Results 1 to 15 of 15
    Established Member Two Rings DLAB's Avatar
    Oct 04 2010
    Portland, OR
    DIY Thermostat Replacement
    Hey guys,
    My thermostat went kaput at 60k miles. After researching options, I decided to DIY it. The dealer was charging $1,300 and my local indy shops were either fully booked or hadn't performed this job before. Hopefully the video and notes I took (below) will help you if you decide to do this job yourself.
    Video
    Notes
    2011 6MT Meteor Gray Ti • AWE Exhaust • JHM STS • Roc-Euro Intake • Hard-wired Passport 9500ix
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Awesome and thank you for throwing this all together!! Will be found the same preemptively in the upcoming weeks. Perfect timing!!
    Established Member Two Rings supriyo82's Avatar
    Dec 12 2016
    Irving, Texas
    Absolutely brilliant. The details with which you have documented everything is commendable. I am sure people who are into DIY stuff would love this information.
    Thanks for sharing.
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Subscribed. Thanks
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Senior Member Three Rings AudiSTL's Avatar
    Sep 21 2013
    2011 S4
    st. louis
    great job this will save $1300 for a lot of people out there
    AWE Quad Exhaust / Rotifom Ind 19x10 (old) / V12 245/35 tires / Solo Werks / ECS Carbon Luft Intake / Stoptech / Verde V99 19x9.5
    Enlaes CF decklid / EPL 1+ w DSG
    https://www.instagram.com/admirstl3/
    Deactivated Three Rings
    Jul 09 2016
    Subscribed, thanks.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    THANKS for your effort in you tubing your repair. Way above my pay grade! But a great viewing experience. Thanks again.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Aug 25 2013
    florida
    great work man, thanks for the detailed video plus notes!
    2014 sfeux p+ 6mt bo nav w/o sd
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    One of the best DIY's I've seen here. A few specialized tools, and I may never do this myself, but I watched the entire video and it was well worth the time spent to learn what it takes to change the thermostat. Excellent! Thanks!
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Oct 09 2009
    B8 S4, B5 A4 Stage 1
    Fremont, CA
    Great, DIY. Had to replace mine a couple months back at my shop. They charged ~$700.
    Delivered 12/31/09
    Audi 2010 S4 Meteor Gray 6MT
    Prem + // Nav // B&O // Sport Differential // 19" Wheels // Carbon Inlays
    Mods:
    License Plate LED - 1.03.10 // 6000K HID - 1.10.10 // Interior LED - 1.10.10
    Clearbra - 1.12.10 // 30% Tint - 1.12.10 // Hoen Endurance Fogs - 1.15.10
    JHM Short Shifter - 2.22.10 // Vagcom'd - 3.5.10 // HRE M40 19x9 - 4.6.10
    APR Exhaust - 4.6.11 // H&R OE Sport Springs 4.6.11
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    How long did it take, start to finish?
    2012 S4
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Good stuff, even though my thermostat took a shit while still under warranty (replaced), I still watched the video just to see what it takes. Great write-up.
    Oct 04 2010
    Portland, OR
    Quote Originally Posted by Senseless View Post
    It's hard to say because I took my time and picked away at it over a span of about two weeks. In total, probably around 10 hours or so. I could see how with prior experience and a helping hand, you could probably cut that in half. Most shops are quoting 5.5-6 hours.
    Nov 30 2010
    Anchorage, AK
    Fantastic job and thank you for the video. I wish I had time to do this for my just-failed thermostat, but with the baby days away I just don't have time, so off to the dealership it goes ><
    Here's hoping the so far worth every penny warranty covers it.
    2010 Meteor Gray Prestige //S4 DSG
    Oct 10 2016
    1987 Dodge Ram, 2003 Dodge Ram,
    East Coast, USA
    Great write up. I just conquered this job myself a couple weeks ago.
    The first right up in the notes is the one that I used. I also got silver sharpies and marked the connectors to make it easier.
    Couple added notes:
    Recommendations. Loosen the supercharger bleeder screws before putting the supercharger back on the car.
    I broke both of mine and had to tap them out with a M8 x 1.00. Recommend getting aluminum bleeder screws to replace. Audi themselves use pressure bleeding; however, without the required equipment the screws are your only hope.
    http://www.brakeconnect.com/product/banjo-bolt-m8-x-1-0
    Putting into service position will help as well to give yourself another couple inches. Worth the extra 10 mins and $10 for longer bolts.
    Instead of dowels, I used (2) 8" x 1/2" drive extensions.
    Best of Luck
