Results 1 to 16 of 16
    Jan 14 2014
    New Jersey
    B5 S4 Engine/Trans Removal With Subframe
    So it's possible I'm a massive idiot and missed it, but are there any writeups for popping the entire engine/trans/suspension/subframe out as a unit? I see plenty for removing the drivetrain with a hoist separately, but none for the subframe method.
    Background:
    Swapping everything from the front ends between two 2001 S4's. One is fully built (Ohlins suspension, BBK, F21's and fully built engine, and JHM 01E) but unable to be registered, the other is a high mileage stock car. Rather than taking things apart piece by piece, we decided it may be easiest to drop the subframes and swap them over as assemblies.
    Before diving in though, it'd be nice to take a look at a writeup if anyone has one! Also I have two lifts at my disposal, which obviously is helpful for subframe related things.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Its not hard. The subframes are pretty obvious how they unbolt from the bottom. On the shock towers there are 3 bolts on each side and you can then drop subframe, engine and suspension as a unit. Its designed to do this easy too.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Aug 06 2008
    Canadia
    The engine mount bracket is seperate, so your still swapping subframe and engine seperate.
    Established Member Two Rings sxC's Avatar
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    nynoah is correct, it's literally that easy. The 8 bolts holding the subframe/sway bar up (4 large, 2 medium, 2 small in the back) plus the 3 bolts on top of the strut tower on each side. Don't forget the rear driveshaft/shifter/clutch slave!
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by sxC View Post
    And disconnect the downpipes from the rest of the exhaust.
    2024 M3 Comp xDrive
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    I believe there are also two more bolts holding each engine mount separate from the one big one that is part of the subframe(so 3 total that go through the engine mounts).
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jan 14 2014
    New Jersey
    You guys are awesome, thanks for the input! Popped the built car in the air today and scouted it out. Looks like the clutch slaves might be the worst part of the whole thing.
    Looking at it now, does the rad support even need to come off for this? It seems like putting it into service position may be enough
    Jul 31 2014
    NH
    Quote Originally Posted by all_motor_A4 View Post
    I believe you could do it without going into service postion at all if you remove the fan from the pully first, which is easy with the right tools, near impossible without.
    Mar 01 2011
    Calgary
    Bump!
    I'm going to be doing this method on Quickjack 7000TL's. Any recommendations for the best surface to drop the engine/trans/subframe combo onto? I know on a hoist there are hydraulic carts, but the quickjacks won't go that high. I was thinking of dropping onto a pallet jack?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    You could drop it on a pallet. I honestly thinking picking the motor straight out is the way to go. Even with a lift I did it that way.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Ya if you do the subframe method, you basically leave your car immovable either taking up valuable garage space or occupying your QuickJacks and you may feel pressure to complete it quickly rather than taking your time. Having a rolling chassis gives you more options.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Mar 01 2011
    Calgary
    I'm doing coilovers/adjustable uca/aluminum uprights at the same time, along with hotchkis front and rear bars, etc.so I'll need an alignment and having it all out should make it a lot easier to swap the parts. Not worried about garage space, as I have a 2.5 wide and the project is the only thing going for a month. Just looking for the least cursing/quickest path towards dropping the assembly out, and it sounds like 3hrs is reasonable if the whole thing is dropped out on the subframe.
    Oct 27 2006
    Currently only S4
    Fort Walton Beach FL
    Please provide any pics or video that you can. Thanks.
    Mar 01 2011
    Calgary
    Never pulled a motor before! Here we go...
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    This is basically the approach I am slowly taking.
    I bought 4 of these 8” caster wheels rated for 500+lbs each and bolted them to a pallet. I plan to place everything down on the pallet using my engine hoist but then it’s all easily movable with the pallet and caster wheels. I did add a broken snow shovel handle and then swapped it for some old wheel barrel handles on the pallet for easy maneuvering around but that was optional. Plus the whole assembly fits under my taller torin 6 tonne stands for storage in the engine bay being that my project will take me forever and I’ll need the engine out for my slow build for things like turbos and the trans out to do the clutch. IIRC, I picked these up as ‘used like new’ from amazon for cheaper being that they would get beat up anyway in the garage.
    This setup has been useful or more things around the house and garage - ie, I built a 250sqft paver patio last year with a 12’x20’ gazebo structure and I was able to move everything over grass with this setup on my own including the 1,500lb gazebo in its 5 shipping boxes.
    https://a.co/d/6JHgYQX
    Good luck, keep us posted please
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Mar 01 2011
    Calgary
    Great idea. I'm looking for a hydraulic cart long enough - taking inspiration from VW having their own Snap-on Scissor Lift SST for the V10 TDI:
    https://vw.snapon.com/SpecialToolsDe...temId=39410155
    Here's a cool video of it in action. I didn't realize it could articulate as well:
    https://i.imgur.com/1nmMZph.mp4
