Results 1 to 19 of 19
    Registered Member Two Rings 4bidden's Avatar
    Jul 15 2005
    Toronto, Canada
    Traction Control, ABS, Flashing Brake Light
    I just purchased a 2002 S4 and the traction control, abs, and brake light are on. The brake light is actually flashing and the other lights remain on. I was wondering if anyone had that tool that could reset these sensors? I live in the GTA and could meet up with you. I prefer not taking it to Audi because they will charge an arm and a leg just to look at it so if anyone local could help me out that would be great, I'm sure it won't take long for the experienced person. The car is from the States if that helps anyone. Thanks for your help.
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    Traction control? Is your car FWD?
    Veteran Member Three Rings T-dot B6's Avatar
    Jun 17 2004
    2005 Audi A4 1.8T Quattro 6MT
    Toronto, Canada
    someone with a VAG-COM can scan your ECU for fault codes. Either the dealer can or a few members on this forum can do so.
    2005 Audi A4 1.8TQ | Light Silver Metallic | Ebony | 6-Speed | Premium | Lighting | Sport | Cold
    GIAC FXK03 | TT225 Injectors | Hyperboost | AFE | NGK | 3M | Formula 1 Tint | Audi Sport | APIKOL SMIC
    Veteran Member Four Rings Itchy Foot's Avatar
    Jan 08 2005
    B6 USP 1.8T
    Toronto, Canada
    Thats ESP. S4's can't be FWD
    Where are you located in GTA? I don't mind helping a fellow member out.
    -Chris
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    If they are on all the time, there's something wrong. Could be a sensor that has gone bad if your ABS light is on (hopefully), at worse, your ABS control unit is bad. As for brakes, could be pads that are worn out or again the sensor or the wire for the sensor is bad.
    Mike
    Feb 12 2004
    Toronto GTA
    ya, I was gonna say..... maybe he bought a FWD S4 1.8T from the states.....
    Well, let's just hope is was ESP.....
    Jul 15 2005
    Toronto, Canada
    I'm located in Pickering but I'm in Mississauga all the time so traveling the distance is not a problem if someone is willing to help me out. I'm not too familiar with the codes and what not so I'm not sure what other info would help. It was in an accident previously, hit on the front right side. The traction control (Circle with ! in it), ABS lights are on all the time and the brake light flashes when the parking brake is not on.
    Anyone free on Sunday evening or Monday to take a look?
    Jul 15 2005
    Toronto, Canada
    If its a simple matter of changing the brake pads, how much does something like that cost? If I buy the pads from Audi, would a regular mechanic be able to change it or is there something special that Audi has to do? I was told that it could be costly cause you normally have to change more than just the pad.
    Jan 08 2005
    B6 USP 1.8T
    Toronto, Canada
    Sunday afternoon is possible for me. But you will have to come to GTA....the most West I am willing to go is Yorkdale...
    It is hard to say what is wrong with the car. The warning lights, when lite together, tell you another thing rather than isolated problems from different components of the car.
    Normally the dealership will change the rotors and the pads at the same time because it is their procedure. It is the rotors and the labor (the dealership charge) that costs an arm and a leg. It really depends on how worn your rotors are.
    If you need to change out both, it might be a good time to change aftermarket rotors and breakpads as well. With aftermarket breakpads you will probably lose the break sensor (but breaks squeek like crazy when they are worn anyways).
    I say do the job with a trusty mechanic (mind you it is not a difficult job) IF it is really your breaks, and you will save a lot of money.
    All in all, we won't be able to know what is wrong until we scan the vehicle.
    -Chris
    Jul 15 2005
    Toronto, Canada
    Thanks Chris, I've sent you a PM to setup a time and place on Sunday.
    Would you know of a good place to buy some aftermarket pads and rotors for a good price? I've seen some on ebay but not sure if it is worth the risk especially with the high shipping and duty costs.
    Jul 16 2005
    2013 Audi S4, 2004 Yamaha R6, Yamaha Blaster
    toronto, on
    just a heads up... lights and these cars are not always what they seem depending on how they light and the combo's .. when my ESP and ABS lights were going off on the s- it was actually an oil sensor. (thats the weird codes u were seeing when u VAG'd my car itchy)
    || dc! 13' S4 | Premium | NAV | B&O | Sport Differential | H&R OE Springs| MORR MF70 19x9 | TiKore Bolts||
    Jan 08 2005
    B6 USP 1.8T
    Toronto, Canada
    so did u fix it yet?
    -Chris
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    well its not the pads; that has a different warning.
    it is definetly the abs sensors or the control unit. see if you can connect to the module (control unit) with a vag-com; if you can then it's just the sensor(s) gone bad (i think) but if you can't connect to it then it's a faulty unit that needs to be repaired/replaced.
    that's where i'm at right now... i didn't think the problem still goes on in 2002 or newer models (mine is a 99 A6)
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Jul 16 2005
    toronto, on
    chris,, its fixed months ago now- i never let things stand with my car as i paid big money for the extra warrenty.. :P
    Jul 15 2005
    Toronto, Canada
    Well I would just like to take this moment to thank Itchy for meeting up with me and Vag'n my car. Its good to see that there are still decent people in the world who like helping others. As for everyone else, I appreciate the advice and help. I'm not too good with codes and Itchy said he had to research what the codes were but maybe someone on this forum would have more insight. Here are the main issue reported from the read out:
    Control Module Part Number: 8D0 907 551 AA
    Component and/or Version: 2.7l V6/5VT G 0003
    Software Coding: 06751
    Work Shop Code: WSC 63351
    4 Faults Found:
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-10 - - - Intermittent
    17887 - Brake Boost Vacuum System: Mechanical Failure
    P1479 - 35-10 - - - Intermittent
    17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
    P1423 - 35-00 - -
    17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
    P1411 - 35-00 - -
    VAG-COM Version: Release 504.1-UD
    Control Module Part Number: 8D0 907 389 E
    Component and/or Version: ABS/ESP allrad D56
    Software Coding: 00000
    Work Shop Code: WSC 00000
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    66-10 - Not Matched - Intermittent
    01044 - Control Module Incorrectly Coded
    35-00 - -
    Anybody have any ideas?
    Jul 15 2005
    Toronto, Canada
    There is someone on ebay selling an ESP module that is the exact same model that is in my car now for 175 US. Is it worth getting another module or does anyone think that the ABS and ESP lights are on for another reason? The brakes rotors and/or pads need changing if that helps.
    Established Member Two Rings joesgtech's Avatar
    Apr 28 2004
    01 S4 01 GMC 02 Lexus
    Stillwater OK
    Re: Traction Control, ABS, Flashing Brake Light
    Did you ever get this fixed if so was it the abs module?
    Veteran Member Four Rings bunnn's Avatar
    Jan 24 2006
    e92
    wow talk about bringing back the dead haha..
    Cheers!
    ~Ben
    Jan 08 2005
    B6 USP 1.8T
    Toronto, Canada
    I remember all those issues were fixed in the end.
    4bidden is usually on audiworld I think. Look him up there!
    -Chris
