View Poll Results: WWYD
Voters
5. You may not vote on this poll
  • Loctite 545
    2 40.00%
  • Permatex High Temp Thread Sealant
    4 80.00%
  • Copper Anti-Sieze
    0 0%
  • Copper Crush Washer
    0 0%
Multiple Choice Poll.
Results 1 to 27 of 27
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Big turbo guys.. how do u keep ur oil restrictor from leaking?
    I'm terrified of ripping the threads off of this thing after destroying the last one, but how tight do you need to go to seal it? After the first start I waited awhile for the oil to burn off.. but this is clearly a leak. I know how bad Teflon tape can be on oil lines, especially near a restrictor. What have you guys done? Torque specs?
    Sent from my Pixel XL using Audizine mobile app
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Senior Member Three Rings A4-Mike's Avatar
    Jun 12 2016
    Melbourne, Australia
    Have you got a copper washer on it?
    Just can't see one in the picture.
    Sent from my E6653 using Tapatalk
    Mar 25 2015
    Placer County
    Quote Originally Posted by A4-Mike View Post
    Nope. I don't see what that would do considering it won't even thread down far enough 🤷
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 25 2015
    Placer County
    Or actually maybe it will. I'll give it a try
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jun 12 2016
    Quote Originally Posted by Gunnarrrrr View Post
    The only thing different to mine is I have a copper washer on it.
    Mar 18 2014
    Washington
    We use loc-tite 545 on pipe thread fittings at my work (crazy vibration, high speed boats), its safe for diesel fuel systems. look up if it works with oil. far better then Teflon tape at least. Put it on the male threads but not first 1-2. Seals up some pretty nasty stuff Ive seen.
    Mar 25 2015
    Placer County
    Would you recommend refilling with fresh oil? I'm really dreading throwing out $50 worth of motul 🙄
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jun 12 2016
    I would only do that if I lost alot fixing it or I contaminated it
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    I used the highest temp red loctite I could find after a suggestion from a friend with the same turbo. Zero leaks since.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Mar 25 2015
    Placer County
    So I guess I'm going to try a crush washer + some loctite? And just not drain my oil and hope it stays in there? Lol
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jun 12 2016
    Sounds like a plan. Lol
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    A good first question would be what type of thread is in the turbo housing and does the thread of the restrictor match it? If they are both a taper pipe thread then the loctite pipe thread sealer is a good option. Also, do the threads fully mesh ( pipe thread with a taper) or does the adaptor bottom out in the housing?
    Short story is both thread types should match for thread pitch and type. Pipe thread to pipe thread or straight thread to straight. If you don't have pipe threads to seal the oil then you need some other contact surface either at the bottom of the fitting or at the top of the threads ( a washer under the head).
    Mar 25 2015
    Placer County
    Do you know what size copper washer you used or did it just come with a kit? The 13/14mm oil pan ones are too big
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Loctite 545 as others have said will do the job OR the high temp thread sealant @ O'Reilly's. Used it on all hoses to and from the turbo. No leaks with the exception of the coolant line not being tight enough at the block end.
    There is no washer on that fitting you are having problems with.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 28 2015
    Quote Originally Posted by A4SoftWalker View Post
    545 is amazing stuff, just make sure you give it time to cure before you put any pressure on it.
    Mar 25 2015
    Placer County
    So let me get this right,
    -no copper crush washer
    -locktite 545>oreilly's thread sealant
    Can I just unscrew the fitting real quick and try to put it back together with locktite before all the oil drains out? or do I need to make sure the threads are squeaky clean before putting the locktite on?
    I guess most of my oil will probs be in my oil pan tho, or can I put a vice grip on the stainless line so seal it temporarily or will that just damage it?
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 28 2015
    This would work better:
    http://www.oreillyauto.com/site/c/de...0802&ppt=C2392
    Use a bit of brake clean on the threads to get the oil off. Yes, the oil is in the sump and it won't drain the pan. After you disconnect it, if you give it a minute it should stop dripping.
    Mar 25 2015
    Placer County
    Quote Originally Posted by Kevin C View Post
    It looks like loctite 567 would be a better equivalent to the the permatex thread locker. 545 is only good to about 2-300 degrees, permatex says 400, so does 567. Since I don't feel like waiting for 567 to come in from amazon, I'll be picking up the permatex high temp from oreilly's I guess. Thanks everyone!
