Results 1 to 21 of 21
    Nov 20 2016
    michigan
    Press clutch pedal to start engine
    Does that writing go off the dash when you push the clutch in?
    Established Member Two Rings gaben2racin's Avatar
    Jun 15 2013
    Roseville,CA
    Yes!
    And right after make sure you input this code:
    Up,up,down,down,B,A,select,start.
    Enjoy!
    Sent from my SM-G900T using Tapatalk
    Nov 20 2016
    michigan
    Quote Originally Posted by gaben2racin View Post
    Yes!
    Enjoy!
    Thanks! First time trying to start this car, I've wired the two wires from the clutch pedal sensor together to test if it worked. but that writing was still on the screen when I did that so I don't know what else is going wrong. Not sure what else to try
    I tried doing that to both sensors that are there but neither seemed to make the writing go away, correct me if I'm wrong but the clutch pedal sensor is the blue one?
    Established Member Two Rings timlog123's Avatar
    Apr 13 2012
    Ghost of a B7 RS4, B8 Q5 3.0T, Rupes and Gyeon stuff
    Estero FL
    Yes!
    Enjoy!
    I thought it was A,B,B,A,A,B,B,A,A?
    12 Spyder Suzuka Grey l Rev9 Res SS exhaust l
    Previous:
    Mk1 TT ALMS 6MT
    B8 S5 Coupe 6MT
    B5 A4 Avant 5MT
    B5 S4 6MT
    B7 RS4 Sedan. Still feel sick that its gone.
    B9 Audi S5 Glacier White Prestige Coupe “gone but not missed”
    Jun 15 2013
    Roseville,CA
    Haha.
    No that's the super pursuit mode one.
    Jul 15 2015
    Rochester NY
    Does that message stay there after you start the car? If not, then don't worry about it
    Veteran Member Three Rings caliizaktiv's Avatar
    Dec 20 2010
    Used Oil
    East Coast
    R+CC+R+CC+B+R+CC+B+Z = 1080 Air
    07 RS4 | 03 M5 | 24 RS6p
    Nov 20 2016
    michigan
    Quote Originally Posted by neilpaku View Post
    Yes it's staying on. The car won't crank at all even if those wires are in contact with each other
    Jun 25 2016
    Brisbane
    What about the other components in the start circuit? The starter relays and then the starter itself?
    I've just about replaced everything in that circuit due to an intermittent fault, which I suspect was a cracked and worn wire at the starter terminals. No point getting all that way and leaving a 10 year old starter in though.
    Sent from my F5321 using Tapatalk
    Nov 20 2016
    michigan
    Heres a more detailed description of the problem im having with pictures
    Whenever i push the clutch down the display on the dash keeps telling me that the clutch needs to be pushed down. So now from what i read online it said the clutch switch is probably bad
    So I tried to test each sensor by making both wires go in contact but the display on the dash still tells me to push the clutch down even after i did that.
    Theres also a light that blinks on the dash when i have the key in the ignition but im not sure if that has anything to do with this.
    If anyone can give me some insight on what else i can try or what the problem might be id really appreciate it
    http://www.audizine.com/gallery/show...g-2343&cat=500
    heres a picture of the light on the dash that blinks^
    http://www.audizine.com/gallery/show...-23411&cat=500
    Pic of wires i spliced together(pic went sideways for some reason)^
    http://www.audizine.com/gallery/show...-23461&cat=500
    One other thing that might have an effect on this is my key broke the other day so the fob isnt attached to the key anymore, but when i put it in the ignition i keep the fob right next to the key^
    May 18 2012
    2005 S4
    Portland, OR
    If the battery light is flashing I believe it may indicate a charging system problem. Is it a new battery?
    Nov 20 2016
    michigan
    No the battery I have is old but it holds a charge for a few hours. I had a battery charger on the car when I tried to start it
    I don't hear anything from the starter or relays when I turn the key
    It's not the battery light that's flashing it's the orange car icon with a key inside of it
    May 18 2012
    2005 S4
    Portland, OR
    Oh...that's the immobilizer. I'll have to defer to someone else on that issue because I have been fortunate enough to not run into it, but it may have something to do with the broken key.
    Nov 20 2016
    michigan
    From what I've read online the car should still start but it would stall out after a few seconds. But maybe it's different on these cars. I do have vag com if there's anyway I could use that to help diagnose something. I'm not to familiar with it though
    But even if it was the immobilized wouldn't the text on the dash still go off on the cluster about the clutch being pressed?
    Nov 20 2016
    michigan
    I did swap engine harnesses if that might have anything to do with it. Maybe I didn't plug something in all the way on the ecu?
    But I triple checked every connected to make sure it was plugged in all the way
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by unichipi View Post
    I believe that text only goes away after you actually start the car, not after you simply press in the clutch, even though it seems like it should. The reason I cannot verify this right now for certain is that my engine is currently out of the car, haha. Major cylinder wall scoring so I'm swapping blocks.
    Established Member Two Rings audi5inline's Avatar
    Jan 10 2013
    Audi RS2 avant
    The Netherlands
    did you only swap the harness or also the ECU ?
    '11 Audi S4 3.0TFSI
    '95 Audi RS2 avant powered by Porsche
    Nov 20 2016
    michigan
    Quote Originally Posted by audi5inline View Post
    Just the harness. I compared them before and they were exactly the same
    Nov 20 2016
    michigan
    Update: I do not believe it's a immobilizer problem. I think either the starters bad or I wired it incorrectly
    I have power to the signal wire running to the starter when I turn the key. My connecter to the starter was broken so it wasn't making a good contact. I tested that by just running an led to that wire and the other end to a negative then turned the key and the led turned on with it.
    So then I ran my own positive wire to the starter and I heard the solenoid engage but the large positive wire on the starter sounded like it was burning and some sparks fell from it. It didn't crank at all but the solenoid engaged. I tried this a few times with the same result
    So can someone confirm that I wired it correctly, there's two thick positive wires down in that area. I have the larger wire on the starter with I believe a 13mm nut holding it and the smaller one on the alternator. Then I have the ground mounted next to the bell housing on the starter then to the mounting point on the frame.
    I double checked it and there's nothing I can see causing it to short circuit. The only thing I can think of is that the starters bad and something inside is making it short circuit
    Nov 20 2016
    michigan
    Found the problem. Got the starter taken off and the wire that connects the solenioid to the main motor was completely corroded. I pulled it apart with my hand. so looks like I'll have to get a new one. Might just make my own temporary wire for that spot for now
    Nov 21 2019
    Racine
    Just replaced headlight bulbs with ds2 bulbs now my car turns over when I just push the clutch.... any ideas
