston order form page. Looked into their catalog, and there is no piston for the 2.7t. But there is for the 1.8T, and how I know about them.
    http://www.cp-carrillo.com/pt-3507-pistons.html
    Feb 19 2011
    Earth
    Quote Originally Posted by Cacti View Post
    At what point does the need for 2618 come into play?
    2000 Achat S4
    Nov 10 2011
    MI
    A majority of the aftermarket piston companies only sell 2618, and also are a lot more customizable. VLM spec supposedly made 800WHP on stock pistons. I think I recall AMD doing 700WHP but running into issues with piston wring lands breaking. 4032 have less thermal expansion but can not take as much abuse as 2618. I think Mahle makes aftermarket 4032 with modified ring lands.
    Dec 14 2008
    Finland
    You can get Mahle 142 9,3:1 CR for 3.0l from Issam for a decent price. Custom CR is a lot more $$. But he lives on the wrong side of the pond :/
    Jul 04 2010
    Norway
    They make 92,80MM stroke pistons as well :)
    Dec 05 2007
    Supertech has an 8.8:1 CR 82.5mm for the 2.7t. Problem is QC (quality control) with QED, and not sure if his customer service is back up to par or not. Nothing wring with quality of parts (ie Gold Cams) other than a few mishaps, but nobody is perfect. Issue was him having health issues, iirc. But with 8.8:1 CR that is the compromise between 8.5:1 and 9:1 when 9:1 used to be the compromise for 8.5:1 and 9.5:1. Just another option if you can get your hands on them. Decently priced.
    http://www.qedpower.com/QED%20VW-Aud...ton%20page.htm
    Jan 05 2010
    burnaby british columbia
    I got an extra set of je 83mm 3l pistons 9:1comp on hand. They were installed in to short block and then pulled for another je set with different comp and enlarged valve relief. They are missing 2 oil rings that would be easy to replace. Pm me if interested. Let em go cheap.
    Sent from my SM-N900W8 using Audizine mobile app
    Mar 22 2013
    AK
    http://www.rec-tuning.de/de-schmiede...impressum.html
    Have you tried calling them ? PH# and e mail in above link.
    BTW REC uses Mahle blanks/forgings or at least used to.
    Jul 04 2010
    Norway
    83mm is kinda on the limit? PM sent
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    thank you and please keep at it bcz at least am reading an learning! subscribed!
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Dude update your build thread Arothished! We all thought you just said F-it after those photos of your oil pump
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    I had JE 83mm with 9.0:1 and 92.8 Stroke best setup ever ! What kind limit are you talking ? many people did big power and high boost on 83mm.
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