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    copper anitseize mo better. locks when heated. good up to 1800f.
    Mar 25 2015
    Placer County
    Now I don't know what to do. Maybe I should turn this into a poll.
    Edit: Cast your votes
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 28 2015
    Quote Originally Posted by heywier427 View Post
    Good idea on an exhaust manifold bolt, bad idea for fixing a leak on a fitting.
    Mar 15 2010
    Bothell
    You are overthinking this as far as oil drain. Mine was leaking and I disconnected the line and fitting and it dripped maybe 3 or 4oz of oil if that. Heck, just find a small tapered rubber plug and the second you undo the feed line jam that inside the feed line so it won't leak out.
    Pull the line off, undo the fitting, put the highest temp red loctite on it and ram it home. Job done. Mine has been 100% leak free since I did that.
    Jun 12 2016
    Mine came with the kit so not sure on size.
    Jan 08 2010
    CT Shoreline
    Its not meant to seal the leak, and neither is any of the other lockers mentioned.
    The copper washer does the sealing.
    A turbo easily sees temps upwards of 12-1800 deg f. Putting a sealer/locker on there that is rated for 300 deg. f. does nothing except turn to powder.
    Search subaru guys, and there use of this stuff. Their stuff doesnt seal ever!
    Mar 15 2010
    Bothell
    A copper washer won't work in this case because the gap is too large between the turbo face and the fitting. The turbo side has basically a bubble flare looking piece inside it that the fitting touches. So it bottoms out on that well before a copper washer could come into play.
    And if it turns red high temp locker to powder then why has mine stayed just fine and not leaked? I don't mean to sound like a dick, but my solution is currently working perfectly, there is no real reason to try other things.
    Mar 28 2015
    Search subaru guys, and their use of this stuff. Their stuff doesn't seal ever!
    Parts of the turbo see much higher temperatures than others. The center section is water and oil cooled. The sealer I recommend is rated for 400°F. If the oil line is seeing temperatures above that he is going to have much bigger problems.
    The material I linked to is meant to seal threads, so is Loctite 545. http://na.henkel-adhesives.com/produ...=8797960011777
    LOCTITE 545
    (Known as Loctite 545 Thread Sealant Hydraulic/Pneumatic Sealant )High lubricity thread sealant for locking and sealing metal pipes and small fittings with fine threads. LOCTITEŽ 545 is a pipe thread sealant designed for locking and sealing of metal pipes and fittings. It is specially formulated to offer high lubricity for easy assembly and removal. Recommended for fine threaded fittings as used in hydraulic and pneumatic installations and small fittings in general. Suitable for fittings up to 50 mm in diameter including pneumatic and hydraulic fittings.
    545 is rated to 300°F and the Permatex is rated to 400°F (Loctite 567 is the same stuff as the Permatex). Both materials will work on a center section but the Permatex / 567 version give the OP a bit more margin.
    Copper washer: Based on the picture, the housing does not appear to be machined for a washer. Right below the fitting it looks like its as cast.
    I checked the spec sheet for a GT2871R and the housing fitting should be a 0.4375IN-24 thread for a 6.35mm tube, inverted flare.
    The AN to turbo fitting should have a recess for a flare fitting, no sealer or copper washer needed at the turbo. These fittings should be correct for your turbo (EDIT: see Evo-Ski's post above... It took me a way too long to put this together).
    http://www.himni-racing.com/fittings...n-gt-bb-turbos
    The turbo housing should have this fitting:
    https://www.turbobygarrett.com/turbo...47_2_4_new.pdf
    OP: I would verify the fitting on your center section and make sure you get one that matches.
    Mar 25 2015
    Placer County
    confirmed that the fitting is 7/16-24, the gt25, gt28, gt30, gt35, etc all use the same fitting.
    You're correct, the housing is not machined, and even if there was a small enough gap to seal the restrictor against a crush washer, it wouldn't seal on the turbo side with the non-machined cast texture.
    Just picked up some permatex, I'll report back in a couple days.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
