Oil leak from the side of the engine around the oil filter housing area.
A bit of background:
A year back when I bought this B7 I noticed that the thermostat is shot so I swapped it and the temp was fixed at 12 o'clock but right after that I noticed engine cover gasket started to leak so I changed it then after that it started to leak from the vacuum pump so I rebuilt it and finally the car was leak free till last weekend while I was swapping my engine mounts i noticed a new leak.... never ends... any way from googling it looks like the oil filter housing seal needs replacement.
1- Any tips from someone had same issue?
2- Anything else there in that area could be the cause of this leak apart from the oil cooler ?
3- Am I going to loos a lot of coolant ? Or a small top up with water will do?
Thanks heaps !
B7 2.0TQ Avant '08
