Results 1 to 30 of 30
    Active Member Two Rings Matty_s4's Avatar
    Jul 16 2017
    Massachusetts
    2012 S4, Bluetooth and Music
    Hello,
    Glad to be part of the community!
    Just got a 2012 S4 Premium + and was wondering if I can play music from my Samsung via Bluetooth?
    Or, will I need to purchase adapter?
    If adapter is only option, recommendations?
    Sent from my SM-G925V using Audizine mobile app
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    On a 2012, no. Streaming audio wasn't added until 2013 mmi updates.
    Some have had luck with bovee viseo, but mine crapped out after a few months. I'm currently testing out some cheap Amazon cables and just running my android hard wired in the glove box.
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Active Member One Ring b7a4mj's Avatar
    Mar 21 2012
    Glenside, PA 19038
    No Bluetooth through mmi on the B8's. I bought the adapter from Audi that plugs inside the glove box and it constantly loses connection. Not to mention you have to keep the phone inside the glove box. I have heard of a Bluetooth adapter that plugs into same port inside glove box that works well. I can't recall the company that makes it.
    Jul 16 2017
    Massachusetts
    been told the Samsung Universal adapter (has SD, USB, HDMI, and charger cable) should work.. anyone hear about this?
    Jul 16 2017
    Massachusetts
    also, can the MMI software be updated?
    Junior Member Two Rings rgferrell56's Avatar
    Mar 22 2017
    Newark California USA
    I'm using a Carpro attached to the port in the glove box. It works great through the Bluetooth just no song read out on mmi.
    Sent from my SM-G955U using Audizine mobile app
    Jul 16 2017
    Massachusetts
    Quote Originally Posted by rgferrell56 View Post
    thanks
    Jul 16 2017
    Massachusetts
    Best place to purchase? Price? Is it a DYI?
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I've got a blue tooth dongle that I can sell to you if you're interested. It works just fine, but I don't use it like I thought I would. PM if you're interested.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Mar 22 2017
    Got mine through Amazon if I remember correctly let me check.
    Jul 16 2017
    Massachusetts
    Quote Originally Posted by Joker S4 View Post
    what kind? how much?
    Mar 22 2017
    Coolstreamrocks.com
    Mar 22 2017
    $79.99
    Jul 16 2017
    Massachusetts
    $79.99
    anything like this one? If it's even worth it?
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    I have a 2012 and was disappointed with the Bluetooth adapter option. I purchased this one from Amazon, and I had trouble getting it to consistently connect to my phone. Rather than try other adapters, I decided to upgrade to the newer version. I bought the components used off of eBay, spent around $500 after getting component protection removed at the dealer. Yes it's no comparison to the price of an adapter, but it's well worth it to me. YMMV. Here are some threads if you are interested.
    Link
    Link
    Also, I highly recommend looking at the upgraded steering wheel from fly designs on eBay.
    Link
    These are the first two mods I did to my 2012, very happy with both.
    2005 A4 USP (Gone)
    2012 S4
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I have a tune2air in my 2011 and it works just fine with iPhone 7 or non iPhones. It had a skipping issue with the iPhone 6. this is what i have for my 2011. https://www.amazon.com/Bovee-Wireles...=tune2air+audi. Just pug it into the cable in the glove box. Make sure you get one with the correct connector
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I use the Tune2Air 3000 in my 2012 as well and absolutely love it. No issues here and I've been using it for over a year now. It connects to my phone instantly and the music starts to play the second the car turns on. It retains full use of your factory controls (steering wheel and center console buttons) and it shows complete song info on the MMI screen (title, artist, album, etc). Don't waste your time with other options.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Established Member Two Rings RG4's Avatar
    Jul 25 2016
    NJ/NC
    +1 for Tune2Air. Works well on my iPhone 6s shouldn't be a problem with your Samsung. It's certainly not perfect but functions well 95% of the time. Had more issues when I first installed it but they seemed to have worked themselves out over time
    2010 A4 2.0T Quartz Grey
    APR Stage II | APR Cast Downpipe | AWE Touring Exhaust | aFe Dry Flow | ECS Turbo Inlet | GFB DV+
    Jul 29 2009
    Austin, Tx
    I have a 2012 and I have 2 different methods. The Tune2air works fine but I also have a USB plug. My issues were that sometimes one or the other wouldn’t work. If I was using the Tune2air sometimes I would have issues with phone connectivity. With the usb if my phone was under 40% battery, it wouldn’t connect. When I updated my phone to iOS 11, none of adapters would work. I changed the input in the MMI to AUX input via green screen. Now I can use what ever adapter I want without any issues. I only use the usb connection now because even the sounds is better. Only drawback is I have to skip music via the phone which is fine.
    Here is a bit more descriptive thread about what I did.
    http://www.audizine.com/forum/showth...1#post12519462
    Active Member Two Rings 2008A4SLine's Avatar
    Jun 29 2017
    PA
    Quote Originally Posted by DannyDeez View Post
    Hi. Where does the tune2air plug into? Do I have to pull the stereo out?
    2008 A4 S-Line
    2011 Gibson Les Paul
    Friedman PT-20 Pink Taco
    Orange PPC112 Cabs
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    Quote Originally Posted by 2008A4SLine View Post
    It plugs into the iPod adapter in the glove box.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by KRS Aaron View Post
    Yup, look inside your glovebox for the connector.
    Apr 29 2013
    Detroit, MI
    a2dp4audi.com sells kits. Works great in my 2012 with Android.
    2018 S4 8AT
    2012 S4 6MT
    2006 S4 6MT
    2000 S4 6MT
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    Quote Originally Posted by BaumerS4 View Post
    OP, this is the one that I have, works well.
    Senior Member Two Rings VtotheJ's Avatar
    Jan 27 2017
    Tune2Air works well but it does have its flaws. Whenever I shuffle on my iPod and try to switch songs using the MMI controls, there is a 5 second delay. Not a huge fan of wireless, I just wish my 2011 had the modern Lightning connector in the center console glove box.
    Apr 30 2010
    San Diego
    I am using Carpro as well but actually do get the song readout though. I can't change songs though unless using the phone though.
    2011 Audi S4 | 6MT | Ibis/Black Silk Nappa | Nav l B&O | Sport Diff | Carbon Inlays | H&R l Strat Intake l Strat SS l Alu Kreuz l AWE Exhaust l AG M510 20x10 et35 l GIAC Stg II l DTM Lip l Eurocode Diff Mounts l SS Clutch Line
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Agree with Deez, I bought the same module from another member here and it pairs great and does exactly what I want it to do via bluetooth.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jul 16 2017
    Massachusetts
    Quote Originally Posted by Dr GP View Post
    thanks, appreciated
    Jul 16 2017
    Massachusetts
    Quote Originally Posted by sacandagaD View Post
    thanks for advice
    Jul 16 2017
    Massachusetts
    thanks, looking at several options
