Just wondering what you guy's think about the alternative of pulling the engine to do this and whether this makes sense given that at the time I could also :
Replace cam chain/tensioner and coolant flange (if worst case scenario below doesn't eventuate )
Do planned work on front ie new modded grille,replace HID bulbs
AND worse case scenario-push Wofies heart ( said engine) into a dark,dark corner if in fact its irreparably,meaning uneconomic damaged but signs are maybe not (said with extreme optimism ).....
I think I can borrow a portable hoist with no time constraint.
If the time factor is not much different,the thought of not having to work upside down with floor jacks,wrestling the sub-frame,pan and with all that
Thoughts appreciated,thanks
