Results 1 to 6 of 6
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    AC / HVAC Servo Motor Repair B6 - A better trimpot fix
    My AC servo motors have been making strange noises under the dash since I got my 2003 A4 more than two years ago. That and the AC would cut out while they tried to figure out their position. A couple of them finally got bad enough that the system quit trying to position two of them. A fellow A4 owner let me pull a full set from an 2004 A4 with about 90,000 miles. Since mine have 154,000 miles on them I figured it had to be an improvement. They tested out fine, I installed them and now the AC works perfectly.
    Now that I have a spare set I was curious to take the old ones apart and see what I could learn.
    1. The motors on all the servos were good. As others have found it is the trim pots that are causing problems.
    2. The trim pots are lubricated with a special grease.
    3. The only wear I found was on the tips of the rotating contacts. They were still good, but instead of a rounded tip they were more of a flat. The resistor element was perfect
    4. A bad trim pot was easy to spot using an ohmmeter.
    5. There is no need to try and clean the trimpot using a solvent and a brush. Since the trimpot is greased and can't be taken apart it really won't clean it and may mess the grease up.
    6. All you need to do is remove the trimpot and spin it a few time to let the contacts wipe into the fresh grease just past normal travel through an area that normally never gets used. That's all it takes to get them functional again.
    Easy way to pry the latches:
    Total Resistance of pot = 5.16K (two outer legs).
    Pot set to middle left and center legs = 6.52K
    Pot set to middle right and center leg = 7.08K
    The sum of the resistance of each leg is significantly greater than the total resistance of the trim pot. That indicates that the pot is dirty and has high contact resistance. The sum of the resistance of the two legs should be close to the trimpots total resistance.
    In this case the total resistance is 5.16K and the sum of the two legs is: 6.52+7.08=13.6K , The dirty contacts added 8.44K ohms of resistance! (13.6K-5.16K).
    I used a drill that just fit the middle of the pot to give it a three second medium speed spin.
    The after results were good. With the trim pot in the centered position the sum of the resistance of each leg was close to the total resistance.
    Take away:
    • The trimpots are lubricated with a special trimpot grease that you don't want to mess with.
    • Removing the grease will greatly shorten the life of the pot and you probably won't be able to get much of it out. What actually fixes the pot is it gets rotated into a new area when you try to clean it.
    • You can achieve the same or better results with less effort by just rotating the pot through an unused area a couple of times.
    Mar 28 2015
    Final Results:
    Center and left pin reading
    Center and right pin reading
    The sum of the resistances of each leg of the pot is very close to the pots total resistance.
    2.44+2.60=5.04K ohms
    Total trim pot resistance = 5.16K
    The contact resistance has been fixed.
    Mar 28 2015
    Update: Its been almost 3 years and they still work perfectly.
    Jun 13 2017
    nowhere
    Great thread. My recirculating flaps are sticking I think or the temp blend actuator. It works when the car starts up and then on and off while driving as it wants to. I believe this is the fix for me. Thank you.
    Mar 05 2013
    2005 4Runner V8
    Island County, WA
    Quote Originally Posted by Kevin C View Post
    First, thank you for the detailed, easy to follow, and to the point post.
    Secondly, thank you for following up.
    You are appreciated.
    Sep 29 2023
    Michigan
    Take away:
    Would this work on a C7.5 S7? My passenger side gets hot but not AC cold
