Worked on a buddy's 2.0t b7 this weekend doing the timing belt. We changed the timing belt, tbelt tensioner and the two idler pullies. Then checked the aligned marks for the camshaft and crank. We used the oem camshaft mark and turned the crank until the cam gear slit aligned with the cam mark on the block, then took off the crank pulley for the serpentine belt and then took off the lower timing belt cover. Then marked the crankshaft gear so we didn't lose the original positioning when the timing belt came off.
We also did the thermostat and the cam follower. Cam follower showed normal wear, no rough surface just wearing of the black coating down to silver.
Put everything back together, filled coolant up and everything and started car. Idled it for about 5 minutes or so to get it up to operating temp and everything was fine, no cel nothing except for the traction control light(battery was disconnected at negative terminal for thermostat change). Then checked coolant again and this time when we started his car the cel came on and read a p0016 camshaft crankshaft position error.
Assuming the cam and crank marks line up, is it possible we got a bad tensioner? We checked the work again and the tensioner seemed ok, but when we set the tension on the tbelt, the tensioner didn't seem like it was getting that much resistance like the serpentine belt... after rechecking everything and applying correct tension on the new ina tensioner, we cleared codes and started engine again. Same thing happened. After idling car for about 5 minutes, then restarting, then idling. Everything seemed fine. Timing advance during idle was 0* with slight fluctuations about 0.5*. As engine was revved up to 1.5-2k timing advance was higher and higher going up to around 20* or so. Then on the before the 3rd start we pulled codes to see if there were any, found p0016 again...
What could be wrong? Idling and everything seems fine, maybe a slight vibration from idle but nothing like an earthquake from a b6 s4 when the timing chain tensioners gave and engine was toast...
