Results 1 to 40 of 47
    Jul 10 2009
    2001.5 S4
    Boston
    Which Coil Conversion, Icm Delete is Better or Stay Stock
    Have not been on for a long time, have not been running the S at all. Getting it up and running again and need to do a tune up so figured now is the time to do this mod.
    Have searched on this subject, read, and have not really made a decision on what I have read. I would like to hear from people who have done this mod and if they think it's worth it
    and which company has the better kit. I am not going to make my own, do not have the time nor aggravation level for it right now. lol
    Also if you think it's overrated or not needed would like to hear those views also.
    Thanks guys really appreciate it...
    Aug 06 2008
    Canadia
    After doing the whole conversion i probably wouldnt bother, car runs the same as before, everyone said it was going to be smoother and idle better but i dont notice a difference, and i usually notice everything. Stay stock.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Totally worth it if you don't want to worry about ICMs, other than that probably not. I recommend the RS6 coil packs, no need for physical adapters to bolt them down.
    MacDaddy, you likely have a different issue, and the conversion did not resolve your other issue.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    I'm with mac on this. I did the conversion as well, with the ecs kit, and the only difference I have is occasionally a check engine light for open circuits on cylinder 4 primary wiring. Changing to rs6 coils seemed to make the code pop up less often, but it still remains. I'll stay with stock coils/icms if I ever purchase another.
    Had no misfires on stock coils, and still none on 2.0 or rs6 coils. Idle quality remains the same.
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    Corona, SOCAL
    Stay stock
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    Jul 10 2009
    2001.5 S4
    Boston
    Wow! did not expect to see all the don't do it responses. It seems that it does not really do much at all.
    I guess I would be better off buying plugs, stock coil packs, then cleaning my icm's and putting some thermal grease/paste on them and call it a day.
    I see some people move the icm's out of their normal position, do I need to do that?
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Nothing wrong with the stock setup if in good condition... Nothing wrong with converting either.
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    i think a lot of people get misfires, then jump on the 2.0T conversion bandwagon without finding their root cause... its not a cure all to misfiring issues, but it does away with the ICMs which can be costly to replace.
    often times than not, if you half ass the wire conversion (improper grounding / soldering etc) it will cause more issues than not.
    fyi i've been running the 2.0T conversion for 20k miles with no issues.
    Jul 10 2009
    2001.5 S4
    Boston
    Quote Originally Posted by erykv1 View Post
    So the kits are not just plug and play? There are issues with them that you need to resolve when installing them?
    The car is running a little rough obviously from not being run and needs plugs and packs.
    I am pretty sure the icm's are good....
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    I like the look of the 2.0 coils, the ease of maintenance (changing plugs), and the price of replacement coils. That said, I wouldn't have made the switch if my ICMs weren't dead (offsetting the cost). I didn't notice any performance/smoothness change, and if I thought I did after the switch, I'm sure it was a placebo effect.
    If it ain't broke, don't fix it. But if it is broke, convert to 2.0T coils.
    Also, don't throw parts at the car. I'm definitely guilty of that on a number of occasions over the years.
    Jul 10 2009
    2001.5 S4
    Boston
    I am just trying to make it as reliable as possible. Less headaches the better. lol
    If the kit makes the car more reliable and/or run better it probably is worth it.
    Also is anyone running the RS6 conversion? What would the difference be from the 2.0 and RS6 kits?
    Thanks again guys. trying to figure this all out while putting the car back on the road...
    Been away from here way too long, feel clueless.
    Jul 01 2014
    'murca
    Quote Originally Posted by Guss View Post
    Oh, the kits from ECS / 034 are plug and play. I was under the assumption you were going to buy pigtails, my bad.
    If your ICMs are fine I would just freshen up what you have and go from there, no need to spend the extra money when you don't have issues.
    Active Member One Ring Alby's Avatar
    Jun 22 2015
    Winnipeg
    some numbers and comparisons to look at:
    OEM
    Pro- easiest(imo)/made for your car
    Con- Expensive if replaced frequent [set of 6: $230(ecs)]
    2.0T conversion
    Pro- after installation, a set of 6 coils is $125(ecs)
    Con- Install kit is about $350
    Looking at these numbers the choice is really up to the owner on this one, but the 2.0T conversion might be a good early investment.
    Feel free to add anything i missed or correct me.. i'm a little new here :)
    Senior Member Two Rings AudiTuner1187's Avatar
    Jan 17 2014
    Delaware
    Can run a larger gap/hotter spark with 2.0 conversion
    Sent from my SM-J320P using Audizine mobile app
    Jul 10 2009
    2001.5 S4
    Boston
    Noticed RS6 kit don't need the plates. Are the RS6 coils as good as the 2.0? Not sure of the difference between the 2 except RS6 fits without the plates. My car is not stock, bigger turbos, fueling, tune, etc. Tune needs to be updated, fixed. Does any of that matter?
    Sent from my HTC One_M8 using Audizine mobile app
    Aug 06 2008
    Canadia
    Quote Originally Posted by Timtheguru View Post
    Car does not have any issues, it was done as preventative maintenance, also rs6 coils are just plain jane mk4 2.0 n/a golf coils.
    For someone who calls thenselves a guru you really manage to get it wrong a lot of the time.
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    No issues on my 034 kit other than shitty 3d printing plastic in a super hot engine bay so the tabs are real brittle, my main reason was cost of replacement coils.
    Dec 14 2014
    PNW
    Quote Originally Posted by MacDaddy View Post
    you are bitter
    Dec 30 2009
    lol, ok
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Aug 06 2008
    Canadia
    The last like, million posts of his ive read have been egregiously wrong, this is the first time i said something. Thats not being bitter thats patience.
