Results 1 to 20 of 20
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Fuel Upgrade Ideas 3.0TFSI and upgraded 2016+ V6 TFSI EA837 Engine
    As you know 2016+ Audi A6,7,8,Q7 have a big upgrades on 3.0TFSI EA837 Engine Gen 4. I'm wondering if we can use 6 port injectors in our engine. This EA837 I think bad ass block and can handle it a lot more then previous model.
    12 Injector 6 Indirect and 6 Intake Port
    Upgraded Supercharger
    Upgraded Fuel Injectors
    Crank Case ventilation
    Modified bedplate with one vent hole only
    Factory 1mm cast iron sleeve
    Modified Pistons
    Larger Supercharger Intercooler and more
    Know we can use standalone unit with thouse Port injectors intake manifold)
    Available mods ?
    Autotech High Volume Fuel Pump http://www.autotech.com/mm5/merchant...de=10-127-101K
    here is the PDF Link on Russia language: https://drive.google.com/file/d/0B5f...ew?usp=sharing
    I'm wondering if EA837 Injectors better ? Could be next upgrade for us ?
    Here is EA837 Intake manifold 6 port injectors
    Here is Gen 4 EA837 V6 TFSI Engine Sorry I got only on Russian language.
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    Wooow....PDF is just amazing!!!
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
    Jan 09 2010
    New York
    Quote Originally Posted by Strong Man View Post
    This Engine should be made 10 years ago not in 2016 so much potential in this engine
    Jan 24 2017
    wooow...pdf is amazing!
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Our fueling issues aren't due to the high pressure or fuel injectors, its the low pressure side. Our OEM pumps are 450lph, but the bucket design limits its full potential flow. I have a 255lph supplemental pump, I'm actually have lots of headroom in terms of fueling and not yet reached the limitations of injector in terms of injector on-timing.
    If I could go back, I would have not installed my Autotech HPFP, it creates a starvation on the low-side at times until my 255lph (boost activated) kicks in. It simply amplifies the OEM's limitations imposed by the bucket design
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jan 09 2010
    New York
    Quote Originally Posted by Loe View Post
    Thanks for the information, did anyone try to modify the bucket? If we fix the flow from the tank then HPFP will do its job? I'll try and buy a used bucket to analyze if there is an opportunity to improve the flow from the tank. It turns out that the pump is almost like the WALBRO 450LPH FUEL PUMP E85? I had a current on 2.7 Single Turbo and without problems enough for 600whp full E85 with this pump
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by UkuRiSh View Post
    I think Mike(?) was looking into it, there is a thread about it somewhere.
    I have no regrets upgrading to the autotech HPFP, moved my Ethanol percentage ceiling up ~10%.
    Bucket mod on the stock LPFP would be awesome if we can figure it out. Cheap and hopefully move that ceiling up even higher.
    Geoff
    Jan 09 2010
    New York
    Quote Originally Posted by whiped View Post
    I had an Audi A4 3.2fsi with swapped 2.7 engine and I did modified the Bucket to install the Walbro pump, just wonder if the B7 bucket is similar to B8.5
    Jan 09 2010
    New York
    Also new generation of 3.0TFSI have 12 injectors they must put there better pump or bucket ?
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Maybe we can adapt the new S4 turbo fuel pump to gain more?
    I was told that our limitation wasn't the LPFP (if you have flex pump installed) but the HPFP due to it being driven by the cam lobe? Is that statement correct?
    I noticed that if my mixture is over E45, my car throws lean codes with 034 map.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Mar 24 2017
    UK
    That pdf looks like the CREC engine we have in the UK middle year 14 and onwards S4/S5's. I was told that there are 2 injectors per cylinder (which ties in with 12 injectors) and they were in different places. It also looks like it has the magnetic clutch unit on the supercharger.
    Mine tunes quite nicely thank you ;)
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by arad85 View Post
    Be careful spinning your SC too fast. Already hearing issues about the CREC engines SC's clutch slipping.
    Good thing we are starting to look at different cams right?
    Geoff
    Mar 24 2017
    UK
    Wonder which car the report of that came from...
    Jan 09 2010
    New York
    Those engine we have in US in 2016+ Audi A6,7,8,Q7
    Jan 09 2010
    New York
    Here is 3.2 FSI and you can see 3.0TFSI above ^^
    I think about this drawing, correct me if I'm wrong. It seems to me that the problem can be in the filter? In our cars the petrol system is adapted with a 3.2FSI motor and almost was not changed only the injectors were modified. The figure shows that the filter has two functions, the filter function and FPR. I heard there 3-4 bars? I plan to check the pressure before the filter and after the filter. If I was right then we can remove it and establish control over the low line pressure just add FPR, set the filter and increase the pressure to 5+ bar. Thank you
    Mar 24 2017
    UK
    You may well have, but my engine is the one that had the slipping clutch....
    Jan 09 2010
    New York
    I think the aftermarket parts and Stage 2+ type settings will appear on the market soon. Your motor has a lot of advantages than ours. Intercooler larger, a new sensor on it, a completely new fuel system, you will not have problems with the E85, the motor has a sleeve and the pistons have been worked. The tuning potential of this motor has grown much higher! I do not understand why you're not happy) Just wait a little time, will soon release improvements for this engine bro
    Mar 24 2017
    UK
    Oh... I'm very happy with the engine/car (stage 2 tuned at the moment).
    Feb 16 2019
    miami, fl
    has anyone tried these oem port fuel rails and intake runners vs doing the jxb alternative coming to market?
    Jan 09 2010
    New York
    Quote Originally Posted by wrxkyle View Post
    You have to swap head from the CREC engine! This secondary fuel rail is not a bolt-on. I tried before no luck so JXB and others custom port adapters is the way to go
