Results 1 to 40 of 52
    Veteran Member Three Rings P1Racer's Avatar
    Nov 18 2014
    Santa Cruz,California
    Supercharger belt shredded while driving
    I was driving calmly for about 30 minutes and felt my power steering go out. Pulled over and saw the belt of my supercharger shredded.
    I have seen this happen a few times here on the forum. My question is what belt should I replace this with? I have a CTS pulley kit. It's been on the car for 1000 miles.
    2011 S4, 034 DP ECU/TCU, AWE Inlet pipe, JHM 187mm Crank pulley, CTS 57mm Supercharger Pulley, AWE Touring Exhaust- 102mm, JHM V2 Test Pipes. @TommyLinebarger
    Mar 21 2015
    Stock
    Nov 18 2014
    Stock
    Would the stock pulley work well the with the aftermarket smaller pulley? I didn't think it would fit since it's a smaller diameter.
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Tell us about your car, year, mileage, is it stock, etc.?
    Otherwise we are really guerssing here.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    What's your car's mileage? When you installed the CTS pulley kit, did you change the belt or use the original belt?
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Nov 18 2014
    80k miles, pulley and belt are CTS and has been on for 1k miles. Cars a dsg and is stock tune.
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    My guess is the belt was loose or miss alligned. I would look for misaligned pulleys that really bend the belt.
    If this is the case, the belt is getting stressed during each revolution of the pulleys, this is a crazy guess.
    I once told our quality manager I do car repair over the phone, this almost qualifies, I am the ME manager.
    2016 Z06/Z07 Vette
    Nov 18 2014
    Dec 19 2015
    GVRD, BC Canada
    +1. I agree with Sudz's guess/hunch/theory that the pulleys are not properly aligned with each other. A belt just does not get shredded like that unless the pulleys are misaligned with each other which means that the grooves in the belt are not seating properly on the grooves of one of the pulleys. Or, the replacement belt was a poor quality part which I somewhat doubt but who knows?
    Nov 18 2014
    Quote Originally Posted by plat View Post
    I'm kind of thinking it's the quality of the belt. I'm going to try and find another brand belt that works with the 57 size pulley.
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    Quote Originally Posted by P1Racer View Post
    Why would you have a stock tune with an undersized pulley? And if it’s not undersized why was the stock pulley replaced?
    Nov 18 2014
    I have a date to get tuned at the end of the month. I don't drive the car often and was told it's fine to have it on. The pulley was replaced to allow for more psi when tuned
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    A similar case recently was down to the charger pulley not being on the shaft far enough.
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Apr 05 2016
    Portland, OR
    Since no one really answered you. 7pk1270
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Quote Originally Posted by xpoweruk View Post
    Yep. The pulley should be flush on the shaft like this:
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Nov 18 2014
    Quote Originally Posted by whiped View Post
    Thank you whiled! This is the exact answer I was looking for
    Nov 18 2014
    That's the appropriate size for my aftermarket pulley?
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    If your powersteering went out, it's your crank pulley that failed, not the supercharger pulley like everyone is saying. When the crank pulley fails it can shift the belts causing the shred also.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Feb 05 2016
    UK
    Good spot
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by infinkc View Post
    This
    Correct. The smaller SC pulley does not require a change in belt size. The belt tensioner takes up any slack.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Nov 18 2014
    After getting the car home and looking more into it, the accessory belt shredded and the supercharger belt just popped off. At 80k Miles, is it possible my tensioners are already worn out?
    Nov 27 2015
    UK, West Berks
    As already noted - your priority should be to check if the OE crank pulley has failed
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Apr 05 2016
    Portland, OR
    Sorry, the 7pk1270 is for the supercharger side of things. I am not sure what the accessory belt size is.
    ECS has kits though you can reference: https://www.ecstuning.com/Audi-B8_S4...ccessory_Belt/
    FWIW, check your crank as noted above.
    Geoff
    Nov 18 2014
    Thanks I'll be checking those out today. If so I guess it's a good time to go DP
    Apr 05 2016
    Portland, OR
    Even if you don't go DP grabbing a fluidampr pulley is wise as you can easily add the larger sleeve on later
    Geoff
    Nov 18 2014
    Alright, so crank pulley is sliding like that on my car so that must be the cause. If so I'd like to go with the 187mm is the fluidamp better than apr? Which is easier to install myself?
    Apr 05 2016
    Portland, OR
    APR bolts on over the OEM pulley. So if you go APR you will need to buy an OEM pulley and the APR extender thing.
    If you go Fluidampr you buy the crank pulley and a sleeve that bolts to it.
    The Fluidampr is a better solution IMO. Both will require the same amount of work to install.
    If you don't mind running undampened JHM/KI also offer solid pulleys.
    Geoff
    Nov 18 2014
    With this failure, JHM Also sells a 187mm Crank pulley that looks like it includes the inner pulley section.
    https://jhmotorsports.com/shop/catal...html?cPath=0_1
    Also, Would it be safe to drive the car with both pulleys for a few weeks?
    Apr 05 2016
    Portland, OR
    Yeah no problem, you'll just bleed off the extra boost.
    Geoff
    Veteran Member Four Rings F40LM's Avatar
    Aug 12 2013
    Midwest
    I have a stock belt and pulley for sale under 15k miles on it btw
    Present
    2019 Ford Raptor
    1968 Mustang Fastback GT
    2020 KTM XC-F 450
    Past
    2004 Jaguar X Type / 2006 Acura RSX / 2005 Subaru WRX STi / 2013 Audi S4 / 2016 Lexus RC 350 F / 2014 Ducati Streetfighter / 2014 Jaguar F Type V8S
    Nov 18 2014
    Just ordered my JHM 187mm crank pulley. That kit comes with a new supercharger pulley I assume. Which means I also will be ordering a new accessory belt. Since I'll be doing this, is there another moving part around there that I should service or upgrade?
    Feb 05 2016
    UK
    Looking at the JHM site it doesn't come with a charger pulley
    https://jhmotorsports.com/shop/catal...si-p-4227.html
    PARTS INCLUDED:
    - 1x JHM "HD" Overdrive Lightweight Crank Pulley (187mm)
    - 8x 8mm x 1.25 Allen Bolts
    - 1x High-Quality Belt, Longer for Use with Larger Pulley
    It will still give a good ratio though & is what MRC use in the UK for stage 2
    Nov 18 2014
    PARTS INCLUDED:
    Awesome! Well after digging around a little a 1320 supercharger belt seems to be the sweet spot with my new ratio. Is anybody running something similar?
    Apr 05 2016
    Portland, OR
    Depends on the brand of belt. I'd go gates rpm 7pk1310 personally. Or a 1320HD
    Feb 05 2016
    UK
    JHM provide the belt by the look of it
    Nov 18 2014
    Thanks for the info, I'll be installing tonight and hopefully the S4 is back up and running!
    Nov 18 2014
    JHM Sent me a Bando 1300, hopefully that works.
    Apr 05 2016
    Portland, OR
    Might be tight but should be fine. Belt sizing is inconsistent so you'll have to test it
    Geoff
    Jul 21 2004
    South Florida
    Bando belts are complete junk. I'd rather run a gates 6 rib.
    https://www.amazon.com/Gates-K060516.../dp/B001R5W4EC
    2018 Audi S5
    Gone-
    Nov 18 2014
    I got it together successfully! Thanks for everyone's help
