Results 1 to 16 of 16
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    How reliable are the 8 speed auto's when tuned with stage 1?
    I was considering trading my 13 A4 in for an S4 but I got such a good deal on my a4 that I've now decided against it. My car has 60k miles on it and I can't stand how slow it is, I previously had a CC manual with apr stage 1. My question is how well do these trannys hold up over time with the tunes? And how often do they need to be serviced?
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    No data to support this statement but I doubt very much that a Stage 1 tune will have any impact on auto transmission life unless you are continually doing hard launches or WOT operation. During "regular" driving, I'm guessing there's less than 70% of the time when you are taking advantage of the improved boost and even then you are probably heavier throttle only for 15-30 seconds. I base that on how often I get push to higher boost levels when driving around my area. It's all up to driving style and I would be in the conservative low/middle range rather than full throttle for extended periods.
    My 2c worth
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I'm not sure I can even recall anyone blowing up a ZF 8 Speed on our platform yet. It's pretty damn sturdy.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Established Member Two Rings Copecetic's Avatar
    Jun 26 2017
    Jacksonville
    Quote Originally Posted by adamazing View Post
    This. When I first bought my car I searched high and low for problems with the Auto Quattro tranny.
    There's so little out there it seems as though no one has really been able to tear one up yet.
    Other than slapping a better mount on the transmission for stage 2+ tunes I can't find any real upgrade/issues.
    Don't worry, I have no idea what I'm doing..
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Allroadcorbin is well over 100k and has a K04. It's robust, but should be serviced around 80k. http://www.audizine.com/forum/showth...Lifetime-fluid
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by earhythmic View Post
    Yep, he's my former roommate. Can vouche it runs just fine.
    My ZF6 is handling the k04 well too.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    I think the transmission is handling power so well that Audi is now using it in the S4 in place I'd the DCT. BMW might be doing the same thing.
    Sent from my Nexus 5 using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by KFizz View Post
    It may be a stronger version of the zfhp8 in the new b9 s4.. but exactly the point!. Its a better transmission for the newer generation higher torque motors!. Manufactures like long term reliability, . And with regular fluid changes it's pretty stout!. Like mentioned the new BMW m5 is going away with the dct twin clutch , and switching to a high Torque zfhp8 version as well. Along with a very trick switchable awd setup!.
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Quote Originally Posted by fitch303 View Post
    Depending on usage, owners have been changing fluid on the 8-speed automatic transmissions every 50k-75k miles.
    Some owners, who heavily tracked their vehicle, have done it even more often - around 30k-40k miles.
    If you fluid is aged, a fluid drain and full service will make a difference in feel and crispness.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    Also to add to what everyone else on here has said, there may also be a TCU tune as well so it will handle the shifting better to accommodate the extra power. I wish my B6 had this flash to accompany the extra power with the ecu flash.
    Sent from my Nexus 6 using Tapatalk
    Dec 27 2009
    Edmonton/Alberta
    So in closing.... The 8 speed ZF, in a few variations, is pretty well the best automatic transmission you can get in a factory vehicle. Within reason.
    Kyle
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by weagle1856 View Post
    No tune as of yet!.. only mod available is a vag com switch to disable the automatic upshift.. a few have done it,
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    I have a 2013 B8.5 A4 ZF8 as well, Ko4 with E85 for over 10k miles now with 2 episodes of running the 1/4 mile. No issues whatsoever, planning on doing a full carbon cleaning and ZF8 fluid flush etc. next spring. These trannies are pretty stout as everyone says so far.
    Ox
    2013 Scuba Blue A4 Premium
    EuroCode / APR / H&R / Bilstein / VagCom / AWE / NGK / 034 / GFB / HRE / Valentine1 HW / CR15 / Black Viton Injector Seals / Fluidamper / Ko4 #00Negative
    Senior Member Three Rings Rollin Thunder's Avatar
    Aug 14 2012
    2008 F150 FX4
    Central New Jersey
    I'm running an APR K04 with all the supporting goodies on an 8spd auto and it's been able to tackle everything I've thrown at it without hiccup.
    Sent from my Nexus 6P using Audizine mobile app
    MODS: Pretty close to everything and the kitchen sink.
    Jan 03 2008
    Columbus, Ohio
    Will Audi do the service even though it is not recommended? or will I need to find an independent shop?
    Jul 03 2005
    Broomfield, CO
    An independent shop would be your best choice as they typically are more cost effective.
    - Erik