    Dec 30 2009
    Alright, I'll bite. What have I been wrong about? Humor me.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Dec 14 2014
    PNW
    Just sounded that way..
    Junior Member Two Rings
    Jan 28 2015
    Finland
    The fsi coils are way cheaper to replace in the future, so if your current stock system is about to fail, I would do a conversion. That's what I did.
    Make sure you run two separate grounds (034 kit is flawed i believe), or you will have problems like everyone here seems to have. Do it properly and no problems. ECS has addressed that problem.
    Apr 07 2011
    Home of the mighty beaver
    Been running single ground for years. There is nothing wrong with it.
    Jul 10 2009
    2001.5 S4
    Boston
    Quote Originally Posted by bindi View Post
    So you have to do some modification when you install the 034 kit? FSI coils are better than the RS6 coil?
    Jul 01 2014
    'murca
    FSI coils are just RS6 coils without the built in adapter plate.
    Jul 10 2009
    2001.5 S4
    Boston
    If you get one of the 034 kits you need to modify how its grounded or there's problems?
    Jan 28 2015
    Finland
    I wouldn't get the 034 kit in the first place.
    Also the RS6 coils only fit APB motors, I guess that's what you have over there? Won't fit our AGB's anyway.
    Jan 29 2009
    Quote Originally Posted by S4James View Post
    ^^ This
    I have plenty of 2.7Ts around I've tuned running single ground (034 Kit) without any issues as well.
    I also have done conversions on other cars (stand alone ECU's) also single ground with no issues...
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    I've been running the ECS kit for about 3 years, zero issues.
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Apr 04 2007
    2001.5 S4 Stage 3+, 2001.5 A4, 2000 Porsche Boxster S, 1969 MG CGT, 1974 MG Midget
    Orlando, Florida
    Quote Originally Posted by bmoreS4 View Post
    I did the ECS swap 2 years ago and have had no issues. I had a bad ICM and decided it was the right time to do the swap.
    Jan 17 2014
    Delaware
    Quote Originally Posted by M1NDCRlME View Post
    X2
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by AudiTuner1187 View Post
    X2
    X3, I swapped to the ECS conversion while troubleshooting a misfire at idle. Turned out it was unrelated to the ignition setup but I like the flexibility on sparkplug gaps with the new coil, the looks and ease of maintenance. Can't go wrong if you truly have a component that failed in the stock ignition setup and jump to the coil conversion setup but it's not a 'performance' upgrade.
    2024 M3 Comp xDrive
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    It doesn't sound like you have any reason to make the change. I also think the coil conversion is overrated.
    Apr 07 2011
    The ECS is far superior in terms of harness routing, but i would work out a way to shield it from the heat
    May 16 2008
    WA
    MK4 2.0 N/A Golf/Jetta uses a coilpack and plug wires:
    For someone who calls themselves MacDaddy you really manage to get it wrong a lot of the time...
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I didn't buy the FSI coils with the expectation that they'd be "better" than healthy stock coils/ICMs. But, our stock ignition systems are generally old and weak at this point if parts have not been replaced, and replacing both ICMS and all coil packs with factory parts is $$$. Add easier diagnosis due to no ICMs, and the cheap coil cost, and the FSI makes a lot of sense IMO.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jul 10 2009
    2001.5 S4
    Boston
    Here is my thinking. I know plugs and coil packs need to be replaced they have been on for a while and the car has sat around.
    Car runs rough, has misfires because of this. I believe my icm's are good but not totally sure, they have been on for a while.
    I did not want to have issues, questions while getting the car back on the road.
    Am just unsure if I should do this or not, have to decide if I want to spend the extra cash.
    Seems the ECS is the better kit from the comments. Looks like there is a consensus the 034 is lower quality...
    My only question is should I just buy the harness from ecs and then buy the RS6 coils.
    Seems having them just plug right in and have stock fit without the plates would be the better way.
    Jun 08 2014
    Vancouver, Washington
    You have a few options.
    If you want the most straight forward way without any real DIY work, buy one of the conversion kits which come with coilpack wiring, ICM deletes (and most likely), the adapter plates. Then you buy 6 coilpacks, either redtops or blacktops your choice. Same thing.
    OR
    You can build the whole kit yourself with a little soldering. There are a few people on the B5 S4 Owners Group who can source the pigtails, rubber boots, ICM delete stuff and coilpacks for MUCH cheaper than a plug and play kit. You will then just have to buy the adapter plates from your preferred retailer. ECS, 034, Integrated Engineering are those who make them I believe. All around the same cost of $120.
    The second one is the route I am going. My car has 184k, and I have no misfire issues, nor ICM issues. All coilpacks work perfect.
    A few reasons I'm doing it:
    1. Its preventative maintenance. Less things to fail, and cheaper to replace if they do. Again, this is only if everything is installed 100% PERFECTLY. Read that. PERFECTLY. Otherwise you'll have issues and get bitter about the conversion ;)
    2. If it was such a terribly unreliable and stupid conversion, why would MULTIPLE companies do the RnD to develop kits and make adapters and harnesses, etc? They wouldn't offer the kits still if they had crazy failure rates..
    3. They look better, easy to replace sparkplugs at the recommended 3-5k miles (with oil changes using BKR7E's), and you rid of the ICM's. Freshens up the bay a bit too.
    I got everything I needed for $200. Wiring, coilpacks, adapters, etc. Just have to build it.
    Jul 10 2009
    2001.5 S4
    Boston
    Researched doing it myself, don't have the time nor patience to do that right now. Just too busy.
    Would rather just buy a pre-made kit. Was thinking of just getting the harness, buying the RS6 coils so I would not need the adapters
    Does not seem to be a difference in the 2.0 coils or RS6 in performance. Price is a little different.
    Would be a cleaner install and look stock with the RS6 coils
