Results 1 to 11 of 11
    Veteran Member Three Rings BlueSVT's Avatar
    Oct 06 2013
    Volume control "Currently Unavailable" while listening to radio
    Something strange recently happened, and I'm not sure why or how to correct. When listening to the FM/Radio tuner ONLY, I'm unable to adjust the volume! It says "currently unavailable" instead of changing volume. However, every other source the volume changes just fine?
    Only thing I can think of, is I just recently used the VAGCOM to change a few things, but ONLY changed things I knew what I was changing, and followed the forum guidelines... didn't go poking around or anything.
    Any ideas???
    Arguing with an engineer is a lot like wrestling with a pig... After a couple hours you realize the pig likes it.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    It means the station you want to listen to is not available to listen to. It happens a lot on HD fm stations. Not an issue, it just that station has not enough signal in the area you are going through . Signal on HD stations are either strong enough or not to be heard . It only happens on FM radio, just like you are experencing. All is normal, your settings changes had nothing to do with it, you just did not notice before.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by jygesq View Post
    To adjust volume? Why would a weak signal - Far side (broadcast) affect near side (car control)? Serious question too.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Aug 22 2014
    bloomfield,ct
    HD radio is digital, either you have signal strength enough to have station be heard or you do not. When you do not you,see icon with a line across a speaker. That means you' can not receive the station. When that occurs and you try to change station volume, you see " currently not available." Only happens on radio on digital " HD station"
    Jul 12 2012
    Ok, good to know. I've never encountered this myself and would've just expected that there would just not be any audio.
    Apr 05 2010
    This has happened to me a long time ago. A hard reset fixed it immediately.
    2020 SQ5 Quantum Grey
    2018 C43 AMG Selenite Grey
    2018 SQ5 - Sold
    2014 S4 - Sold
    2004 A4 USP - Sold
    Oct 06 2013
    Yeah, this is while the music IS playing and it IS tuned to a station... I changed stations and same thing.
    How do I do a hard reset?
    Apr 05 2010
    Quote Originally Posted by BlueSVT View Post
    Look at the 2nd image in the first post. Press and hold down until it shuts off.
    http://www.audizine.com/forum/showth...ft-2013-B8-5-s
    2018 SQ5 - Sold
    2014 S4 - Sold
    2004 A4 USP - Sold
    Oct 06 2013
    Nov 03 2019
    2014 Toyota 4runner
    Wesley Chapel, FL
    The same issue happened to me today but I was listening to an AM station. The issue cleared while I was driving with no changes.
    Account Terminated Two Rings celticsevad's Avatar
    Jan 23 2019
    Montreal.Canada
    https://www.youtube.com/watch?v=kmrSdXLmeG4 if it isnt fixed.. see my video sorry my bad for the english
